[mpich-discuss] problem with execution of examples/cpi
Ariovaldo de Souza Junior ariovaldojunior at gmail.com
Mon Jun 30 12:56:55 CDT 2008
It is solved, half by you all guys and half by myself. I really needed to
add "./" but also I had some things to fix in nfs. I was sharing just the
mpich folder, not the whole environment of my tools, so it couldn't catch
the cpi file in the other computers. But thanks a lot!
Ari
2008/6/30 Jayesh Krishna <jayesh at mcs.anl.gov>:
>  Hi,
>  Try providing the absolute path of cpi to mpiexec.
> Regards,
> Jayesh
> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Ariovaldo de Souza Junior
> *Sent:* Monday, June 30, 2008 11:54 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] problem with execution of examples/cpi
> Anthony Chan,
> I did not install MPICH on falcon due it to be shared by nfs, so I just
> installed in the server and I get an image of this in both computers. I have
> tried to execute like this "./cpi" and it gets the same error. I can process
> both alone in each computer, but when I want it done by both this message
> returns to me. Any idea?
> Thanks a lot for your attention,
> Ari
> 2008/6/30 Anthony Chan <chan at mcs.anl.gov>:
>> Is mpich2 installed on falcon ?  If so, is it installed in the same
>> location as eagle ?
>> Assuming you have mpich2 installed correctly on both machines,
>> cd to <mpich2-install-dir>/examples, then do
>> mpiexec -n 10 ./cpi
>> A.Chan
>>  ----- "Ariovaldo de Souza Junior" <ariovaldojunior at gmail.com> wrote:
>> > ---------- Forwarded message ----------
>> > From: Ariovaldo de Souza Junior < ariovaldojunior at gmail.com >
>> > Date: 2008/6/30
>> > Subject: Re: [MPICH2 Req #4157] Getting error message running mpiexec
>> > To: Rajeev Thakur < thakur at mcs.anl.gov >, Pavan Balaji <
>> > balaji at mcs.anl.gov >
>> > Hello Rajeev and Pavan,
>> > Thanks a lot for your help on building MPICH correctly. I have removed
>> > mpd (apt-get purge mpd) and then reinstalled MPICH. I was so happy
>> > when I saw it was working T_T. A the looping test, with 1,000,000
>> > loops too 431 seconds to be performed. Do you think it is a good rate?
>> > But now what brings me to here is what comes next. I have followed all
>> > instructions from the "quick start" until this line:
>> > mpiexec -n 5 examples/cpi
>> > and it didn't work, returning this error:
>> > problem with execution of examples/cpi on falcon: [Errno 2] No such
>> > file or directory
>> > file or directory
>> > and stopped in the second line.
>> > Then I tried to submit this command inside of the "examples" folder,
>> > and it returned:
>> > problem with execution of cpi on eagle: [Errno 2] No such file or
>> > directory
>> > problem with execution of cpi on falcon: [Errno 2] No such file or
>> > directory
>> > directory
>> > directory
>> > directory
>> > Now I can see that it failed for the five processes. I have set and
>> > mounted the nfs on the node (until now I'm setting up just one
>> > computer, later I'll close this one) and it is working ok. So my
>> > server is named as eagle and the node, falcon. mpd is running in both
>> > computers, this I can see utilizing the mpdtrace command. when I
>> > submit the example "mpiexec -l -n 10 hostname" it returns me this:
>> > root at eagle:/modeling/mpich2-1.0.7/examples# mpiexec -l -n 10 hostname
>> > 1: falcon
>> > 2: eagle
>> > 3: falcon
>> > 5: falcon
>> > 4: eagle
>> > 7: falcon
>> > 8: eagle
>> > 6: eagle
>> > 0: eagle
>> > 9: falcon
>> > And then I think it is ok.
>> > the paths are set and ok, so I don't understand why is that returning
>> > that error, not found, if even if I execute it inside of "examples"
>> > folder it doesn't work (of course I take off the examples part, or
>> > even add the whole path).
>> > Ad I have a doubt, a stupid one, sorry, every time I restart the
>> > computer I have to point the path for the bin directory, and then it
>> > works. Is there any way to set it automatically?
>> > Sorry for trouble you two so much. And thank you two until now for
>> > your attention!
>> > Ari.
>> > 2008/6/27 Rajeev Thakur < thakur at mcs.anl.gov >:
>> > What exact commands did you use to configure, make, and install
>> > MPICH2? How did music and playlist get into the mpd directory? :-)
>> > Rajeev
>> > From: Ariovaldo de Souza Junior [mailto: ariovaldojunior at gmail.com ]
>> > Sent: Friday, June 27, 2008 6:31 PM
>> > To: mpich2-maint at mcs.anl.gov
>> > Cc: mpich2-maint at mcs.anl.gov
>> > Subject: [MPICH2 Req #4157] Getting error message running mpiexec
>> > Hello everybody.
>> > I'm trying to make mpich work for a cluster running NAMD and I'm
>> > frozen in the tests step yet. When I try to run the simple script
>> > "helloworld.out" I get the followying error message:
>> > root at eagle:/modeling/mpich# mpiexec ./hello.out
>> > mpiexec_eagle (get_parms_from_rcfile 1403): line in mpd conf is not
>> > key=val pair; line=:music_directory "/var/lib/mpd/music"
>> > key=val pair; line=:playlist_directory "/var/lib/mpd/playlists"
>> > key=val pair; line=:db_file "/var/lib/mpd/tag_cache"
>> > key=val pair; line=:log_file "/var/log/mpd/mpd.log"
>> > key=val pair; line=:error_file "/var/log/mpd/errors.log"
>> > key=val pair; line=:pid_file "/var/run/mpd/pid"
>> > key=val pair; line=:state_file "/var/lib/mpd/state"
>> > key=val pair; line=:user "root"
>> > key=val pair; line=:bind_to_address "localhost"
>> > key=val pair; line=:password "gqtcpbm at read,add,control,admin"
>> > key=val pair; line=:filesystem_charset "UTF-8"
>> > key=val pair; line=:id3v1_encoding "UTF-8"
>> > /modeling/mpich/bin/mpdroot: did not find secretword in mpd conf
>> > filempiexec_eagle (__init__ 1190): forked process failed; status=255
>> > I googled around trying all I could but I didn't find anything. Do
>> > anyone have a clue about what is going one? Thanks a lot for any tip!
>> > Ariovaldo
>> > UFAM - Brazil
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080630/c95d3854/attachment.htm>
