[mpich-discuss] //Ssend(...) safe?
    Dorian Krause
    ddkrause at uni-bonn.de
    Sun Nov 16 13:14:40 CST 2008
Hi
Sören Freudiger wrote:
> Hi @All
> A hopefully very easy question. I just want to ensure that there's no misunderstanding:
> if(rank==0)
>    MPI::Request request = comm.Irecv(recvData, recvData.size, MPI__INT, 1, 100)
>    /* do something */
>    request.Wait();
>    request = comm.Irecv(...);
>    /* do something */
>    request.Wait();
> else
>    /* do something */
>    comm.Ssend(sendData, sendData.size, MPI::INT, 0, 100);
>    sendData[0] = 100;
> comm.Barrier();
> I read somewhere:
> " When a synchronous mode send operation is completed, the sending process may assume the destination process has begun receiving the message. The destination process need not be done receiving the message, but it must have begun receiving the message. "
> Does that mean that under certain circumstances sendData[0] = 100; changes the data that is send at my first comm.Ssend(..) call?
No. MPI_Ssend is blocking. Do whatever you like with the send data, MPI
will not return control before it is safe.
> I think it's like that:
> On the send side the send operation is completed as soon as the other side has started the receiving process. Nevertheless if all Data has been received on the other side there's no risk to write into the send buffer at the sending side again. That means: no chance that sendData[0] = 100; at first Ssend-operation. Am I correct?
> Best,
> DarkAnn
> PS: I'm using Ssend, because possibly my send-call happens before my Irecv has been called. That means Rsend results in undefined behaivoir and that means standard Send shouldn't been used because reday send could be implemented for that one.
I don't think so. As far as I know, MPI_Send may choose between
MPI_Bsend and MPI_Ssend. Am I wrong?
Dorian
