[mpich-discuss] problem with mpdboot and LDAP
    daniel.a.lauer at cummins.com
    Tue Mar 25 10:09:01 CDT 2008
Since we switched from NIS to LDAP for authentication, I've been having
trouble with LDAP accounts trying to start an mpd ring with mpdboot, I
always get invalid port info errors:
mpdboot -n 2 -f mpd.hosts
mpdboot_xxxxxxxx (handle_mpd_output 388): from mpd on xxxxxxxxxy, invalid
port info:
stty: standard input: Invalid argument
55277
I can manually setup a mpd ring as described in Troubleshooting MPDs in
the appendix and I can setup an mpd ring using a non-LDAP user (root and a
testuser).  I've got ssh public/private authentication setup for
passwordless authentication so I'm not sure what happened with the switch
to LDAP that might have caused a problem.
This is mpich2 v1.0.5p4 so I'm going to install the latest and try again
but has anyone seen anything similar?
thanks in advance,
Dan Lauer
Sr. Unix Admin
Cummins Business Services
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080325/5ace3ea3/attachment.htm>
