[mpich-discuss] [MPICH] Compiling a program (john-mpi MPICH2) under cygwin / WinXP - Correct formatting of sample makefile
    madfran
    madfran at set-ezine.org
    Sat Mar  8 11:38:41 CST 2008
Hi,...
Sorry. You are thrue.
Was a mistake in my makefile.
Attached the correct sintax.
../run/john.exe: $(JOHN_OBJS)
	$(LD) $(JOHN_OBJS) -lkernel32 $(LDFLAGS) -o ../run/john.exe
	strip ../run/john.exe
Thanks.
On Mon, 3 Mar 2008 18:24:16 -0400, madfran wrote
> Hi,...
> I follow all your advice (I think), but without succes.
> Any other idea?
> >Hi,
> >I am also providing you a sample makefile+source for an MPI helloworld
> >program which will help you modify your makefile accordingly.
> >As Darius mentioned in his previous mail the correct ordering of the
> >object files is necessary for linking your program. In the example below
> >main.c calls a function in hello.c (So main.o is specified before hello.o
in
> >$(OBJS)). Please notice that the libraries are provided in the linking
stage
> >($(CC) -o) and the order of $(OBJS) to make the program compile+link
> >correctly. Also note the position of the LFLAGS containing the libs.
> >########### makefile #############
> >CC = gcc
> >CFLAGS = -Wall -O3 -fomit-frame-pointer
> >-I/cygdrive/c/Progra~1/MPICH2/include
> >LFLAGS = -L/cygdrive/c/Progra~1/MPICH2/lib -lmpi
> >OBJS = main.o hello.o
> >helloworld: $(OBJS)
> >$(CC) -o helloworld $(OBJS) $(LFLAGS)
> >main.o: main.c
> >$(CC) $(CFLAGS) -c main.c
> >hello.o: hello.c
> >$(CC) $(CFLAGS) -c hello.c
> >clean:
> >rm -f helloworld.exe $(OBJS)
> >############ main.c ##############
> >#include <stdio.h>
> >#undef SEEK_SET
> >#undef SEEK_CUR
> >#undef SEEK_END
> >#include <mpi.h>
> >int main(int argc, char *argv[]){
> >MPI_Init(&argc, &argv);
> >helloworld();
> >MPI_Finalize();
> >############ hello.c ##############
> >#include <stdio.h>
> >#undef SEEK_SET
> >#undef SEEK_CUR
> >#undef SEEK_END
> >#include <mpi.h>
> >int helloworld(void ){
> >int rank;
> >MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> >printf("[%d] hello world\n", rank);
> >Type make in the command line to compile+link the program.
> >Hope this helps...
> >Regards,
> >Jayesh
> ********************OUTPUT OF MAKE*************************************
> $ make clean win32-cygwin-x86-sse2 2>&1 | tee output20.txt
> rm -
> f ../run/john ../run/unshadow ../run/unafs ../run/unique
> ../run/undrop ../run/ john.bin ../run/john.com ../run/unshadow.com
> ../run/unafs.com ../run/unique.co m ../run/undrop.com
> ../run/john.exe ../run/unshadow.exe ../run/unafs.exe ../ru
> n/unique.exe ../run/undrop.exe rm -f ../run/john.exe *.o *.bak core
> rm -f detect bench generic.h arch.h sparc.h tmp.s rm -f DES_bs_s.c
> DES_bs_n.c DES_bs_a.c cp /dev/null Makefile.dep cp x86-sse.h arch.h
> make ../run/john.exe ../run/unshadow.exe ../run/unafs.exe
> ../run/unique.exe .. /run/undrop.exe \ 		JOHN_OBJS="john.o
misc.o
> options.o signals.o bench.o DES_fmt.o DES_std.o DES_bs.o BSDI_fmt.o
> MD5_fmt.o MD5_std.o BF_fmt.o BF_std.o AFS_fmt.o LM_fmt.o des.o
> MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o NSLDAP_fmt.o
> NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o IPB2_fmt.o NT_fmt.o md4.o
> smbencrypt.o rawMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o hmacMD5_fmt.o
> WPAPSK_fmt.o mscash_fmt.o oracle_fmt.o batch.o charset.o common.o
> compiler.o config.o cracker.o crc32.o external.o formats.o getopt.o
> idle.o inc.o list.o loader.o logger.o math.o memory.o params.o
> path.o recovery.o rpp.o rules.o single.o status.o tty.o wordlist.o
> unshadow.o ryan.o unafs.o undrop.o unique.o  DES_bs_b.o x86.o x86-
> sse.o md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1- mmx.o" \
	ASFLAGS="-c -
> DUNDERSCORES" make[1]: Entering directory `/tmp/john-mpi/john-1.7.2-
> bp17-mpi7/src' gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops john.c gcc -c -
> Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include -
>  funroll-loops misc.c gcc -c -Wall -O3 -fomit-frame-pointer -
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops options.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops signals.c
> signals.c: In function `sig_handle_status': signals.c:102: warning:
> unused variable `saved_errno' signals.c: At top level: signals.c:92:
> warning: 'sig_handle_update' defined but not used gcc -c -Wall -O3
> -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include - funroll-
> loops bench.c gcc -c -Wall -O3 -fomit-frame-pointer -
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops DES_fmt.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops DES_std.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops DES_bs.c gcc -c
> -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include
> - funroll-loops BSDI_fmt.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops MD5_fmt.c gcc -
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops MD5_std.c
> MD5_std.c:27: warning: alignment of 'MD5_std_all' is greater than
> maximum object file alignment.  Using 16 gcc -c -Wall -O3 -fomit-
> frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops BF_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops BF_std.c
> BF_std.c:53: warning: alignment of 'BF_exp_key' is greater than
> maximum object file alignment.  Using 16 BF_std.c:57: warning:
> alignment of 'BF_init_key' is greater than maximum object file
> alignment.  Using 16 gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops AFS_fmt.c gcc -
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops LM_fmt.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops des.c gcc -c -
>  funroll-loops MD5_apache_fmt.c gcc -c -Wall -O3 -fomit-frame-
> pointer -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops BFEgg_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops lotus5_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops md5.c gcc -c -
>  funroll-loops NSLDAP_fmt.c NSLDAP_fmt.c:63: warning: alignment of
> 'buffer' is greater than maximum object file alignment.  Using 16
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops NSLDAPS_fmt.c
> NSLDAPS_fmt.c: In function `crypt_all': NSLDAPS_fmt.c:231: warning:
> suggest parentheses around + or - in operand of & NSLDAPS_fmt.c: At
> top level: NSLDAPS_fmt.c:62: warning: alignment of 'buffer' is
> greater than maximum object file alignment.  Using 16 gcc -c -Wall
> funroll-loops sha1.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops base64.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops MYSQL_fmt.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops IPB2_fmt.c gcc -
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops NT_fmt.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops md4.c gcc -c -
>  funroll-loops smbencrypt.c gcc -c -Wall -O3 -fomit-frame-pointer -
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops rawMD5_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops rawSHA1_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops mssql_fmt.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops hmacMD5_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops WPAPSK_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops mscash_fmt.c
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops oracle_fmt.c
> oracle_fmt.c:234: warning: initialization from incompatible pointer type
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops batch.c gcc -c -
>  funroll-loops charset.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops common.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops compiler.c gcc -
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops config.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops cracker.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops crc32.c gcc -c -
>  funroll-loops external.c gcc -c -Wall -O3 -fomit-frame-pointer -
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops formats.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops getopt.c gcc -c
> - funroll-loops idle.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops inc.c gcc -c
> - funroll-loops list.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops loader.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops logger.c gcc -c
> - funroll-loops math.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops memory.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops params.c gcc -c
> - funroll-loops path.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops recovery.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops rpp.c gcc -c -
>  funroll-loops rules.c gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops single.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops status.c gcc -c
> - funroll-loops tty.c gcc -c -Wall -O3 -fomit-frame-pointer -
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops wordlist.c gcc -
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops unshadow.c gcc
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops ryan.c gcc -c
> - funroll-loops unafs.c gcc -c -Wall -O3 -fomit-frame-pointer -
> I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops undrop.c gcc -c
> - funroll-loops unique.c sed "s/unsigned long/ARCH_WORD/" sboxes.c >
> DES_bs_s.c sed "s/unsigned long/ARCH_WORD/" nonstd.c > DES_bs_n.c
> I/cygdrive/c/Progra~1/MPICH2/include - finline-functions DES_bs_b.c
> gcc -c -DUNDERSCORES x86.S gcc -c -DUNDERSCORES x86-sse.S gcc -c
> -DUNDERSCORES md4-sse2.S gcc -c -Wall -O3 -fomit-frame-pointer
> -I/cygdrive/c/Progra~1/MPICH2/include - funroll-loops NTmmx_fmt.c
> NTmmx_fmt.c:63: warning: alignment of 'saved_plain' is greater than
> maximum object file alignment.  Using 16 NTmmx_fmt.c:65: warning:
> alignment of 'output' is greater than maximum object file alignment.
>  Using 16 gcc -c -DUNDERSCORES md5-mmx.S gcc -c -DUNDERSCORES sha1-mmx.S
> gcc john.o misc.o options.o signals.o bench.o DES_fmt.o DES_std.o
> DES_bs.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.o AFS_fmt.o
> LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o
> NSLDAP_fmt.o NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o IPB2_fmt.o
> NT_fmt.o md4.o smbencrypt.o rawMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o
> hmacMD5_fmt.o WPAPSK_fmt.o mscash_fmt.o oracle_fmt.o batch.o
> charset.o common.o compiler.o config.o cracker.o crc32.o external.o
> formats.o getopt.o idle.o inc.o list.o loader.o logger.o math.o
> memory.o params.o path.o recovery.o rpp.o rules.o single.o status.o
> tty.o wordlist.o unshadow.o ryan.o unafs.o undrop.o unique.o
>  DES_bs_b.o x86.o x86-sse.o md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-
> mmx.o - lkernel32 -o ../run/john.exe john.o:john.c:(.text+0x33):
> undefined reference to `_MPI_Init' john.o:john.c:(.text+0x43):
> undefined reference to `_MPI_Comm_rank' john.o:john.c:(.text+0x53):
> undefined reference to `_MPI_Comm_size' john.o:john.c:(.text+0x713):
> undefined reference to `_MPI_Finalize' john.o:john.c:(.text+0x751):
> undefined reference to `_MPI_Finalize' john.o:john.c:(.text+0x771):
> undefined reference to `_MPI_Finalize' john.o:john.c:(.text+0x921):
> undefined reference to `_MPI_Finalize' john.o:john.c:(.text+0xac2):
> undefined reference to `_MPI_Finalize' misc.o:misc.c:(.text+0x38):
> more undefined references to `_MPI_Finalize' follow
> bench.o:bench.c:(.text+0x930): undefined reference to `_MPI_Reduce'
> bench.o:bench.c:(.text+0x9a2): undefined reference to `_MPI_Reduce'
> bench.o:bench.c:(.text+0xa3c): undefined reference to `_MPI_Reduce'
> bench.o:bench.c:(.text+0xab4): undefined reference to `_MPI_Reduce'
> collect2: ld returned 1 exit status make[1]: *** [../run/john.exe]
> Error 1 make[1]: Leaving directory `/tmp/john-mpi/john-1.7.2-bp17-mpi7/src'
> make: *** [win32-cygwin-x86-sse2] Error 2
> ************************MAKEFILE*************************************
> # This file is part of John the Ripper password cracker,
> # Copyright (c) 1996-2006 by Solar Designer
> # 15.02.2008 Elli0t: enabled linking on cygwin; some cleanup
> # 03.03.2008 Adapted to MPICH2 under WinXP
> CPP = gcc
> CC = gcc
> AS = gcc
> LD = gcc
> CP = cp
> LN = ln -sf
> RM = rm -f
> TR = tr
> SED = sed
> PERL = perl
> NULL = /dev/null
> CPPFLAGS = -E
> CFLAGS = -c -Wall -O3 -fomit-frame-pointer -
> ASFLAGS = -c
> LDFLAGS = -s -lm -L/cygdrive/c/Progra~1/MPICH2/lib -lmpicxx -
> lfmpich2 -lmpi OPT_NORMAL = -funroll-loops OPT_INLINE = -finline-functions
> JOHN_OBJS_MINIMAL = \
> 	john.o \
> 	misc.o \
> 	options.o \
> 	signals.o \
> 	bench.o \
> 	DES_fmt.o DES_std.o DES_bs.o \
> 	BSDI_fmt.o \
> 	MD5_fmt.o MD5_std.o \
> 	BF_fmt.o BF_std.o \
> 	AFS_fmt.o \
> 	LM_fmt.o \
> 	des.o \
> 	MD5_apache_fmt.o \
> 	BFEgg_fmt.o \
> 	lotus5_fmt.o \
> 	md5.o \
> 	NSLDAP_fmt.o NSLDAPS_fmt.o sha1.o base64.o \
> 	MYSQL_fmt.o \
> 	IPB2_fmt.o \
> 	NT_fmt.o \
> 	md4.o smbencrypt.o \
> 	rawMD5_fmt.o \
> 	rawSHA1_fmt.o \
> 	mssql_fmt.o \
> 	hmacMD5_fmt.o \
> 	WPAPSK_fmt.o \
> 	mscash_fmt.o \
> 	oracle_fmt.o \
> 	batch.o charset.o common.o compiler.o config.o cracker.o \
> 	crc32.o external.o formats.o getopt.o idle.o inc.o list.o \
> 	loader.o logger.o math.o memory.o params.o path.o \
> 	recovery.o rpp.o rules.o single.o status.o tty.o wordlist.o \
> 	unshadow.o ryan.o \
> 	unafs.o \
> 	undrop.o \
> 	unique.o
> JOHN_OBJS_ORIG = \
> 	$(JOHN_OBJS_MINIMAL) DES_bs_b.o
> JOHN_OBJS = \
> 	$(JOHN_OBJS_ORIG)
> BENCH_DES_OBJS_ORIG = \
> 	DES_fmt.o DES_std.o
> BENCH_DES_OBJS_DEPEND = \
> 	$(BENCH_DES_OBJS_ORIG)
> BENCH_DES_BS_OBJS_DEPEND = \
> 	DES_bs_b.o
> BENCH_MD5_OBJS_DEPEND = \
> 	MD5_fmt.o MD5_std.o
> BENCH_BF_OBJS_DEPEND = \
> 	BF_std.o
> BENCH_OBJS = \
> 	$(BENCH_DES_OBJS_DEPEND) \
> 	DES_bs.o $(BENCH_DES_BS_OBJS_DEPEND) \
> 	$(BENCH_MD5_OBJS_DEPEND) \
> 	BF_fmt.o $(BENCH_BF_OBJS_DEPEND) \
> 	bench.o best.o common.o config.o formats.o math.o memory.o miscnl.o
> \ 	params.o path.o signals.o tty.o
> PROJ = ../run/john ../run/unshadow ../run/unafs ../run/unique ../run/undrop
> PROJ_DOS = ../run/john.bin ../run/john.com \
> 	../run/unshadow.com ../run/unafs.com ../run/unique.com ../run/undrop.c
> om
> PROJ_WIN32 = ../run/john.exe \
> 	../run/unshadow.exe ../run/unafs.exe ../run/unique.exe ../run/undrop.e
> xe
> default:
> 	@echo "To build John the Ripper, type:"
> 	@echo "	make clean SYSTEM"
> 	@echo "where SYSTEM can be one of the following:"
> 	@echo "linux-x86-mmx            Linux, x86 with MMX"
> 	@echo "linux-x86-sse2           Linux, x86 with SSE2 (best)"
> 	@echo "linux-x86-any            Linux, x86"
> 	@echo "linux-x86-64             Linux, AMD x86-64, 64-bit native
> w/SSE2 (best)"
> 	@echo "linux-x86-64-mmx         Linux, AMD x86-64, 32-bit with MMX"
> 	@echo "linux-alpha              Linux, Alpha"
> 	@echo "linux-sparc              Linux, SPARC 32-bit"
> 	@echo "linux-ppc32-altivec      Linux, PowerPC w/AltiVec (best)"
> 	@echo "linux-ppc32              Linux, PowerPC 32-bit"
> 	@echo "linux-ppc64-altivec      Linux, PowerPC 64-bit w/AltiVec
> (best)"
> 	@echo "linux-ppc64              Linux, PowerPC 64-bit"
> 	@echo "freebsd-x86-mmx          FreeBSD, x86 with MMX (best)"
> 	@echo "freebsd-x86-any          FreeBSD, x86"
> 	@echo "freebsd-alpha            FreeBSD, Alpha"
> 	@echo "openbsd-x86-mmx          OpenBSD, x86 with MMX (best)"
> 	@echo "openbsd-x86-any          OpenBSD, x86"
> 	@echo "openbsd-x86-64           OpenBSD, AMD x86-64"
> 	@echo "openbsd-alpha            OpenBSD, Alpha"
> 	@echo "openbsd-sparc64          OpenBSD, SPARC 64-bit (best)"
> 	@echo "openbsd-sparc            OpenBSD, SPARC 32-bit"
> 	@echo "openbsd-ppc32            OpenBSD, PowerPC 32-bit"
> 	@echo "openbsd-ppc64            OpenBSD, PowerPC 64-bit"
> 	@echo "openbsd-pa-risc          OpenBSD, PA-RISC"
> 	@echo "openbsd-vax              OpenBSD, VAX"
> 	@echo "netbsd-vax               NetBSD, VAX"
> 	@echo "solaris-sparc64-cc       Solaris, SPARC V9 64-bit, cc (best)"
> 	@echo "solaris-sparc64-mpicc      Solaris, SPARC V9 64-bit, mpicc"
> 	@echo "solaris-sparcv9-cc       Solaris, SPARC V9 32-bit, cc"
> 	@echo "solaris-sparcv8-cc       Solaris, SPARC V8 32-bit, cc"
> 	@echo "solaris-sparc-mpicc        Solaris, SPARC 32-bit, mpicc"
> 	@echo "solaris-x86-any          Solaris, x86, mpicc"
> 	@echo "sco-x86-any-mpicc          SCO, x86, mpicc"
> 	@echo "sco-x86-any-cc           SCO, x86, cc"
> 	@echo "tru64-alpha              Tru64 (Digital UNIX, OSF/1), Alpha"
> 	@echo "aix-ppc32                AIX, PowerPC 32-bit"
> 	@echo "macosx-ppc32-altivec     Mac OS X, PowerPC w/AltiVec (best)"
> 	@echo "macosx-ppc32             Mac OS X, PowerPC 32-bit"
> 	@echo "macosx-ppc64-altivec     Mac OS X 10.4+, PowerPC 64-bit
> w/AltiVec"
> 	@echo "macosx-ppc64             Mac OS X 10.4+, PowerPC 64-bit"
> 	@echo "macosx-x86-sse2          Mac OS X, x86 with SSE2"
> 	@echo "hpux-pa-risc-mpicc         HP-UX, PA-RISC, mpicc"
> 	@echo "hpux-pa-risc-cc          HP-UX, PA-RISC, ANSI cc"
> 	@echo "irix-mips64-r10k         IRIX, MIPS 64-bit (R10K) (best)"
> 	@echo "irix-mips64              IRIX, MIPS 64-bit"
> 	@echo "irix-mips32              IRIX, MIPS 32-bit"
> 	@echo "dos-djgpp-x86-mmx        DOS, DJGPP 2.x, x86 with MMX (best)"
> 	@echo "dos-djgpp-x86-any        DOS, DJGPP 2.x, x86"
> 	@echo "win32-cygwin-x86-mmx     Win32, Cygwin, x86 with MMX (best)"
> 	@echo "win32-cygwin-x86-sse2    Win32, Cygwin, x86 with SSE2"
> 	@echo "win32-cygwin-x86-any     Win32, Cygwin, x86"
> 	@echo "beos-x86-mmx             BeOS, x86 with MMX"
> 	@echo "beos-x86-any             BeOS, x86"
> 	@echo "beos-x86-sse2            BeOS, x86 with SSE2 (best)"
> 	@echo "generic                  Any other Unix-like system with mpicc"
> linux-x86-mmx:
> 	$(LN) x86-mmx.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-mmx.o md4-mmx.o
> NTmmx_fmt.o md5-mmx.o sha1-mmx.o"
> linux-x86-sse2:
> 	$(LN) x86-sse.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-sse.o md4-sse2.o
> linux-x86-any:
> 	$(LN) x86-any.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) x86.o"
> linux-x86-any-a.out:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) x86.o" \
> 		ASFLAGS="$(ASFLAGS) -DUNDERSCORES -DALIGN_LOG"
> linux-x86-64:
> 	$(LN) x86-64.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86-64.o"
> linux-x86-64-32-sse2:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-sse.o sha1-mmx.o" \
> 		CFLAGS="$(CFLAGS) -m32" \
> 		ASFLAGS="$(ASFLAGS) -m32" \
> 		LDFLAGS="$(LDFLAGS) -m32"
> linux-x86-64-32-mmx:
> 	$(MAKE) $(PROJ) \
> NTmmx_fmt.o" \
> linux-alpha:
> 	$(LN) alpha.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) alpha.o"
> # This target is currently "undocumented" as ccc generates much slower
> # code for the large unrolled loops in John; let's hope it gets fixed.
> linux-alpha-ccc:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) alpha.o" \
> 		CPP=ccc CC=ccc AS=ccc LD=ccc \
> 		CFLAGS="-c -Wf,-switch,noil_schedule" \
> 		OPT_NORMAL="-fast" \
> 		OPT_INLINE="-O2 -arch host"
> linux-sparc:
> 	$(LN) sparc32.h arch.h
> 	$(MAKE) $(PROJ)
> linux-ppc32-altivec:
> 	$(LN) ppc32alt.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) ppc-alti-linux.o" \
> 		OPT_INLINE="-finline-functions -finline-limit=4000"
> linux-ppc32:
> 	$(LN) ppc32.h arch.h
> 	$(MAKE) $(PROJ)
> # This is slightly slower than linux-ppc32-altivec for most hash types.
> linux-ppc64-altivec:
> 	$(LN) ppc64alt.h arch.h
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="$(CFLAGS) -m64" \
> 		LDFLAGS="$(LDFLAGS) -m64" \
> linux-ppc64:
> 	$(LN) ppc64.h arch.h
> 	$(MAKE) $(PROJ) \
> ppc-alti-linux.o: ppc-alti.c DES_bs_a.c
> 	$(CC) $(CFLAGS) $(OPT_INLINE) -maltivec ppc-alti.c -o $@
> freebsd-x86-sse2:
> 	$(MAKE) $(PROJ) \
> 		ASFLAGS="$(ASFLAGS) -DBSD"
> freebsd-x86-mmx:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-mmx.o sha1-mmx.o" \
> freebsd-x86-any:
> 	$(MAKE) $(PROJ) \
> freebsd-x86-any-a.out:
> 	$(MAKE) $(PROJ) \
> 		ASFLAGS="$(ASFLAGS) -DUNDERSCORES -DALIGN_LOG -DBSD"
> freebsd-x86-64:
> 	$(MAKE) $(PROJ) \
> freebsd-alpha:
> 	$(MAKE) $(PROJ) \
> openbsd-x86-sse2:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS_MINIMAL) x86.o x86-sse.o" \
> openbsd-x86-mmx:
> 	$(MAKE) $(PROJ) \
> NTmmx_fmt.o" \
> openbsd-x86-any:
> 	$(MAKE) $(PROJ) \
> openbsd-x86-any-a.out:
> 	$(MAKE) $(PROJ) \
> openbsd-x86-64:
> 	$(MAKE) $(PROJ) \
> openbsd-alpha:
> 	$(MAKE) $(PROJ) \
> openbsd-sparc64:
> 	$(LN) sparc64.h arch.h
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="$(CFLAGS) -m64 -mcpu=ultrasparc" \
> openbsd-sparc:
> 	$(MAKE) use-openbsd-sparc HAMMER=use-openbsd-sparc NAIL=sparc.h
> 	$(LN) sparc.h arch.h
> 	$(MAKE) use-openbsd-sparc NAIL="$(PROJ)"
> use-openbsd-sparc:
> 	$(MAKE) $(NAIL) \
> 		BENCH_DES_OBJS_DEPEND="$(BENCH_DES_OBJS_ORIG) sparc.o" \
> 		JOHN_OBJS="$(JOHN_OBJS_ORIG) sparc.o" \
> 		ASFLAGS="-c -DBSD"
> openbsd-sparc-a.out:
> 	$(MAKE) use-openbsd-sparc-a.out \
> 		HAMMER=use-openbsd-sparc-a.out NAIL=sparc.h
> 	$(MAKE) use-openbsd-sparc-a.out NAIL="$(PROJ)"
> use-openbsd-sparc-a.out:
> 	$(MAKE) $(NAIL) \
> 		ASFLAGS="-c -DUNDERSCORES -DBSD"
> openbsd-ppc32:
> 	$(MAKE) $(PROJ)
> openbsd-ppc64:
> 	$(MAKE) $(PROJ) \
> openbsd-pa-risc:
> 	$(LN) pa-risc.h arch.h
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -Wall -O3 -fomit-frame-pointer"
> openbsd-vax:
> 	$(LN) vax.h arch.h
> 	$(MAKE) $(PROJ)
> netbsd-sparc64:
> 	$(MAKE) $(PROJ) \
> netbsd-vax:
> 	$(LN) vax.h arch.h
> 	$(MAKE) $(PROJ)
> solaris-sparc64-cc:
> 	$(MAKE) $(PROJ) \
> 		CPP=cc CC=cc AS=cc LD=cc \
> 		CFLAGS="-c -fast -xarch=native64" \
> 		LDFLAGS="-s -xarch=native64 -lc -lrt" \
> 		OPT_NORMAL="" \
> 		OPT_INLINE="-xinline=s1,s2,s3,s4,s5,s6,s7,s8"
> solaris-sparc64-mpicc:
> 	$(MAKE) $(PROJ) \
> 		LDFLAGS="$(LDFLAGS) -m64 -lrt"
> solaris-sparc-any:
> 	$(MAKE) $(HAMMER) NAIL=sparc.h
> 	$(RM) arch.h
> 	ln -s sparc.h arch.h
> 	$(MAKE) $(HAMMER) NAIL="$(PROJ)"
> solaris-sparcv9-cc:
> 	$(MAKE) solaris-sparc-any HAMMER=use-solaris-sparcv9-cc
> solaris-sparcv8-cc:
> 	$(MAKE) solaris-sparc-any HAMMER=use-solaris-sparcv8-cc
> solaris-sparc-mpicc:
> 	$(MAKE) solaris-sparc-any HAMMER=use-solaris-sparc-mpicc
> use-solaris-sparcv9-cc:
> 	$(MAKE) $(NAIL) \
> 		BENCH_DES_OBJS_DEPEND="$(BENCH_DES_OBJS_ORIG) spro-sparc.o" \
> 		JOHN_OBJS="$(JOHN_OBJS_ORIG) spro-sparc.o" \
> 		CFLAGS="-c -xO4 -xarch=v8plusa -xchip=ultra" \
> 		LDFLAGS="-s -lc -lrt" \
> 		OPT_NORMAL="" \
> use-solaris-sparcv8-cc:
> 	$(MAKE) $(NAIL) \
> 		CFLAGS="-c -xO4 -xarch=v8" \
> 		OPT_NORMAL="" \
> use-solaris-sparc-mpicc:
> 	$(MAKE) $(NAIL) \
> 		LDFLAGS="$(LDFLAGS) -lrt"
> sparc.h:
> 	$(RM) arch.h
> 	$(CC) $(CFLAGS) -DOS_TIMER -DOS_FLOCK -DDES_ASM detect.c
> 	$(LD) $(LDFLAGS) detect.o -o detect
> 	./sparc.sh "$(MAKE)" "$(HAMMER)" "$(BENCH_DES_OBJS_DEPEND)"
> # Older versions of spro cc didn't support .S files directly
> spro-sparc.o: sparc.S
> 	$(CPP) $(CPPFLAGS) sparc.S | $(SED) 's/% /%/g' > tmp.s
> 	$(AS) $(ASFLAGS) tmp.s -o spro-sparc.o
> 	$(RM) tmp.s
> solaris-x86-any:
> 	$(RM) arch.h
> 	ln -s x86-any.h arch.h
> 	$(MAKE) $(PROJ) \
> 		SHELL=/bin/sh \
> 		JOHN_OBJS="$(JOHN_OBJS) solaris-x86.o" \
> 		LDFLAGS="$(LDFLAGS) -lc -lrt"
> # Solaris x86 got a broken assembler, with line length restriction (and some
> # other problems, that are worked around in x86.S)
> solaris-x86.o: x86.S
> 	$(CPP) $(CPPFLAGS) -P -DDUMBAS x86.S | $(TR) \; \\n > tmp.s
> 	$(AS) $(ASFLAGS) tmp.s -o solaris-x86.o
> 	$(RM) tmp.s
> sco-x86-any-mpicc:
> 	$(RM) arch.h
> 	$(MAKE) $(PROJ) \
> 		SHELL=/bin/sh \
> 		JOHN_OBJS="$(JOHN_OBJS) sco-x86.o"
> sco-x86-any-cc:
> 	$(RM) arch.h
> 	$(MAKE) $(PROJ) \
> 		SHELL=/bin/sh \
> 		JOHN_OBJS="$(JOHN_OBJS) sco-x86.o" \
> 		CFLAGS="-c -b elf -O3" \
> 		ASFLAGS="-c -b elf" \
> 		OPT_NORMAL="-K loop_unroll,no_inline" \
> 		OPT_INLINE="-K inline"
> # SCO is even worse than Solaris x86
> sco-x86.o: x86.S
> 	$(CPP) $(CPPFLAGS) -DDUMBAS x86.S | \
> 		$(TR) \; \\n | $(SED) 's/\([%.]\) /\1/g' > tmp.s
> 	$(AS) $(ASFLAGS) tmp.s -o sco-x86.o
> 	$(RM) tmp.s
> tru64-alpha:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) digipaq-alpha.o" \
> 		CFLAGS="-c -O4 -arch host" \
> 		OPT_NORMAL="" \
> 		OPT_INLINE="-inline all"
> # Digital/Compaq's cc and make use the .S suffix for a different purpose...
> digipaq-alpha.o: alpha.S
> 	$(CPP) $(CPPFLAGS) alpha.S > tmp.s
> 	$(AS) $(ASFLAGS) tmp.s -o digipaq-alpha.o
> 	$(RM) tmp.s
> aix-ppc32:
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -qunroll=2 -qarch=ppc -qchars=signed" \
> 		LDFLAGS="-s -lbsd" \
> 		OPT_NORMAL="-O2" \
> 		OPT_INLINE="-O3 -Q=99 -w"
> macosx-ppc32-altivec:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) ppc-alti-macosx.o" \
> 		CFLAGS="-c -Wall -fomit-frame-pointer" \
> 		OPT_NORMAL="-fast -mcpu=7450" \
> 		OPT_INLINE="-fast -mcpu=7450 -finline-limit=4000"
> macosx-ppc32:
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -traditional-cpp" \
> 		OPT_NORMAL="-O2" \
> 		OPT_INLINE="-O3"
> # This is slightly slower than macosx-ppc32-altivec for most hash types.
> macosx-ppc64-altivec:
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -m64 -Wall -fomit-frame-pointer" \
> 		LDFLAGS="-s -m64" \
> 		OPT_INLINE="-fast -finline-limit=4000"
> macosx-ppc64:
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -Wall -fomit-frame-pointer -m64" \
> 		LDFLAGS="-s -m64" \
> ppc-alti-macosx.o: ppc-alti.c DES_bs_a.c
> 	$(CC) $(CFLAGS) $(OPT_INLINE) -faltivec -maltivec ppc-alti.c -o $@
> macosx-x86-sse2:
> 	$(LN) x86-sse-mac.h arch.h
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-sse.o" \
> 		ASFLAGS="$(ASFLAGS) -DUNDERSCORES -DBSD -DALIGN_LOG"
> 		OPT_NORMAL="-O2" \
> 		OPT_INLINE="-O3"
> macosx-x86-mmx:
> 	$(MAKE) $(PROJ) \
> 		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-mmx.o sha1-mmx.o" \
> 		OPT_NORMAL="-O2" \
> 		OPT_INLINE="-O3"
> hpux-pa-risc-mpicc:
> 	$(MAKE) $(PROJ) \
> hpux-pa-risc-cc:
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -Aa -D_HPUX_SOURCE -DANSI_CPP" \
> 		LDFLAGS="-s" \
> 		OPT_NORMAL="+O2" \
> 		OPT_INLINE="+O3 +Oinline"
> irix-mips64-r10k:
> 	$(LN) mips64.h arch.h
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -O2 -64 -mips4 -r10000 -signed" \
> 		LDFLAGS="-s -64 -mips4 -r10000" \
> 		OPT_NORMAL="-LNO:opt=1 -OPT:Olimit=2194" \
> 		OPT_INLINE="-INLINE:all"
> irix-mips64:
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -O2 -64 -mips3 -signed" \
> 		LDFLAGS="-s -64 -mips3" \
> irix-mips32:
> 	$(LN) mips32.h arch.h
> 	$(MAKE) $(PROJ) \
> 		CFLAGS="-c -O2 -32 -signed" \
> 		LDFLAGS="-s -32" \
> dos-djgpp-x86-mmx:
> 	copy x86-mmx.h arch.h
> 	$(MAKE) $(PROJ_DOS) \
> NTmmx_fmt.o" \
> 		CFLAGS="$(CFLAGS) -mpreferred-stack-boundary=2" \
> dos-djgpp-x86-any:
> 	copy x86-any.h arch.h
> win32-cygwin-x86-mmx:
> 	$(CP) x86-mmx.h arch.h
> 	$(MAKE) $(PROJ_WIN32) \
> 		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-mmx.o  md4-mmx.o
> NTmmx_fmt.o md5-mmx.o sha1-mmx.o" \
> 		ASFLAGS="$(ASFLAGS) -DUNDERSCORES"
> win32-cygwin-x86-sse2:
> 	$(CP) x86-sse.h arch.h
> 		JOHN_OBJS="$(JOHN_OBJS) x86.o x86-sse.o md4-sse2.o
> win32-cygwin-x86-any:
> 	$(CP) x86-any.h arch.h
> beos-x86-sse2:
> 	$(MAKE) $(PROJ) \
> beos-x86-mmx:
> 	$(MAKE) $(PROJ) \
> NTmmx_fmt.o"
> beos-x86-any:
> 	$(MAKE) $(PROJ) \
> generic: generic.h
> 	$(RM) arch.h
> 	ln -s generic.h arch.h
> 	$(MAKE) $(PROJ)
> generic.h:
> 	$(RM) arch.h
> 	$(CC) $(CFLAGS) detect.c
> 	./best.sh "$(MAKE)" \
> 		"$(BENCH_DES_OBJS_DEPEND)" \
> 		"$(BENCH_DES_BS_OBJS_DEPEND)" \
> 		"$(BENCH_MD5_OBJS_DEPEND)" \
> 		"$(BENCH_BF_OBJS_DEPEND)"
> bench: $(BENCH_OBJS)
> 	$(LD) $(LDFLAGS) $(BENCH_OBJS) -o bench
> ../run/john: $(JOHN_OBJS)
> 	$(LD) $(JOHN_OBJS) $(LDFLAGS) -o ../run/john
> ../run/unshadow: ../run/john
> 	$(RM) ../run/unshadow
> 	ln -s john ../run/unshadow
> ../run/unafs: ../run/john
> 	$(RM) ../run/unafs
> 	ln -s john ../run/unafs
> ../run/undrop: ../run/john
> 	$(RM) ../run/undrop
> 	ln -s john ../run/undrop
> ../run/unique: ../run/john
> 	$(RM) ../run/unique
> 	ln -s john ../run/unique
> ../run/john.bin: $(JOHN_OBJS)
> 	$(LD) $(LDFLAGS) $(JOHN_OBJS) -o ../run/john.exe
> 	if exist ..\run\john.bin del ..\run\john.bin
> 	ren ..\run\john.exe john.bin
> ../run/john.com: john.com
> 	copy john.com ..\run\john.com
> ../run/unshadow.com: john.com
> 	copy john.com ..\run\unshadow.com
> ../run/unafs.com: john.com
> 	copy john.com ..\run\unafs.com
> ../run/undrop.com: john.com
> 	copy john.com ..\run\undrop.com
> ../run/unique.com: john.com
> 	copy john.com ..\run\unique.com
> john.com: john.asm
> 	@echo Use Borland TASM/TLINK to make JOHN.COM
> 	$(LD) $(JOHN_OBJS) -lkernel32 -o ../run/john.exe
> ../run/unshadow.exe: symlink.c
> 	$(CC) symlink.c -o ../run/unshadow.exe
> 	strip ../run/unshadow.exe
> ../run/unafs.exe: symlink.c
> 	$(CC) symlink.c -o ../run/unafs.exe
> 	strip ../run/unafs.exe
> ../run/undrop.exe: symlink.c
> 	$(CC) symlink.c -o ../run/undrop.exe
> 	strip ../run/undrop.exe
> ../run/unique.exe: symlink.c
> 	$(CC) symlink.c -o ../run/unique.exe
> 	strip ../run/unique.exe
> # Inlining the S-boxes produces faster code, as long as they fit in the
cache
> # (that is, on RISC with at least 8 KB of L1 code cache).
> DES_bs_b.o: DES_bs_b.c DES_bs_s.c DES_bs_n.c
> 	$(CC) $(CFLAGS) $(OPT_INLINE) DES_bs_b.c
> # I prefer to distribute Matthew Kwan's S-box files unmodified...
> DES_bs_s.c: sboxes.c
> 	$(SED) "s/unsigned long/ARCH_WORD/" sboxes.c > DES_bs_s.c
> DES_bs_n.c: nonstd.c
> 	$(SED) "s/unsigned long/ARCH_WORD/" nonstd.c > DES_bs_n.c
> DES_bs_a.c: nonstd.c ppc-alti.pl
> 	$(PERL) ppc-alti.pl nonstd.c > DES_bs_a.c
> miscnl.o: misc.c
> 	$(CC) $(CFLAGS) $(OPT_NORMAL) -D_JOHN_MISC_NO_LOG misc.c -o miscnl.o
> .c.o:
> 	$(CC) $(CFLAGS) $(OPT_NORMAL) $*.c
> .S.o:
> 	$(AS) $(ASFLAGS) $*.S
> # We don't have any files with .s suffix, this is for compiling in DOS only
> .s.o:
> depend:
> 	makedepend -fMakefile.dep -Y *.c 2>> /dev/null
> clean:
> 	$(RM) $(PROJ) $(PROJ_DOS) $(PROJ_WIN32)
> 	$(RM) ../run/john.exe *.o *.bak core
> 	$(RM) detect bench generic.h arch.h sparc.h tmp.s
> 	$(RM) DES_bs_s.c DES_bs_n.c DES_bs_a.c
> 	$(CP) $(NULL) Makefile.dep
> include Makefile.dep
