[mpich-discuss] multiple mpich2 jobs on a single node
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu May  1 12:44:09 CDT 2008
In a PBS environment, you need not use MPD at all. You can simply use the
mpiexec written by Pete Wyckoff: http://www.osc.edu/~pw/mpiexec/index.php
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Bryan Putnam
> Sent: Thursday, May 01, 2008 12:40 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: RE: [mpich-discuss] multiple mpich2 jobs on a single node
> On Thu, 1 May 2008, Rajeev Thakur wrote:
> > Can you try running them with a single mpdboot?
> > Rajeev
> Rajeev,
> Yes, it does work correctly when I use only one mpdboot as
> you describe.
> However, this is within a PBS environment, and the user doesn't know
> whether or not the daemon is already running.
> Bryan
> > > Sent: Thursday, May 01, 2008 7:52 AM
> > > Subject: [mpich-discuss] multiple mpich2 jobs on a single node
> > > Hi, perhaps this is an FAQ, but I can't seem to find it.
> > > I've noticed that if I have two mpich2 jobs running on for
> > > example, the same 8-processor node, submitted as
> > > mpdboot
> > > mpirun -np 4 ./a.out
> > > mpdboot
> > > mpirun -np 4 ./a.out2
> > > then when one of the jobs completes, it kills all the mpd
> > > processes along
> > > with it, and the remaining job dies with message
> > > job aborted; reason = mpd disappeared
> > > Is there an easy fix for this?
> > > Thanks,
> > > Bryan
> > > Bryan Putnam
> > > Rosen Center for Advanced Computing, Purdue University
> > > Young Hall (Rm. 519)
> > > 302 Wood Street
> > > West Lafayette, IN 47907-2108
> > > Ph 765-496-8225 Fax 765-494-0566
> > > bfp at purdue.edu
> > > http://www.purdue.edu/itap
