[mpich-discuss] Getting error message running mpiexec
Ariovaldo de Souza Junior
ariovaldojunior at gmail.com
Fri Jun 27 18:42:12 CDT 2008
Hello everybody.
I'm trying to make mpich work for a cluster running NAMD and I'm frozen in
the tests step yet. When I try to run the simple script "helloworld.out" I
get the followying error message:
root at eagle:/modeling/mpich# mpiexec ./hello.out
mpiexec_eagle (get_parms_from_rcfile 1403): line in mpd conf is not key=val
pair; line=:music_directory "/var/lib/mpd/music"
pair; line=:playlist_directory "/var/lib/mpd/playlists"
pair; line=:db_file "/var/lib/mpd/tag_cache"
pair; line=:log_file "/var/log/mpd/mpd.log"
pair; line=:error_file "/var/log/mpd/errors.log"
pair; line=:pid_file "/var/run/mpd/pid"
pair; line=:state_file "/var/lib/mpd/state"
pair; line=:user "root"
pair; line=:bind_to_address "localhost"
pair; line=:password "gqtcpbm at read,add,control,admin"
pair; line=:filesystem_charset "UTF-8"
pair; line=:id3v1_encoding "UTF-8"
/modeling/mpich/bin/mpdroot: did not find secretword in mpd conf
filempiexec_eagle (__init__ 1190): forked process failed; status=255
I googled around trying all I could but I didn't find anything. Do anyone
have a clue about what is going one? Thanks a lot for any tip!
Ariovaldo
UFAM - Brazil
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080627/b2418987/attachment.htm>
