[mpich-discuss] multiple mpich2 jobs on a single node
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu May  1 17:00:54 CDT 2008
Try doing this. For one job,
setenv MPD_CON_EXT job1
mpdboot
mpirun -np 4 ./a.out
For the other one,
setenv MPD_CON_EXT job2
mpdboot
mpirun -np 4 ./a.out2
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Bryan Putnam
> Sent: Thursday, May 01, 2008 1:23 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: RE: [mpich-discuss] multiple mpich2 jobs on a single node
> On Thu, 1 May 2008, Rajeev Thakur wrote:
> > In a PBS environment, you need not use MPD at all. You can
> simply use the
> > mpiexec written by Pete Wyckoff:
> http://www.osc.edu/~pw/mpiexec/index.php
> Hi Rajeev,
> Yes we used to use that program when we used OpenPBS, but it
> doesn't work
> with the latest PBSPro.
> Bryan
> > Rajeev
> > > Sent: Thursday, May 01, 2008 12:40 PM
> > > > Can you try running them with a single mpdboot?
> > > > Rajeev
> > > Rajeev,
> > > Yes, it does work correctly when I use only one mpdboot as
> > > you describe.
> > > However, this is within a PBS environment, and the user
> doesn't know
> > > whether or not the daemon is already running.
> > > Bryan
> Bryan Putnam
> > > > > Sent: Thursday, May 01, 2008 7:52 AM
> > > > > Subject: [mpich-discuss] multiple mpich2 jobs on a single node
> > > > > Hi, perhaps this is an FAQ, but I can't seem to find it.
> > > > > I've noticed that if I have two mpich2 jobs running on for
> > > > > example, the same 8-processor node, submitted as
> > > > > mpdboot
> > > > > mpdboot
> > > > > then when one of the jobs completes, it kills all the mpd
> > > > > processes along
> > > > > with it, and the remaining job dies with message
> > > > > job aborted; reason = mpd disappeared
> > > > > Is there an easy fix for this?
> > > > > Thanks,
> > > > > Bryan
> > > > > Bryan Putnam
> > > > > Rosen Center for Advanced Computing, Purdue University
> > > > > Young Hall (Rm. 519)
> > > > > 302 Wood Street
> > > > > West Lafayette, IN 47907-2108
> > > > > Ph 765-496-8225 Fax 765-494-0566
> > > > > bfp at purdue.edu
> > > > > http://www.purdue.edu/itap
