[mpich-discuss] mpdboot handshake problem
Rajeev Thakur
thakur at mcs.anl.gov
Wed May 7 10:38:41 CDT 2008
Sometimes this is caused by a stray mpd already running on the machine. Do a
ps on n002 and "kill -9" any mpd if it is there.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Qi Ying
> Sent: Wednesday, May 07, 2008 9:37 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpdboot handshake problem
> I did follow the guide and everything works as it should.
> What confuses me is I can manually start the mpd manually
> without problem, for example:
> [qying at n002 ~]$ mpd &
> [qying at n002 ~]$ mpdtrace -l
> n002.newwolf.edu_39682 (192.168.0.2)
> [qying at n001 ~]$ mpd -h n002 -p 39682 &
> [qying at n001 ~]$ mpdtrace
> n001
> n002
> [qying at n001 ~]$ mpdringtest
> time for 1 loops = 0.000439882278442 seconds
> Seems everything is working fine. It is just that n002 does not work.
> I have 19 additional nodes running on the system and they are
> all working fine.
> Qi
> On Tue, May 6, 2008 at 12:21 PM, Rajeev Thakur
> <thakur at mcs.anl.gov> wrote:
> > It could be something with the networking configuration on the
> > machines. You can debug the problem by using the mpdcheck
> utility and
> > following all the steps described in the installation guide.
> > Rajeev
> > > Sent: Tuesday, May 06, 2008 12:04 PM
> > > Subject: [mpich-discuss] mpdboot handshake problem
> > > Hi All,
> > > Recently I had trouble starting mpd using mpdboot on my cluster.
> > > This seems caused by a single node in the system (n002). The
> > > following is the debugging output. However, I can
> manually start mpd
> > > on n001 and
> > > n002 (and have them join the ring), and there is no problem. Any
> > > insights or suggestions?
> > > Thanks,
> > > Qi Ying
> > > [qying at n001~] $ mpdboot -n 2 -f ~/mpd.hosts
> --rsh=/usr/bin/rsh -v -d
> > > running mpdallexit on n001.newwolf.edu LAUNCHED mpd on
> > > n001.newwolf.edu via
> > > debug: launch cmd= /opt/mpich2/bin/mpd.py --ncpus=1 -e -d
> > > debug: mpd on n001.newwolf.edu on port 55059
> > > RUNNING: mpd on n001.newwolf.edu
> > > debug: info for running mpd: {'ncpus': 1, 'list_port': 55059,
> > > 'entry_port': '', 'host': 'n001.newwolf.edu', 'entry_host': '',
> > > 'ifhn': ''}
> > > LAUNCHED mpd on n002 via n001.newwolf.edu
> > > debug: launch cmd= /usr/bin/rsh -n n002
> '/opt/mpich2/bin/mpd.py -h
> > > n001.newwolf.edu -p 55059 --ncpus=1 -e -d'
> > > debug: mpd on n002 on port 54319
> > > mpdboot_n001.newwolf.edu (handle_mpd_output 385): failed to
> > > handshake with mpd on n002; recvd output={}
