[mpich-discuss] exit code -1073741819
    trymelz trymelz
    trymelz at yahoo.com
    Tue Mar 25 12:56:52 CDT 2008
For fmpich2s.lib, the following tesings crash:
calling convention = STDCALL (iface:stdcall)
name case interpretation = Upper Case
String length argument passing = after individual string argument
(crash for both integer and characters)
calling convention = STDCALL, REFERENCE (iface:stdrefl)
(crash for characters)
calling convention = CVF(iface:cvf)
String length argument passing = after all arguments
The following testings run though:
Testing examples\fpi will not show the crashes due to recv/recv characters because it only send/recv integer and reals.
Linfa
----- Original Message ----
To: trymelz trymelz <trymelz at yahoo.com>
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, March 25, 2008 10:36:56 AM
Subject: RE: [mpich-discuss] exit code -1073741819
 Nope... If you would like to use fmpich2s.lib you should follow the settings mentioned in my previous email.
 I would suggest you to try the fortran example (examples\fpi.*) with the different fortran libs. Let us know if it does not work for you.
 And by the way MPICH2 1.0.7rc2 is out. You might want to try it (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
Jayesh
From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of trymelz trymelz
Sent: Tuesday, March 25, 2008 10:23 AM
Subject: Re: [mpich-discuss] exit code -1073741819
I assume you meant
fmpich2s.lib
String length argument passing = "after all arguments"
Sent: Friday, March 21, 2008 10:10:27 AM
The different fortran libraries provided with MPICH2 are tuned to the "default" settings of different compilers. If you are using Intel Visual fortran compiler the default settings of the compiler would work with fmpich2.lib. If you would like to use fmpich2.lib/fmpich2s.lib using the Intel Visual fortran compiler please use the settings below,
fmpich2.lib
calling convention = default
name case interpretation = default
string length argument passing = after all arguments
fmpich2s.lib
Jayesh
From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Friday, March 21, 2008 9:25 AM
To: 'trymelz trymelz'
 MPI_SEND() in fortran takes 7 arguments. The 8th argument is to handle the fortran CHARACTER arrays.
Jayesh
Sent: Thursday, March 20, 2008 6:16 PM
I did not see MPI_SEND taking 8 arguments, how come it generates MPI_SEND at 32 ?
Linfa
Sent: Thursday, March 20, 2008 3:44:25 PM
 The fortran bindings for MPI funcs is in src/binding/f77 (Note that these source files are generated by scripts).
Jayesh
Sent: Thursday, March 20, 2008 3:38 PM
By specifying character length as 11, the program behaviors the same as 15 since the order of arguments is messed up.
Do you know where is the protype or definition in the source code of MPI_SEND/RECV?  Thanks.
Linfa
Cc: Jayesh Krishna <jayesh at mcs.anl.gov>
Sent: Thursday, March 20, 2008 2:33:51 PM
What happens if you specify character length as 11 instead of 15 in
your MPI_Sned and MPI_Recv ?
On Thu, 20 Mar 2008, trymelz trymelz wrote:
> Hi,
> Sure. After changing the calling convention to default in Intel Compiler, I successfully linked with fmpich2.lib. But again, it runs fine when the string length is passed at the end of argument list, and it crashes when the string length is passed after the string pointer.
> Probably, more MPICH2 FORTRAN libraries are needed to be provided.
> Linfa
> From: Jayesh Krishna <jayesh at mcs.anl.gov>
> Sent: Thursday, March 20, 2008 2:08:46 PM
> Hi,
> Can you also try compiling your program with fmpich2.lib ?
> Regards,
> Jayesh
> From: trymelz trymelz [mailto:trymelz at yahoo.com]
> Sent: Thursday, March 20, 2008 2:06 PM
> To: Jayesh Krishna; mpich-discuss at mcs.anl.gov
> Hi
> I have no problem to compile & run the sample fpi.f using fmpich2s.lib. Actually, I have identified the culprit: MPI_SEND/RECV work find with integer, but have problem with string.
> The main reason I beleive is that, in Fortran, different compiler treats the string arguments differently: either add the string length as a invisible argument immediately after the string pointer, or the string lengh is added as a invisible arguments at the end of arguments list. So in my understanding MPI_SEND/RECV will have 28 byte of arguments for integer, but 32 byte of arguments for string because the invisible string length argument.
> It will cause crash if the positions of the invisible string length arguments are different in the .obj file and in fmpich2s.lib. The following program dimenstrate this
> program main
> implicit none
> #include <mpif.h>
> integer status(MPI_STATUS_SIZE)
> character * 15 pcomand
> integer MYID,mpimodbg,ierr
> ierr=MPI_SUCCESS
> call MPI_INIT(ierr)
> call MPI_COMM_RANK( MPI_COMM_WORLD, MYID, ierr )
> if(MYID .eq. 1)then
> mpimodbg=99
> pcomand='hello world'
> call MPI_SEND(mpimodbg,1,MPI_INTEGER,0
> * ,11,MPI_COMM_WORLD,ierr)
> write(*,*)'node',MYID,pcomand,mpimodbg
> call MPI_SEND(pcomand,15,MPI_CHARACTER,0
> elseif(MYID.eq.0)then
> mpimodbg=0
> pcomand='hello'
> call MPI_RECV(mpimodbg,1,MPI_INTEGER,1
> * ,11,MPI_COMM_WORLD,status,ierr)
> call MPI_RECV(pcomand,15,MPI_CHARACTER,1
> endif
> call MPI_FINALIZE(ierr)
> end
> When compiled with the string length as a invisible argument immediately after the string pointer (by default in Intel Compiler):
> $ "/cygdrive/c/Program Files/MPICH2/bin/mpiexec.exe" -n 3 ./Debug/fortestargs.exe
> node          0 hello                    99
> node          1 hello world              99
> forrtl: severe (157): Program Exception - access violation
> Image              PC        Routine            Line        Source
> fmpich2s.dll      1000507F  Unknown              Unknown  Unknown
> fortestargs.exe    004A783D  Unknown              Unknown  Unknown
> fortestargs.exe    0044AA53  Unknown              Unknown  Unknown
> fortestargs.exe    0044A81D  Unknown              Unknown  Unknown
> kernel32.dll      7C816FD7  Unknown              Unknown  Unknown
> fmpich2s.dll      1000492B  Unknown              Unknown  Unknown
> job aborted:
> rank: node: exit code[: error message]
> 0: abyss: 157: process 0 exited without calling finalize
> 1: abyss: 157: process 1 exited without calling finalize
> 2: abyss: 123
> When compiled with the string length as a invisible argument at the end of arguments list:
> node          0 hello                    99
> node          0 hello world              99
> Thanks all  for your help.
> Linfa
> Sent: Thursday, March 20, 2008 9:15:21 AM
> Hi,
>    Can you compile & run the sample fpi.f (provided in MPICH2\examples in your installation dir) using fmpich2s.lib ?
> Regards,
> Jayesh
> Sent: Wednesday, March 19, 2008 6:30 PM
> Hi
> The MPI program is too big to be sent. Here is what I got from the debugger
> Before calling PMPI_ISEND:
> Symbol Value Type
>  buf(1) 3 INTEGER(4)
>  cnt 1 INTEGER(4)
>  datatype 1275069467 INTEGER(4)
>  dest 0 INTEGER(4)
>  tag 24 INTEGER(4)
>  comm 1140850688 INTEGER(4)
>  reqs(1) 1243468 INTEGER(4)
>  ierr 0 INTEGER(4)
> call PMPI_ISEND(buf,cnt,datatype,dest,tag,comm,reqs(1),ierr)
> Unhandled exception at 0x003b41c9 in EXEC.exe:0xC0000005:
> Access violation writing location 0x00000000
> After the break at the crash, all the arguments becomes "undefined address".
> When I check the library, I got
> $ nm fmpich2s.lib | grep MPI_SEND@
> 00000000 T _MPI_SEND at 28
> 00000000 I __imp__MPI_SEND at 28
> 00000000 T _MPI_SEND at 32
> 00000000 I __imp__MPI_SEND at 32
> 00000000 T _PMPI_SEND at 28
> 00000000 I __imp__PMPI_SEND at 28
> 00000000 T _PMPI_SEND at 32
> 00000000 I __imp__PMPI_SEND at 32
> I am wondering why there are two definitions:  _MPI_SEND at 28 and _MPI_SEND at 32.  And I could not find corresponding source code for _MPI_SEND at 32. Any comments? Thanks.
> Linfa
> Sent: Wednesday, March 19, 2008 2:32:59 PM
> Hi,
> Can you send us your MPI program ?
> You can also try to debug your program by setting the error handler to MPI_ERRORS_RETURN (MPI_Comm_set_errhandler() ) & using MPI_Error_string() to get the description of the error code.
> Regards,
> Jayesh
> Sent: Wednesday, March 19, 2008 2:11 PM
> Subject: [mpich-discuss] exit code -1073741819
> Hi all,
> I got an strange error when I run my parallel program.
> job aborted:
> 0: abyss: -1073741819: process 0 exited without calling finalize
> 1: abyss: -1073741819: process 1 exited without calling finalize
> 2: abyss: -1073741819: process 2 exited without calling finalize
> My program works as expected under Linux. But when I porting it to windows I got above error. It is compiled by VC8 and Intel FORTRAN 10.0.
> I didn't built my own MPICH2, but link my program with fmpich2s.lib and mpi.lib which were installed from mpich2-1.0.6p1-win32-ia32.msi.
> This error happened inside the call to MPI_SEND. Does anyone have an idea about this error?
> Linfa
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
> Looking for last minute shopping deals? Find them fast with Yahoo! Search.
>      ____________________________________________________________________________________
> Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Never miss a thing. Make Yahoo your homepage.
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080325/66542f76/attachment.htm>
