[mpich-discuss] Problems with mpi spawn multiple
    fernando_luz
    fernando_luz at tpn.usp.br
    Thu Nov  6 08:00:58 CST 2008
Thanks Rajeev,
It's works, but I need you MPI::ROOT in process parent, when I call
MPI::COMM_WORLD.Spawn_multiple.
Thanks again for the help
Fernando Luz
"Rajeev Thakur" <thakur at mcs.anl.gov> escreveu:
> The interface for MPI_Comm_spawn_multiple expects the program names to be
> passed in an array of pointers, not a 2D array of chars. For example, if
you
> declare it as
> char *program_name[2] = { "worker_02", "worker_02"};
> it should work.
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of fernando_luz
>> Sent: Tuesday, November 04, 2008 11:20 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] Problems with mpi spawn multiple
>> Yes,
>> This code is based in a example code of MPI_Spawn in mpi
>> forum homepage (
>> http://www.mpi-forum.org/docs/mpi-20-html/node98.htm#Node98 ).
>> I adapted the code in C++ and to use mpi spawn multiple. This
>> code work's
>> when I use with mpi spawn.
>> manager_02 code:
>> #include <mpi.h>
>> #include <iostream>
>> #include <string>
>> #define MAX 128
>> MPI::Status status;
>> MPI::Intercomm everyone;
>> MPI::Info information[10];
>> int  size, rank, universe_size, *universe_sizep, n, n_proc[10],
>> size_machine;
>> bool flag;
>> char machine[MAX], program_name[4][MAX], buffer[MAX], s_wdir[MAX],
>> s_path[MAX], temp[MAX];
>> int main(int argc, char *argv[]){
>>   MPI::Init(argc, argv);
>>   size = MPI::COMM_WORLD.Get_size();
>>   rank = MPI::COMM_WORLD.Get_rank();
>>   MPI::Get_processor_name(machine,size_machine);
>>   if (size != 1)  std::cerr << "Top heavy with management" <<
>> std::endl;
>>   flag = MPI::COMM_WORLD.Get_attr(MPI::UNIVERSE_SIZE,
>> &universe_sizep);
>>   if (!flag) {
>>     std::cout << "This MPI does not support UNIVERSE_SIZE. How many
>> processes total?" << std::endl;
>>     std::cin >> universe_size;
>>   else universe_size = *universe_sizep;
>>   if (universe_size == 1) std::cerr << "Não tem como iniciar
>> um processo
>> com universe_size igual a 1." << std::endl;
>>   universe_size = 3;
>>   for (int i = 0; i < universe_size-1; i++){
>>     strcpy(program_name[i], "worker_02");
>>     information[i] = information[i].Create();
>>     information[i].Set("wdir","/home/fernando_luz/");
>> information[i].Set("path","/home/fernando_luz/SVN/TPN3/casos_t
>> estes/02/worker_02/");
>>     information[i].Set("host", "a54");
>>     n_proc[i] = 1;
>>   everyone = MPI::COMM_WORLD.Spawn_multiple(universe_size-1,
>> (const char**)
>> program_name, MPI::ARGVS_NULL, n_proc, information, rank);
>>   strcpy(buffer,"Who are you?");
>>   everyone.Bcast(&buffer, MAX, MPI::CHAR, rank);
>>   for (int i=0; i < universe_size-1; i++){
>>     everyone.Recv(&buffer, MAX, MPI::CHAR, i, MPI::ANY_TAG, status);
>>     std::cout << "I am " << buffer << " with rank " <<
>> status.Get_source()
>> << std::endl;
>>     information[i].Free();
>>   MPI::Finalize();
>>   return 0;
>> worker_02 code:
>> #include <mpi.h>
>> #include <iostream>
>> #include <string>
>> #define MAX 128
>> MPI::Status status;
>> MPI::Intercomm parent;
>> int  rank, size, size_machine;
>> char machine[MAX], buffer[MAX];
>>   parent = parent.Get_parent();
>>   if (parent == MPI::COMM_NULL) std::cerr << "No daddy!!" <<
>> std::endl;
>>   size = parent.Get_remote_size();
>>   if (size != 1) std::cerr << "Problems with daddy..." << std::endl;
>>   rank = parent.Get_rank();
>>   parent.Bcast(&buffer, MAX, MPI::CHAR, 0);
>>   std::cout << "Process " << rank << " received in broadcast:
>> " << buffer
>> << std::endl;
>>   parent.Send(&machine, MAX, MPI::CHAR, 0, rank);
>>   MPI::Finalize();
>>   return 0;
>> and I start the program with "mpiexec -configfile executa.txt"
>> executa.txt file:
>> -host a53 -path
>> /home/fernando_luz/SVN/TPN3/casos_testes/02/manager_02/
>> -wdir /home/fernando_luz/ -l -exitinfo manager_02
>> Thanks for help
>> Fernando Luz
