[mpich-discuss] mpich2 1.0.8 on windows - domain required?
    Thomas Blom
    blomcode at gmail.com
    Mon Nov  3 19:06:29 CST 2008
Thanks so much for your timely and detailed help.  Sorry that I became
involved in other issues today and my reply is delayed.
1.  I removed mpich2 completely and reinstalled, and rebooted between and
after these operations (as every superstitious windows-user has learned to
do when problems occur).  I installed for everyone, as I have done
previously.
2.  mpiexec -validate simply prints the statement "FAIL"
3.  I followed your directions for smpd and mpiexec in debug/verbose mode.
Log files are attached.
I will continue to play with this; thanks again for your continued help.  My
intuition is that this problem has to do with my having both renamed the
machine and my user account just prior to setting this up a few days ago (to
make the user accounts the same on both machines and make the machine-name
less unwieldy to type).  But every other test I have performed to check the
validity of the new names passes.
-thomas blom, austin tx
On Mon, Nov 3, 2008 at 11:22 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
>  Hi,
>  Can you try re-installing MPICH2 making sure that MPICH2 is installed for
> "Everyone" (the default is "Just me" - the user installing MPICH2) and
> re-run mpiexec ?
>  Can you validate the username/password registered on mb13 using the
> "-validate" option of mpiexec (mpiexec -validate)?
>  If that does not work please provide us the debug logs for smpd/mpiexec,
> On mb13,
> 1) Stop any instances of smpd running on the machine using the command,
> smpd -stop
> 2) Run smpd in the debug mode & redirect the output to a log file, smpd -d
> > smpd.log
> 3) In another command window run mpiexec in debug/verbose mode and redirect
> the output to a logfile, mpiexec -verbose -n 2 hostname > mpiexec.log
> 4) Provide us with the mpiexec/smpd log files.
> Regards,
> Jayesh
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Thomas Blom
> *Sent:* Monday, November 03, 2008 10:41 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] mpich2 1.0.8 on windows - domain required?
> Yes, I've tried this.  To eliminate questions about the machine name etc...
> I have
> 1.  go through network setup wizards again to establish that the machine
> name is mb13 and the workgroup is LOGIC; disable  firewall.
> (reboot)
> 1.5 Verify that I can share a folder on mb13, and from the other computer
> can successfully map a drive to \\mb13\sharename -- this establishes that
> mb13 is the recognized computer name.  And that other computers can reach it
> at that name.
> 2.  uninstall mpich2 completely
> 3.  install mpich2
> (reboot)
> 4. mpi -register, and provide username/password of an account on the
> machine that is a "computer administrator" (thomas)
> I still am unable to simply run mpiexec -n 2 hostname.... I get the same
> "Credentials for thomas rejected connecting to mb13"
> I am able to run 'smpd -status' and it tells me that smpd is running on
> mb13.
> Good grief... (my build from source & testing on two bsd-based macs took
> about 15 minutes)
> -thomas
> On Mon, Nov 3, 2008 at 10:21 AM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>>  Hi,
>>  Try re-registering your username(thomas)/password in mb13 using "mpiexec
>> -register" command.
>> Regards,
>> Jayesh
>> *Sent:* Monday, November 03, 2008 10:12 AM
>>   The test command suggested (mpiexec -n 2 hostname) works fine on one of
>> the machines.  On the other machine (both are winXP) I get the error:
>> Aborting: Unable to connect to mb13
>> This is the result of just running locally, not over a network!  In answer
>> to the previous question, 'thomas' is not a domain user.  This is just two
>> winXP machines on a local network that are part of the same "workgroup" but
>> neither are part of any domain.
>> I wonder if this has to do with my having changed the machine name on mb13
>> ... but I have since completely uninstalled and installed mpich2.  I left
>> the default phrase "behappy" during this installation.  I then ran
>> wmpiregister and entered my username and password (which I use to login to
>> each machine sucessfully).
>> I have tried to play with wmpiconfig, but it is a little difficult to
>> understand how to use this.  I don't find any documentation for it.
>> Thanks very much for any help....
>> On Mon, Nov 3, 2008 at 9:01 AM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>>>  Hi,
>>>  The machines don't have to be part of the same domain to be part of your
>>> MPI job (This requirement is only for setups which use the SSPI
>>> authentication mechanism to launch MPI jobs).
>>>  Can you run a non-MPI command like hostname on the local machine ?
>>>  Is the user "thomas" a domain user ? In that case you should register
>>> the username with the domainname (DOMAINNAME\USERNAME) when registering the
>>> username (mpiexec -register) with mpiexec.
>>>  Let us know if you still have problems.
>>> Regards,
>>> Jayesh
>>> *Sent:* Sunday, November 02, 2008 8:45 AM
>>> *Subject:* [mpich-discuss] mpich2 1.0.8 on windows - domain required?
>>>   Hello,
>>> I have just subscribed to the list to ask a question about mpich2 on
>>> windows.  (I found the archives but don't see a way to search them).
>>> Is it a requirement that the windows computers participating in mpich2 be
>>> part of a windows domain?  I see things in the documentation that perhaps
>>> imply this, but not state it outright.
>>> My computers are simply on a local network, and part of a "workgroup".
>>> The smpd process manager can "see" the other systems to some extent, since
>>> the result of
>>> smpd -status mb13    // mb13 is the hostname of my other windows pc
>>> correctly finds that smpd is running on my other host.  But executing
>>> mpiexec and providing hostnames in a "machinefile" e.g.
>>> mpiexec -n 4 -machinefile machines echo %COMPUTERNAME%
>>> fails with:
>>> I have taken care that the username/pass is identical on each machine,
>>> the user is admin, etc.  I have followed steps I've found in various
>>> documents about uninstalling/installing smpd and providing the identical
>>> passphrase on each, running mpiexec -register, etc...
>>> Any ideas?  (Or is it just that I must be running on a domain, which I
>>> cannot find concrete documentation about)
>>> thanks very much,
>>> thomas blom in austin, tx
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081103/e9702886/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081103/e9702886/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081103/e9702886/attachment-0001.obj>
