[mpich-discuss] MPE
    Anthony Chan
    chan at mcs.anl.gov
    Wed May  7 12:49:29 CDT 2008
----- "Alberto Giannetti" <albertogiannetti at gmail.com> wrote:
> 1.0.7. by the way, is there a command to check mpich2 version and default
> parameters values, like ompi_info for OMPI?
<mpich2-install-dir>/bin/mpich2version (does not contain as much info
as ompi_info though)
Just in case you don't know: You can compile your code with "mpicc -mpe=mpilog".
The mpich2-1.0.7/src/mpe2/README has detailed usage on MPE logging.  MPICH2-1.0.7's
user's guide has a section on MPE logging.
A.Chan
> On May 7, 2008, at 1:00 PM, Anthony Chan wrote:
> > MPE is installed by default for MPICH2.  (But MPE can be configured
> > for other MPI implementations).  What version of MPICH2 are you
> > using ?
> > A.Chan
> >> Do I have to statically configure MPICH2 with logging enabled to
> use
> >> MPE functions? Why wouldn't an MPE-enabled install be the default?
