[mpich-discuss] building 32 bit shmem on 64 bit linux system
Daniel Fetchinson
fetchinson at googlemail.com
Thu Jun 26 17:20:12 CDT 2008
I started the whole thing from scratch and deleted all build
directories, unpacked mpich and now I'm pretty certain I've got a
ch_shmem configured, built, installed.
But there is another problem: I use the parallel arpack library in my
program and while linking the whole thing together mpicc complains
about undefined references:
libs/libparpack.a(pznaupd.o): In function `pznaupd_':
pznaupd.f:(.text+0x3db): undefined reference to `mpi_comm_rank__'
libs/libparpack.a(pznaupd.o):(.data+0x0): undefined reference to `mpi_dup_fn__'
libs/libparpack.a(pznaupd.o):(.data+0x4): undefined reference to
`mpi_null_delete_fn__'
libs/libparpack.a(pznaupd.o):(.data+0x8): undefined reference to
`mpi_null_copy_fn__'
libs/libparpack.a(pivout.o): In function `pivout_':
pivout.f:(.text+0x16): undefined reference to `mpi_comm_rank__'
libs/libparpack.a(pivout.o):(.data+0x0): undefined reference to `mpi_dup_fn__'
libs/libparpack.a(pivout.o):(.data+0x4): undefined reference to
libs/libparpack.a(pivout.o):(.data+0x8): undefined reference to
etc. etc..............
Although /home/fetchinson/mpich32shmem/lib/libmpich.a is given to
mpicc for linking along with all other object files where
/home/fetchinson/mpich32shmem is the installation directory of mpich
(the one given to ./configure via --prefix). So it seems I have some
linking problems still.
By the way, the only file that is needed to be given to mpicc for
static linking is libmpich.a, right? What is strange is that on
another machine the same Makefile works with the same installation
directory for mpich.
Cheers,
Daniel
> In the outputs of the configure and make steps, does it look like it is
> building ch_p4 or ch_shmem?
> Rajeev
>> Out of desperation I looked at the output of
>> strings my_test_program
>> where my_test_program was compiled using mpicc (using absolute paths)
>> from the 32-bit shmem mpi library. Strangely, ch_p4 appears in the
>> output several times while ch_shmem doesn't. On another machine where
>> I'm successfully compiling 32-bit shmem executables the output of
>> 'strings my_test_program' only contains ch_shmem and not ch_p4.
>> So there must be something wrong with my mpicc, although I can't
>> imagine what, I never compiled to ch_p4.
>> Thanks for the advice guys, there seems to be progress :)
>> Daniel
>> > Did you do a "make install" after "make" ? If not, the
>> install directory
>> > may still have an older installation of mpich-1 which could be ch_p4
>> > and not ch_shmem that you need.
>> > A.Chan
>> > ----- "Daniel Fetchinson" <fetchinson at googlemail.com> wrote:
>> >> > It must be the mpirun then. Make sure you use the mpirun from the
>> >> same
>> >> > build. Give the full path if necessary.
>> >> > Rajeev
>> >> Thanks, but there is only one installation of mpi on the
>> machine and
>> >> that installation is the one I keep compiling. So even if it wanted
>> >> to
>> >> execute the wrong mpicc/mpirun/etc it couldn't because
>> there is only
>> >> 1
>> >> copy at any given time.
>> >> Nevertheless I recompiled now mpi as well as my program and still I
>> >> get the same error:
>> >> 0 - MPI_INIT : MPIRUN chose the wrong device ch_shmem;
>> program needs
>> >> device ch_p4
>> >> /home/fetchinson/mpich32shmem/bin/mpirun.ch_shmem: line 91: 21976
>> >> Segmentation fault /home/fetchinson/test "testinput"
>> >> Any ideas?
>> >> Daniel
>> >> >> > Did you recompile the program? Make sure you use the mpicc
>> >> >> from this
>> >> >> > build and not some other mpicc from another directory. Give
>> >> >> the full
>> >> >> > path if necessary.
>> >> >> > Rajeev
>> >> >> Yes, I did recompile the program using mpicc from the newly
>> >> >> built mpi library. Actually, there is only one mpicc on the
>> >> >> whole machine.
>> >> >> Cheers,
>> >> >> Daniel
>> >> >> >> Actually, I spoke a bit too soon. Configure, make, make
>> >> >> install all
>> >> >> >> work but the code still doesn't run, saying:
>> >> >> program needs
>> >> >> >> device ch_p4
>> >> >> >> /home/fetchinson/mpi32shmem/bin/mpirun.ch_shmem:
>> line 91: 17761
>> >> >> >> The exact same code runs on another machine where
>> someone else
>> >> >> >> installed a 32-bit shmem mpich1 library, I'm trying to do
>> >> >> the same on
>> >> >> >> a different machine now. It's an intel quad core so I suppose
>> >> the
>> >> >> >> shmem device should work. The configure options I used for
>> >> >> compiling
>> >> >> >> are
>> >> >> >> export CC='gcc -m32'
>> >> >> >> export F77='g77 -m32'
>> >> >> >> ./configure --with-device=ch_shmem
>> >> >> >> Do I need to specify the --with-arch option? Going through
>> >> >> the list
>> >> >> >> of available --with-arch options I'm not sure what I need for
>> >> an
>> >> >> >> Intel(R)
>> >> >> >> Core(TM)2 Quad CPU Q6600 @ 2.40GHz.
>> >> >> >> What am I doing wrong?
>> >> >> >> Cheers,
>> >> >> >> Daniel
>> >> >> >> > Thanks Anthony, that worked!
>> >> >> >> > Concerning MPICH2: I'm not in a position to change the
>> >> >> >> communication
>> >> >> >> > routines in the code I use so this would only be an option
>> >> >> >> if MPICH2
>> >> >> >> > is fully backward compatible with MPICH1. Is this the case?
>> >> >> >> Can I just
>> >> >> >> > start using MPICH2 without changing anything in the code if
>> >> >> >> it works
>> >> >> >> > with MPICH1?
>> >> >> >> > Cheers,
>> >> >> >> > Daniel
>> >> >> >> >> Since you are using MPICH-1, you can try setting
>> CC, F77 and
>> >> F90
>> >> >> >> >> CC="gcc -m32"
>> >> >> >> >> F77="g77 -m32"
>> >> >> >> >> BTW, can you use MPICH2 instead ? We have shifted all our
>> >> >> >> >> development effort to MPICH2 which is more robust than
>> >> >> >> MPICH-1. If
>> >> >> >> >> you are using MPICH2, setting CFLAGS and FFLAGS should
>> >> >> >> work, and you
>> >> >> >> >> can use nemesis which shared memory for intranode
>> >> communication.
>> >> >> >> >> A.Chan
>> >> >> >> >>> Hi folks,
>> >> >> >> >>> I'd like to build the 32-bit shmem mpi library because
>> >> >> >> the code I'll
>> >> >> >> >>> use with mpi only works in 32-bit because of some
>> >> >> 32-bit specific
>> >> >> >> >>> assembly code. The machine is a 64-bit machine with a
>> >> >> >> 64-bit linux
>> >> >> >> >>> distribution (suse).
>> >> >> >> >>> I tried configuring mpich-1.2.7p1 in a number of ways:
>> >> >> >> >>> ./configure --with-device=ch_shmem ./configure
>> >> >> --with-arch=LINUX
>> >> >> >> >>> --with-arch=LINUX32 --with-device=ch_shmem ./configure
>> >> >> >> >>> --with-arch=i386 --with-device=ch_shmem
>> >> >> >> >>> with and without setting the following environment
>> >> >> variables (in
>> >> >> >> >>> bash):
>> >> >> >> >>> export CFLAGS=-m32
>> >> >> >> >>> export FFLAGS=-m32
>> >> >> >> >>> Configuring went all right but none of the above
>> >> >> >> combinations worked
>> >> >> >> >>> with 'make' unfortunately :( The error in 'make' is
>> >> >> the following:
>> >> >> >> >>> /home/fetchinson/mpich-1.2.7p1/bin/mpicc -o overtake
>> >> >> overtake.o
>> >> >> >> >>> test.o
>> /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse
>> >> >> >> -linux/bin/ld:
>> >> >> >> >>> skipping incompatible
>> >> >> >> /home/fetchinson/mpich-1.2.7p1/lib/libmpich.a
>> >> >> >> >>> when searching for -lmpich
>> >> >> >> -linux/bin/ld:
>> >> >> >> >>> cannot find -lmpich
>> >> >> >> >>> collect2: ld returned 1 exit status
>> >> >> >> >>> make[4]: *** [overtake] Error 1
>> >> >> >> >>> make[3]: [linktest1] Error 2 (ignored) Could not link
>> >> >> a C program
>> >> >> >> >>> with MPI libraries
>> >> >> >> >>> make[3]: *** [linktest1] Error 1
>> >> >> >> >>> make[2]: *** [linktest] Error 2
>> >> >> >> >>> make[1]: *** [mpi-lib-test] Error 2
>> >> >> >> >>> make: *** [mpi] Error 2
>> >> >> >> >>> Which makes me believe that I was not able to
>> convince the
>> >> >> >> >>> compiler/linker/etc that I really want everything in
>> >> 32-bit.
>> >> >> >> >>> What would be the correct way of compiling the whole mpi
>> >> >> >> library to
>> >> >> >> >>> 32-bit?
>> >> >> >> >>> Cheers,
>> >> >> >> >>> Daniel
>> >> >> >> > Psss, psss, put it down! -
>> http://www.cafepress.com/putitdown
>> >> >> >> Psss, psss, put it down! - http://www.cafepress.com/putitdown
