[mpich-discuss] gfortran and mpich2 interaction
jdelia at intec.unl.edu.ar
Fri May 9 06:13:17 CDT 2008
Dear developers,
From the first distributions of the GFORTRAN compiler (experimental
or not), I had noticed a little execution problem (of low impact) when
the attached test program runs in parallel using MPICH2. I ignore if
it is a problem of GFORTRAN or MPICH2 but it does not happen neither
with G95 nor with IFORT.
As a simple test (please, see at the end of this message), the
processor 0 must read a variable "n" that is entered by console.
During the execution (including the case with a single process), it
does not print any message until a value is entered for the required
variable.
In the present test I used the current 1.0.7 stable version of MPICH2
(http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)
$ which mpif90
/usr/local/mpich2-exp/1.0.7/bin/mpif90
$ mpif90 --version
GNU Fortran (GCC) 4.4.0 20080302 (experimental) [trunk revision 132813]
Copyright (C) 2007 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
$ mpif90 -Wall -std=f2003 -fPIC -o testinputmpi.exe testinputmpi.f90
$ mpiexec -machinefile ~/machi.dat -np 1 testinputmpi.exe
100
100
100
matrix rank ; n : ?
matrix rank ; n = 100
matrix rank ; n : ?
matrix rank ; n : ?
$ cat /proc/version
Linux version 2.6.9-22.0.1.ELsmp (root at yort.fnal.gov) (gcc version
3.4.3 20050227 (Red Hat 3.4.3-22.1)) #1 SMP Thu Oct 27 10:53:36 CDT 2005
The nodes of our Beowulf cluster are 32-bit processors (i386, Intel
Pentium 4).
Perhaps, if this problem is in the way that the program is compiled or
the MPICH2 was built (please, see config.log.gz attached file), is
there some compilation or building flag for fix this little trouble ?
Thanks in advance,
Jorge.
! MPICH2
! which mpif90
! mpif90 --version
! mpif90 -Wall -std=f2003 -fPIC -o testinputmpi.exe testinputmpi.f90
! mpdboot -n 5 -f ~/mpd.hosts
! mpdtrace
! mpdringtest
! mpiexec -machinefile ~/machi.dat -np 2 testinputmpi.exe
! mpdallexit
program testinputmpi
use mpi
implicit none
integer :: myid, siza, ierr, master=0, n
call MPI_Init (ierr)
call MPI_Comm_size (MPI_COMM_WORLD, siza, ierr) ! number of processes
call MPI_Comm_rank (MPI_COMM_WORLD, myid, ierr) ! my rank
if (myid == master) then
! alternative 1
write (*,*)
write (*,*) " matrix rank ; n : ? "
read (*,*) n
write (*,*) " matrix rank ; n = ", n
! alternative 2
write (6,*)
write (6,*) " matrix rank ; n : ? "
read (5,*) n
write (6,*) " matrix rank ; n = ", n
! alternative 3
print *
print *, " matrix rank ; n : ? "
read (*,*) n
print *, " matrix rank ; n = ", n
else
write (*,*) "hellow from ", myid, " of ", siza, "processes"
end if
call MPI_Finalize (ierr)
end program
CIMEC, http://www.cimec.org.ar/
INTEC, Guemes 3450, 3000-Santa Fe, ARGENTINA
tel: +54-342-451.15.94, extension 1018;
+54-342-455.91.75, fax: +54-342-455.09.44
Universidad Nacional del Litoral (UNL)
Consejo Nacional de Investigaciones Cientificas y Tecnicas (CONICET)
This message was sent using IMP, the Internet Messaging Program.
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080509/0cfe4e6a/attachment.bin>
