[mpich-discuss] No Fortran 90 compiler
倪旭东
xd_ni at seu.edu.cn
Wed Jun 4 08:53:28 CDT 2008
Dmitri Chubarov,您好!
But I have installed the Intel(R) Fortran Compiler 9.0 for Linux*,
[root at cgsp l_fc_c_9.0.033]# rpm -qa | grep intel
intel-ifort9-9.0-033
intel-iidb9-9.0-037
intel-iidbe9-9.0-037
So why it cannot find the Fortran 90 compiler ? Thanks
======== 2008-06-04 19:49:08 您在来信中写道: ========
Hello,
You have to install gfortran or any other Fortran-90 compiler or use mpif77 with your FORTRAN-77 codes.
Here is what configure says:
checking whether the Fortran 77 compiler (g77 ) works... yes
You have got g77, good, but g77 is old and most of the work on the GNU Fortran compiler is on gfortran.
checking for f95... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for ifc... no
checking for efc... no
configure: warning: no acceptable Fortran 90 compiler found in $PATH
checking whether Fortran 90 is compatible with Fortran 77... no
configure: error: Fortran 90 and Fortran 77 compilers are not compatible.
They generate external symbol names that are different
You do not seem to have a Fortran 90 compiler available on your system.
致
礼!
倪旭东
xd_ni at seu.edu.cn
2008-06-04
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080604/aa4a2246/attachment.htm>
