[mpich-discuss] Re: [MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
Krishna Chaitanya
kris.c1986 at gmail.com
Sun Mar 2 07:58:30 CST 2008
I think i have figured it out. Will post back if I have any further doubts.
Krishna Chaitanya K
On Sun, Mar 2, 2008 at 1:02 AM, Krishna Chaitanya <kris.c1986 at gmail.com>
wrote:
> >Not sure I understand your question fully,
> Basically, I am trying to modify the MPICH library to invoke a
> callback when a message gets inserted into the unex queue and also monitor
> the unex queue's length.
> >So, if the message from
> the other send arrives in the meanwhile, MPID_Progress_Wait will cause it
> to
> be received and placed in the unexpected queue.
> Well, This is what I have understood :
> 1. MPI_Irecv calls MPIDI_CH3U_Recvq_FDU_or_AEP. This scans through the
> unex queue. In my case, there isnt one, so it creates a new request and
> inserts it into the posted queue.
> 2. MPI_Irecv returns.
> 3. MPI_Iwait calls MPIDI_CH3i_Progress_wait which calls
> MPIDI_CH3I_Progress_handle_sock_event in a loop.
> 4. If the event is MPIDU_SOCK_OP_READ and if the conn->state is connected,
> and MPIDI_CH3U_Recvq_FDP_or_AEU gets called. This function scans through the
> posted queue for a match. If a match is found, it gets dequeued. Else, it is
> placed into the unex queue.
> OK...
> A node can actually gather a new incoming message only when it is in
> the progress engine. The progress engine is invoked only by MPI_Wait.
> MPI_Wait gets called only after MPI_Irecv returns. (Am i right so far ? )
> From the traces that I have done so far, I have observed that a new
> message is not getting into the unex queue, as a matching MPI_Irecv has
> already been executed. ( Which has placed the recv request in the posted
> queue) . When MPIDI_CH3U_Recvq_FDP_or_AEU is called from the progress
> engine, a matching request in the posted queue is invariably found and the
> new message is not really "unexepected" from the receiver's standpoint.
> This is what my code looks like :
> sender side :
> MPI_Isend (buffer, 1, MPI_INTEGER, 1, 1001,
> MPI_COMM_WORLD, &req2[0]);
> MPI_Isend (buffer, 1, MPI_INTEGER, 1, 1002,
> MPI_COMM_WORLD, &req2[1]);
> printf(" [%d] MPI_Isend returns \n",rank);
> MPI_Wait( &req2[0] , &sts2[0]);
> MPI_Wait( &req2[1], &sts2[1]);
> receiver side :
> sleep(10);
> MPI_Irecv (buffer, 1, MPI_INTEGER, 0, 1001, MPI_COMM_WORLD,
> &(req1[0]));
> sleep(10);
> MPI_Irecv (buffer, 1, MPI_INTEGER, 1, 1002,
> MPI_COMM_WORLD, &(req1[1]));
> MPI_Wait(&req1[0], &sts1[0]);
> MPI_Wait(&req1[1], &sts1[1]);
> I tried to have those sleep()'s to make the reciever operate slower
> than the sender.
> Thanks for your time and please let me know if I am missing something .
> Krishna Chaitanya,
> Final Year B-Tech,
> National Institute of Technology,Karnataka.
> On Fri, Feb 29, 2008 at 7:44 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> > > I just started looking into the non-blocking calls today. I am
> > > not sure of whats happening in the call : MPIR_Grequest_progress_poke.
> > > What exactly is the difference between a generalized request and a
> > > native request?
> > A generalized request is something defined in MPI-2's chapter on
> > external
> > interfaces. It is a way for a new library to define its own nonblocking
> > operations and use MPI_Request objects to test or wait on.
> > MPIR_Grequest_progress_poke uses an extension to MPI-2 generalized
> > requests,
> > as explained in
> > http://www-unix.mcs.anl.gov/~thakur/papers/grequest-redesign.pdf<http://www-unix.mcs.anl.gov/%7Ethakur/papers/grequest-redesign.pdf>.
> > But you
> > can just ignore generalized requests for now.
> > > I am also keen on knowing how an unexpected message is handled
> > > by MPICH2 and I have understood what happens in the function
> > > MPIDI_CH3U_Recvq_FDU_or_AEP(). So, I had two ranks(ranks 0 and 1)
> > > executing MPI_Isend() and one rank(rank 2) executing the two matching
> > > MPI_Irecv() calls, with the hope that the message that is arriving
> > > from rank 1 would be unexpected from rank 2's standpoint. But, as it
> > > turns out, MPI_Wait() actually calls MPID_Progress_Wait(). This is a
> > > blocking call and the MPI_Isend() that is being executed by rank1 is
> > > blocked until rank2 executes the corresponding MPI_Irecv().
> > > My question is, how can I get an incoming message at rank 2 to
> > > get into the unexpected queue and wait there till the receiver scans
> > > through the queue until a match is found and proceeds to transfer of
> > > data?
> > > To make this happen, MPID_Progress_Wait must never get called
> > > and so the MPI_Wait must constantly. Is that correct?
> > Not sure I understand your question fully, but MPID_Progress_wait will
> > block
> > until some (any) event occurs. That event need not be the event of
> > interest,
> > namely, the one for which the MPI_Wait was called. So, if the message
> > from
> > it to
> > Rajeev
> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080302/26e7a6b9/attachment.htm>
