[mpich-discuss] gfortran and mpich2 interaction
    Steve Kargl
    sgk at troutmask.apl.washington.edu
    Fri May  9 17:26:27 CDT 2008
On Fri, May 09, 2008 at 07:00:53PM -0300, jdelia at intec.unl.edu.ar wrote:
> Steve Kargl <sgk at troutmask.apl.washington.edu> ha escrito:
> >On Fri, May 09, 2008 at 06:12:13PM -0300, jdelia at intec.unl.edu.ar wrote:
> >>Your suggestion about to use "call flush (6)" works very nice. I only
> >>have to change to the gfortran flag "-std=gnu". The fixed sample
> >>program is included at the end of this reply.
> >If you have at least version 4.2.3 of gfortran, you can
> >change 'call flush(6)' to simply 'flush(6)', which is
> >standard conforming Fortran 2003 feature.
> OK. Then, with your suggestion  I can return again to the gfortran
> flag "-std=f2003".
Yes, of course (provided you have gfortran 4.2.3 or newer).  I
also suspect that this will be accepted by ifort although I
can't teist it.
Steve
