[mpich-discuss] intercomm merge then intercomm create bug/misunderstanding?
Brad Penoff penoff at cs.ubc.ca
Fri Jun 27 16:38:13 CDT 2008
On Fri, Jun 27, 2008 at 8:39 AM, Robert Latham <robl at mcs.anl.gov> wrote:
> On Fri, Jun 27, 2008 at 01:19:43AM -0700, Brad Penoff wrote:
>> However, when I do this, I keep getting this error that I'm
>> having difficulty understanding:
>> mpirun -np 3 ./spawn_merge_create_simple 2      #  the arg 2 is how
>> many procs to spawn
> Hey Brad
> I get this same error as well with MPICH2 from SVN (the gang here has
> done a lot of work on the dynamic process path since the release...)
> If I only mpiexec one process and let mpi_comm_spawn build the rest,
> things seem to go ok.    I can't add too much to help you out: I only
> break MPI-2 dynamic process routines, not work on them :>
hey Rob,
Thanks, ya I hadn't tried the latest MPICH2 from SVN.  For the record,
on MPICH2 1.0.7, this same code I sent you guys a link to also works
if I run only one process.  This says there's either a bug in MPICH2
or my "program_a" logic for creating the intercommunicator is
incorrect...
I noticed on the new MPICH2 webpage that the bug tracker is a work in
progress... Do you know if there is a bug formally logged against
this?
Thanks again,
brad
