[mpich-discuss] Scalability of Intel quad core (Harpertown) cluster
Hee Il Kim heeilkim at gmail.com
Fri Mar 28 00:50:55 CDT 2008
I recently made a Rocks cluster of 10 comuting nodes with dual Intel quad
core cpus (Harpertown). The nodes are connected with gigabit networks.
The problem is I got bad scalability from the benchmark test of Cactus which
is well-known program for numerical relativity. It might be natural with the
gigabit network. However, I suspect I missed something important or it's a
generic problem of clusters of multicore cpus because the benchmark problems
does not require massive communication between the computing nodes.
I tested openmpi, mpich as well as mpich2 but no significant differences
between openmpi and mpich2. The mpich2 was configured with ssm. After
reading some documents on nemesis and multicore cpus, I tested with nemesis
but got worse results than with ssm.
- Is there any optimized configuration option for multicore cpus like
Harpertown?
- Could it be improved only with infiniband, myrinet,...?
- If the gigabit network was the cause, could it be improved with Open-MX?
I'm a newbie on this field. The questions must be not clear to you. I
appreciate any helps in advance.
Kim, Hee Il
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080328/270cb523/attachment.htm>
