[mpich-discuss] IMB 3.1 with TOL 0 crashes on Allreduce
    Calin Iaru
    calin at dolphinics.com
    Mon May 26 05:49:37 CDT 2008
The problem is that the latest mpich2 in combination with IMB 3.1
generates a data corruption error when running on 2 nodes. IMB was
compiled with the CHECK flag and TOL set to 0 inside IMB_declare.h. I am
not sure if this is a transport error or a verification error; it could
be that the problem lies in the application code.
E:\Program Files\MPICH2\bin>mpiexec.exe -hosts 2 node-1 node-2
\\node-1\e$\imb-mpi1.exe allreduce
#    Intel (R) MPI Benchmark Suite V3.1, MPI-1 part
# Date                  : Fri May 23 14:44:12 2008
# Machine               : x86 Family 15 Model 4 Stepping 1, GenuineIntel
# System                : Windows 2003
# Release               : 5.2.3790
# Version               : Service Pack 1
# MPI Version           : 2.0
# MPI Thread Environment: MPI_THREAD_SINGLE
# Calling sequence was:
# \\node-1\e$\imb-mpi1.exe allreduce
# Minimum message length in bytes:   0
# Maximum message length in bytes:   4194304
# MPI_Datatype                   :   MPI_BYTE
# MPI_Datatype for reductions    :   MPI_FLOAT
# MPI_Op                         :   MPI_SUM
# List of Benchmarks to run:
# Allreduce
# Benchmarking Allreduce
# #processes = 2
       #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]
defects
            0         1000         0.51         0.52
0.51         0.00
            4         1000        80.30        80.35
80.33         0.00
1: Error Allreduce, size = 8, sample #0
Process 1: Got invalid buffer:
Buffer entry: 2.300000
0: Error Allreduce, size = 8, sample #0
Process 0: Got invalid buffer:
