[mpich-discuss] Error with MPI - mpirun+MPICH mpiexec+MPICH2
Jayesh Krishna
jayesh at mcs.anl.gov
Tue May 6 09:02:30 CDT 2008
As you mentioned in your email you should *right* job laucher (mpirun for
MPICH & mpiexec for MPICH2) to run MPI apps.
Jayesh
_____
Sent: Tuesday, May 06, 2008 2:00 AM
To: Jayesh Krishna
Subject: Re: [mpich-discuss] Error with MPI - set PATH
Hi Jayesh,
I have installed both MPICH and MPICH2. When I compile using MPICH (with
PETSc), I can run my code successfully with 2 processes with mpirun:
Process 0 of 2 is alive
Enter the number of intervals: (0 quits)
Process 1 of 2 is alive
However, if I use mpiexec from MPICH2, I will get the error:
Process 0 of 1 is alive
Similarly, if I compile using MPICH2 and execute using mpirun, I will get
the same error.
Does it mean that I must use MPICH with mpirun and MPICH2 with mpiexec
strictly?
Or is there something wrong with my code/installation?
Thank you.
Regards
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080506/481c8463/attachment.htm>
