[mpich-discuss] Problem sometimes when running on winxp on >=2 processes and MPE_IBCAST
    Ben Tay
    zonexo at gmail.com
    Wed May  7 10:25:20 CDT 2008
I tried to run a mpi code which is copied from an example by the RS 6000
book. It is supposed to broadcast and synchronize all values. When I ran
it on my school's linux servers, there is no problem. However, if I run
it on my own winxp, on >=2 processes, sometimes it work, other times I
get the error:
[01:3216].....ERROR:result command received but the wait_list is empty.
[01:3216]...ERROR:unable to handle the command: "cmd=result src=1 dest=1
tag=7 c
md_tag=3 cmd_orig=dbget ctx_key=1 value="port=1518
description=gotchama-16e5ed i
fname=192.168.1.105 " result=DBS_SUCCESS "
[01:3216].ERROR:error closing the unknown context socket: generic socket
failure
, error stack:
MPIDU_Sock_wait(2603): The I/O operation has been aborted because of
either a th
read exit or an application request. (errno 995)
[01:3216]..ERROR:sock_op_close returned while unknown context is in
state: SMPD_
IDLE
Or
[01:3308].....ERROR:result command received but the wait_list is empty.
[01:3308]...ERROR:unable to handle the command: "cmd=result src=1 dest=1
tag=15
cmd_tag=5 cmd_orig=barrier ctx_key=0 result=DBS_SUCCESS "
[01:3308]..ERROR:sock_op_close returned while unknown context is in
state: SMPD_
IDLE
There is no problem if I run on 1 process. If it's >=4, then the error
happens all the time. Moreover, it's a rather simple code and so there
shouldn't be anything wrong with it. Why is this so?
Btw, the RS 6000 book also mention a routine called MPE_IBCAST, which is
a non-blocking version of MPI_BCAST. Is there a similar routine in MPICH2?
Thank you very much
Regards.
