[mpich-discuss] MPICH on multiple NICs, and how to choose the best computing node
    Gus Correa
    gus at ldeo.columbia.edu
    Wed May 21 12:23:45 CDT 2008
Hello MPICH experts
MPICH developers:  Do you recommend any particular solution
to reduce network contention on multi-core/multi-slot nodes?
Which solutions work with MPICH2, and which don't?
Besides link aggregation/bonding (Thank you Diego for your suggestion.),
I've also read about using a different IP address for each NIC on a node.
There may be other ways to do this as well.
One problem with bonding is that it is not supported by the main
free cluster management software, Cluster Rocks, which we use.
They suggest using multiple IPs on each node.
I wonder if multiple IPs would work with MPICH2,
if it would impact MPI programming and efficiency, and how.
Many thanks to all.
Gus Correa
Diego M. Vadell wrote:
>Hi,
>   It looks to me like you are describing "bonding" (
>http://www.linux-corner.info/bonding.html ). Is it good enough?
>Regards,
> -- Diego.
>On Tuesday 20 May 2008 17:49:05 Gus Correa wrote:
>>Hello MPICH experts
>>1) I wonder if MPICH2 (and/or MPICH-1) works with multiple
>>(Gigabit)Ethernet NICs
>>installed on each computer node on a Linux/Beowulf cluster.
>>The naive idea here would be to increase network bandwidth and reduce
>>contention by using multiple NICs.
>>Network contention may become an issue in the typical "eight core
>>computer node"
>>that is popular now on the market (two-slot quad-core nodes).
>>I will need to buy a replacement for our small old cluster soon,
>>and I don't know what would be the most cost effective choice to run our
>>MPICH-based code:
>>"two-slot quad-core nodes",  "two-slot dual-core nodes",
>>or other (single core processors seem to be an extinct species).
>>Of course, the price of one two-slot quad-core node is significantly
>>less than the price
>>of a couple of two-slot dual-core nodes.
>>However, it looks like to me that MPICH may not be as efficient with
>>eight cores sharing a single NIC,
>>as it would be in a two-slot dual-core node (four cores sharing a NIC).
>>Where the optimal price/performance point resides I don't know.
>>2) If MPICH does work with multiple NICs,
>>are there guidelines, documentation, or a recipe on how to set up a
>>scheme like this?
>>3) Any other suggestions to avoid/reduce MPICH network contention in
>>multicore/multiprocessor computer nodes?
>>(Using OpenMP within the nodes is not so convenient, as it requires
>>intensive re-coding,
>>and is not particularly simple or efficient in large programs.
>>Buying Infiniband, Myrinet, etc, is not possible with our shoestring
>>budget, and I got to stick to and be happy with Gigabit Ethernet.)
>>If this question was discussed before, as it is likely to be the case,
>>please just point to me the right thread in the mailing list.
>>Many thanks,
>>Gus Correa
