[mpich-discuss] mpich2 1.0.8 on windows - domain required?
Thomas Blom
blomcode at gmail.com
Mon Nov 3 10:41:26 CST 2008
Yes, I've tried this. To eliminate questions about the machine name etc...
I have
1. go through network setup wizards again to establish that the machine
name is mb13 and the workgroup is LOGIC; disable firewall.
(reboot)
1.5 Verify that I can share a folder on mb13, and from the other computer
can successfully map a drive to \\mb13\sharename -- this establishes that
mb13 is the recognized computer name. And that other computers can reach it
at that name.
2. uninstall mpich2 completely
3. install mpich2
(reboot)
4. mpi -register, and provide username/password of an account on the machine
that is a "computer administrator" (thomas)
I still am unable to simply run mpiexec -n 2 hostname.... I get the same
"Credentials for thomas rejected connecting to mb13"
I am able to run 'smpd -status' and it tells me that smpd is running on
mb13.
Good grief... (my build from source & testing on two bsd-based macs took
about 15 minutes)
-thomas
On Mon, Nov 3, 2008 at 10:21 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
> Try re-registering your username(thomas)/password in mb13 using "mpiexec
> -register" command.
> Regards,
> Jayesh
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Thomas Blom
> *Sent:* Monday, November 03, 2008 10:12 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] mpich2 1.0.8 on windows - domain required?
> The test command suggested (mpiexec -n 2 hostname) works fine on one of the
> machines. On the other machine (both are winXP) I get the error:
> Aborting: Unable to connect to mb13
> This is the result of just running locally, not over a network! In answer
> to the previous question, 'thomas' is not a domain user. This is just two
> winXP machines on a local network that are part of the same "workgroup" but
> neither are part of any domain.
> I wonder if this has to do with my having changed the machine name on mb13
> ... but I have since completely uninstalled and installed mpich2. I left
> the default phrase "behappy" during this installation. I then ran
> wmpiregister and entered my username and password (which I use to login to
> each machine sucessfully).
> I have tried to play with wmpiconfig, but it is a little difficult to
> understand how to use this. I don't find any documentation for it.
> Thanks very much for any help....
> -thomas blom, austin tx
> On Mon, Nov 3, 2008 at 9:01 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
>> Hi,
>> The machines don't have to be part of the same domain to be part of your
>> MPI job (This requirement is only for setups which use the SSPI
>> authentication mechanism to launch MPI jobs).
>> Can you run a non-MPI command like hostname on the local machine ?
>> Is the user "thomas" a domain user ? In that case you should register the
>> username with the domainname (DOMAINNAME\USERNAME) when registering the
>> username (mpiexec -register) with mpiexec.
>> Let us know if you still have problems.
>> Regards,
>> Jayesh
>> *Sent:* Sunday, November 02, 2008 8:45 AM
>> *Subject:* [mpich-discuss] mpich2 1.0.8 on windows - domain required?
>> Hello,
>> I have just subscribed to the list to ask a question about mpich2 on
>> windows. (I found the archives but don't see a way to search them).
>> Is it a requirement that the windows computers participating in mpich2 be
>> part of a windows domain? I see things in the documentation that perhaps
>> imply this, but not state it outright.
>> My computers are simply on a local network, and part of a "workgroup".
>> The smpd process manager can "see" the other systems to some extent, since
>> the result of
>> smpd -status mb13 // mb13 is the hostname of my other windows pc
>> correctly finds that smpd is running on my other host. But executing
>> mpiexec and providing hostnames in a "machinefile" e.g.
>> mpiexec -n 4 -machinefile machines echo %COMPUTERNAME%
>> fails with:
>> I have taken care that the username/pass is identical on each machine, the
>> user is admin, etc. I have followed steps I've found in various documents
>> about uninstalling/installing smpd and providing the identical passphrase on
>> each, running mpiexec -register, etc...
>> Any ideas? (Or is it just that I must be running on a domain, which I
>> cannot find concrete documentation about)
>> thanks very much,
>> thomas blom in austin, tx
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081103/b4c8d67d/attachment.htm>
