[mpich-discuss] mpich2 1.0.8 on windows - domain required?
    Thomas Blom
    blomcode at gmail.com
    Wed Nov  5 10:08:24 CST 2008
I didn't try linux, but I'm sure it is easy.  Mac osx is bsd basically, and
on a couple macs I got the source, did the configure/make/make install
standard procedure which they document well in the install guide and it all
worked without problem.
-thomas
On Tue, Nov 4, 2008 at 7:12 PM, Marcus Vinicius Brandão Soares <
mvbsoares at gmail.com> wrote:
> Just being curious (this is my first post ...): have you already trued to
> run MPICH2 with Linux ?
> Best regards,
> Marcus Vinicius.
> 2008/11/3, Thomas Blom <blomcode at gmail.com>:
>> Thanks so much for your timely and detailed help.  Sorry that I became
>> involved in other issues today and my reply is delayed.
>> 1.  I removed mpich2 completely and reinstalled, and rebooted between and
>> after these operations (as every superstitious windows-user has learned to
>> do when problems occur).  I installed for everyone, as I have done
>> previously.
>> 2.  mpiexec -validate simply prints the statement "FAIL"
>> 3.  I followed your directions for smpd and mpiexec in debug/verbose
>> mode.  Log files are attached.
>> I will continue to play with this; thanks again for your continued help.
>> My intuition is that this problem has to do with my having both renamed the
>> machine and my user account just prior to setting this up a few days ago (to
>> make the user accounts the same on both machines and make the machine-name
>> less unwieldy to type).  But every other test I have performed to check the
>> validity of the new names passes.
>> -thomas blom, austin tx
>> On Mon, Nov 3, 2008 at 11:22 AM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>>>  Hi,
>>>  Can you try re-installing MPICH2 making sure that MPICH2 is installed
>>> for "Everyone" (the default is "Just me" - the user installing MPICH2) and
>>> re-run mpiexec ?
>>>  Can you validate the username/password registered on mb13 using the
>>> "-validate" option of mpiexec (mpiexec -validate)?
>>>  If that does not work please provide us the debug logs for smpd/mpiexec,
>>> On mb13,
>>> 1) Stop any instances of smpd running on the machine using the command,
>>> smpd -stop
>>> 2) Run smpd in the debug mode & redirect the output to a log file, smpd
>>> -d > smpd.log
>>> 3) In another command window run mpiexec in debug/verbose mode and
>>> redirect the output to a logfile, mpiexec -verbose -n 2 hostname >
>>> mpiexec.log
>>> 4) Provide us with the mpiexec/smpd log files.
>>> Regards,
>>> Jayesh
>>> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
>>> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Thomas Blom
>>> *Sent:* Monday, November 03, 2008 10:41 AM
>>> *To:* mpich-discuss at mcs.anl.gov
>>> *Subject:* Re: [mpich-discuss] mpich2 1.0.8 on windows - domain
>>> required?
>>> Yes, I've tried this.  To eliminate questions about the machine name
>>> etc... I have
>>> 1.  go through network setup wizards again to establish that the machine
>>> name is mb13 and the workgroup is LOGIC; disable  firewall.
>>> (reboot)
>>> 1.5 Verify that I can share a folder on mb13, and from the other computer
>>> can successfully map a drive to \\mb13\sharename -- this establishes that
>>> mb13 is the recognized computer name.  And that other computers can reach it
>>> at that name.
>>> 2.  uninstall mpich2 completely
>>> 3.  install mpich2
>>> (reboot)
>>> 4. mpi -register, and provide username/password of an account on the
>>> machine that is a "computer administrator" (thomas)
>>> I still am unable to simply run mpiexec -n 2 hostname.... I get the same
>>> "Credentials for thomas rejected connecting to mb13"
>>> I am able to run 'smpd -status' and it tells me that smpd is running on
>>> mb13.
>>> Good grief... (my build from source & testing on two bsd-based macs took
>>> about 15 minutes)
>>> -thomas
>>> On Mon, Nov 3, 2008 at 10:21 AM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>>>>  Hi,
>>>>  Try re-registering your username(thomas)/password in mb13 using
>>>> "mpiexec -register" command.
>>>> Regards,
>>>> Jayesh
>>>> *Sent:* Monday, November 03, 2008 10:12 AM
>>>> required?
>>>>   The test command suggested (mpiexec -n 2 hostname) works fine on one
>>>> of the machines.  On the other machine (both are winXP) I get the error:
>>>> Aborting: Unable to connect to mb13
>>>> This is the result of just running locally, not over a network!  In
>>>> answer to the previous question, 'thomas' is not a domain user.  This is
>>>> just two winXP machines on a local network that are part of the same
>>>> "workgroup" but neither are part of any domain.
>>>> I wonder if this has to do with my having changed the machine name on
>>>> mb13 ... but I have since completely uninstalled and installed mpich2.  I
>>>> left the default phrase "behappy" during this installation.  I then ran
>>>> wmpiregister and entered my username and password (which I use to login to
>>>> each machine sucessfully).
>>>> I have tried to play with wmpiconfig, but it is a little difficult to
>>>> understand how to use this.  I don't find any documentation for it.
>>>> Thanks very much for any help....
>>>> On Mon, Nov 3, 2008 at 9:01 AM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>>>>>  Hi,
>>>>>  The machines don't have to be part of the same domain to be part of
>>>>> your MPI job (This requirement is only for setups which use the SSPI
>>>>> authentication mechanism to launch MPI jobs).
>>>>>  Can you run a non-MPI command like hostname on the local machine ?
>>>>>  Is the user "thomas" a domain user ? In that case you should register
>>>>> the username with the domainname (DOMAINNAME\USERNAME) when registering the
>>>>> username (mpiexec -register) with mpiexec.
>>>>>  Let us know if you still have problems.
>>>>> Regards,
>>>>> Jayesh
>>>>> *Sent:* Sunday, November 02, 2008 8:45 AM
>>>>> *Subject:* [mpich-discuss] mpich2 1.0.8 on windows - domain required?
>>>>>   Hello,
>>>>> I have just subscribed to the list to ask a question about mpich2 on
>>>>> windows.  (I found the archives but don't see a way to search them).
>>>>> Is it a requirement that the windows computers participating in mpich2
>>>>> be part of a windows domain?  I see things in the documentation that perhaps
>>>>> imply this, but not state it outright.
>>>>> My computers are simply on a local network, and part of a "workgroup".
>>>>> The smpd process manager can "see" the other systems to some extent, since
>>>>> the result of
>>>>> smpd -status mb13    // mb13 is the hostname of my other windows pc
>>>>> correctly finds that smpd is running on my other host.  But executing
>>>>> mpiexec and providing hostnames in a "machinefile" e.g.
>>>>> mpiexec -n 4 -machinefile machines echo %COMPUTERNAME%
>>>>> fails with:
>>>>> I have taken care that the username/pass is identical on each machine,
>>>>> the user is admin, etc.  I have followed steps I've found in various
>>>>> documents about uninstalling/installing smpd and providing the identical
>>>>> passphrase on each, running mpiexec -register, etc...
>>>>> Any ideas?  (Or is it just that I must be running on a domain, which I
>>>>> cannot find concrete documentation about)
>>>>> thanks very much,
>>>>> thomas blom in austin, tx
> Marcus Vinicius
> "Havendo suficientes colaboradores,
> Qualquer problema é passível de solução"
> Eric S. Raymond
> A Catedral e o Bazar
> "O passado é apenas um recurso para o presente"
> Clave de Clau
> "A melhor causa é sempre a próxima"
> Evandro Lins e Silva
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081105/f2937ee0/attachment.htm>
