[mpich-discuss] Does MPICH2 work with multiple NICs, and how?
Gus Correa
gus at ldeo.columbia.edu
Tue Jun 3 10:44:06 CDT 2008
Hi Darius (and MPICH-Discuss list)
Thank you very much for the important clarification, Darius.
I poked around but could not find anything in the MPICH documentation
about multiple NICs. (Maybe there is something, but I couldn't find.)
Two more questions, if it is OK to ask:
4) Is there any experiment/benchmark/measurement on how MPICH2 performs with
channel bonding on Gigabit Ethernet NICs?
I have been told some network applications (e.g. NFS) show little
improvement
when channel bonding is used.
5) Can I understand that in the future MPICH2 will provide multiple IP
addresses
as an alternative to channel bonding (or perhaps instead of channel
bonding)?
Many thanks once again.
Gus Correa
Gustavo J. Ponce Correa, PhD - Email: gus at ldeo.columbia.edu
Lamont-Doherty Earth Observatory - Columbia University
P.O. Box 1000 [61 Route 9W] - Palisades, NY, 10964-8000 - USA
Oceanography Bldg., Rm. 103-D, ph. (845) 365-8911, fax (845) 365-8736
Darius Buntinas wrote:
> Hi Gus,
> Right now, channel bonding is the only option. Addressing multiple
> Gig-E NICs is in our future plans though.
> -d
> On 06/03/2008 09:38 AM, Gus Correa wrote:
>> Dear MPICH developers and experts
>> 1) Does MPICH2 (or MPICH-1) work with multiple Gigabit Ethernet NICs
>> installed on the
>> computing nodes of a PC Linux cluster?
>> 2) If it does work with multiple NICs, what is the recommended
>> mechanism to use MPICH2
>> with multiple NICs: LACP/channel bonding, multiple IP addresses,
>> something else?
>> 3) If it doesn't work with multiple NICs,
>> are there plans to include communication with multiple NICs in
>> MPICH2, and how soon?
>> We are long time MPICH users, and so far our old
>> single-core/dual-slot PC computer
>> cluster nodes have had single NICs, performing reasonably well.
>> However, most new PC cluster nodes on the market these days are
>> multi-core/multi-slot,
>> and a single NIC per node is likely to produce network contention.
>> I have to buy a replacement cluster for our group (which mostly does
>> computations with MPICH),
>> hence my concern about this.
>> I hope the questions are appropriate.
>> Many thanks for any clarification or help.
>> Gus Correa
