[mpich-discuss] mpich2 and sending message from a task to itself
Bryan Putnam
bfp at purdue.edu
Fri May 30 07:13:16 CDT 2008
On Thu, 29 May 2008, Rajeev Thakur wrote:
> The send-to-yourself needs to be either a nonblocking send or the receive
> must be posted before the send. MPI_Send will block for the receive to be
> posted.
> Rajeev
Rajeev,
One of my co-workers makes the following comment:
That contradicts Section 2.2 in MPI: The Complete Reference (Blocking Send
and Receive Operations), which specifically says on page I-37 that a
process may use MPI_SEND to send a message to itself. I see nothing there
about a need to post a receive before the send, and at any rate,
nonblocking sends and receives are not discussed until section 2.8.
Bryan
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Bryan Putnam
> > Sent: Thursday, May 29, 2008 3:26 PM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: [mpich-discuss] mpich2 and sending message from a
> > task to itself
> > Hi,
> > I've found that if I take a standard "hello, world" program
> > (where master
> > sends "hello" to all tasks except itself), and modify it so
> > that master
> > sends "hello" to all tasks including itself, I get a
> > "MPI_Send" error when
> > using mpich2-1.0.7, of the form
> > Fatal error in MPI_Send: Error message texts are not
> > available[cli_0]:
> > aborting job:
> > From what we can tell, sending a message to yourself is
> > allowed by the MPI
> > standard:
> > From MPI: The Complete Reference (I-37):
> > The range of valid values for [the destination argument] is 0..n-1,
> > where n is the number of processes in the group. This range includes
> > the rank of the sender: if [the communicator] is an intracommunicator,
> > then a process may send a message to itself.
> > MPI::COMM_WORLD is indeed an intracommunicator.
> > For your enjoyment, I've included my original code, and followed it
> > by the modified code.
> > Thanks!
> > Bryan
> > program hellof
> > include 'mpif.h'
> > integer me, nt, mpierr, status(MPI_STATUS_SIZE)
> > integer tag
> > character*12 message, inmsg
> > call MPI_INIT(mpierr)
> > call MPI_COMM_SIZE(MPI_COMM_WORLD, nt, mpierr)
> > call MPI_COMM_RANK(MPI_COMM_WORLD, me, mpierr)
> > tag = 1
> > if(me .eq. 0) then
> > message = 'Hello world!'
> > do i=1,nt-1
> > call MPI_SEND(message, 12, MPI_CHARACTER, i, tag,
> > & MPI_COMM_WORLD, mpierr)
> > enddo
> > write(6,*) 'node', me, ': ', message
> > else
> > call MPI_RECV(inmsg, 12, MPI_CHARACTER, 0, tag,
> > & MPI_COMM_WORLD, status, mpierr)
> > write(6,*) 'node', me, ': ', inmsg
> > endif
> > call MPI_FINALIZE(mpierr)
> > end
> > Modified code:
> > program hellof
> > include 'mpif.h'
> > integer tag
> > tag = 1
> > if(me .eq. 0) then
> > do i=0,nt-1
> > enddo
> > endif
> > end
