[mpich-discuss] Profiling configuration file mpe_mpilog.conf
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Sat May  3 02:25:52 CDT 2008
I think I figured it out. Its working now. Thanks.
On Sat, May 3, 2008 at 2:42 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> ----- "Krishna Chaitanya" <kris.c1986 at gmail.com> wrote:
> > Hi,
> > I have made a few changes in the MPI source code and added a few lines
> > of code into the MPE module. To compile the cpi program in the
> > examples directory, I have added the -mpe=mpilog switch in the
> > makefile. It was working well until it started reporting this error :
> > ../bin/mpicc -g -O2 -mpe=mpilog -L../lib -o cpi cpi.o -lm -lmpich
> > -lpthread -lrt
> Assuming the mpicc that you invoked is in the mpich2 install directory,
> you don't need "-L../lib" and "-lmpich ...." which are already done
> in mpicc.
> > Profiling configuration file mpe_mpilog.conf not found in
> > /home/mpich-install/etc
> Is there a mpe_mpilog.conf in /home/mpich-install/etc ?
> If not, your installation of MPE2 is broken.
> > This is followed by a few undefined references to the function that I
> > have added in the MPE module. I checked the messages displayed during
> > make and I noticed that the libmpe.a library was created successfully
> > at src/mpe2/lib. What could be the problem?
> Send us your configure, make and "make install" output as shown on
> your screen.
> A.Chan
> > Thanks,
> > Krishna Chaitanya,
> > In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080503/195ae722/attachment.htm>
