[mpich-discuss] Problem with gdb
    Anthony Chan
    chan at mcs.anl.gov
    Tue Jul 29 09:12:33 CDT 2008
configuring mpich2 with --enable-g=meminit,dbg should get rid some (if not all)
of valgrind messages.
A.Chan
----- "Burlen Loring" <burlen.loring at kitware.com> wrote:
> Hi all,
> Marcelo Tomim wrote:
> > I have been trying to debug a program, but it freezes every time I
> try to run
> > it in debug mode.
> > This is what I type:
> >  mpiexec -gdb -n 3 ./my_program
> > Then it does not return the command line and I have to kill it.
> I can confirm this. The same thing recently started happening to me. I
> guessed it was related to a recent kernel/system library upgrades.
> Linux tycho 2.6.24-19-generic #1 SMP Fri Jul 11 23:41:49 UTC 2008 i686
> GNU/Linux
> Also seemingly coincident with recent system upgrades, when I run
> codes
> through valgrind I see a lot of complaints about using uninitialized
> memory. Below is a simple program and it's valgrind output. Notice,
> that
> there is a lot of lines like:
> Syscall param writev(vector[...]) points to uninitialised byte(s)
> These seemed to show up about the same time that -gdb option stopped
> working. I think it has to do with system library change and not mpich
> but I can't be sure. I am using my own source install of mpich 2 and I
> have rebuilt since the upgrades but it didn't help.
> I'd certainly like to get the -gdb option back, and the memory issues
> cleaned up as well.
> Thanks
> Burlen
> // begin of mpivg.cpp
> #include <mpi.h>
> #include <iostream>
> int main(int argc, char **argv)
>   MPI_Init(&argc,&argv);
>   MPI_Barrier(MPI_COMM_WORLD);
>   MPI_Finalize();
>   return 0;
> // end of mpivg.cpp
> tycho:~/ext/kitware_cvs/Work/Burlen/testing$mpiexec -n 2 valgrind
> ./mpivg
> ==2031== Memcheck, a memory error detector.
> ==2031== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et
> al.
> ==2031== Using LibVEX rev 1804, a library for dynamic binary
> translation.
> ==2031== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
> ==2031== Using valgrind-3.3.0-Debian, a dynamic binary instrumentation
> framework.
> ==2031== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et
> al.
> ==2031== For more details, rerun with: -v
> ==2030== Memcheck, a memory error detector.
> ==2030== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et
> al.
> ==2030== Using LibVEX rev 1804, a library for dynamic binary
> translation.
> ==2030== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
> ==2030== Using valgrind-3.3.0-Debian, a dynamic binary instrumentation
> framework.
> ==2030== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et
> al.
> ==2030== For more details, rerun with: -v
> ==2030==
> ==2031==
> ==2030== Syscall param writev(vector[...]) points to uninitialised
> byte(s)
> ==2030==    at 0x40007F2: (within /lib/ld-2.7.so)
> ==2030==    by 0x4130FBC: MPIDU_Sock_wait (in
> /opt/mpich2-1.0.7/lib/libmpich.so.1.1)==2031== Syscall param
> ==2031==    at 0x40007F2: (within /lib/ld-2.7.so)
> ==2031==    by 0x4130FBC: MPIDU_Sock_wait (in
> ==2031==    by 0x40ABE2B: MPIDI_CH3I_Progress (in
> ==2031==    by 0x40EA978: MPIC_Wait (in
> ==2031==    by 0x40EAD71: MPIC_Sendrecv (in
> ==2031==    by 0x40A089D: MPIR_Barrier (in
> ==2030==    by 0x40ABE2B: MPIDI_CH3I_Progress (in
> ==2030==    by 0x40EA978: MPIC_Wait (in
> ==2030==    by 0x40EAD71: MPIC_Sendrecv (in
> ==2030==    by 0x40A089D: MPIR_Barrier (in
> ==2030==    by 0x40A0E4A: PMPI_Barrier (in
> ==2030==    by 0x804891B: main (in
> /home/burlen/ext/kitware_cvs/Work/Burlen/testing/mpivg)
> ==2030==  Address 0x4457fa8 is 32 bytes inside a block of size 72
> alloc'd
> ==2030==    at 0x4022AB8: malloc (vg_replace_malloc.c:207)
> ==2030==    by 0x40AE6F5: MPIDI_CH3I_Connection_alloc (in
> ==2030==    by 0x40AE97E: MPIDI_CH3I_Sock_connect (in
> ==2030==    by 0x40AEBB7: MPIDI_CH3I_VC_post_sockconnect (in
> ==2030==    by 0x40AAB0C: MPIDI_CH3I_VC_post_connect (in
> ==2030==    by 0x40A9472: MPIDI_CH3_iSend (in
> ==2030==    by 0x40F9CC5: MPID_Isend (in
> ==2030==    by 0x40EAD39: MPIC_Sendrecv (in
> 2031==    by 0x40A0E4A: PMPI_Barrier (in
> ==2031==    by 0x804891B: main (in
> ==2031==  Address 0x4457fa8 is 32 bytes inside a block of size 72
> alloc'd
> ==2031==    at 0x4022AB8: malloc (vg_replace_malloc.c:207)
> ==2031==    by 0x40AE6F5: MPIDI_CH3I_Connection_alloc (in
> ==2031==    by 0x40AE97E: MPIDI_CH3I_Sock_connect (in
> ==2031==    by 0x40AEBB7: MPIDI_CH3I_VC_post_sockconnect (in
> ==2031==    by 0x40AAB0C: MPIDI_CH3I_VC_post_connect (in
> ==2031==    by 0x40A9472: MPIDI_CH3_iSend (in
> ==2031==    by 0x40F9CC5: MPID_Isend (in
> ==2031==    by 0x40EAD39: MPIC_Sendrecv (in
> ==2031==    by 0x40A0E4A: PMPI_Barrier (in
> ==2030==
> ==2030== Syscall param write(buf) points to uninitialised byte(s)
> ==2030==    by 0x40A950D: MPIDI_CH3_iSend (in
> ==2030==    by 0x40F82DF: MPID_Finalize (in
> ==2030==    by 0x40D8FD4: PMPI_Finalize (in
> ==2030==    by 0x8048920: main (in
> ==2030==  Address 0xbec94fdc is on thread 1's stack
> ==2031==
> ==2031== Syscall param write(buf) points to uninitialised byte(s)
> ==2031==    by 0x40A950D: MPIDI_CH3_iSend (in
> ==2031==    by 0x40F82DF: MPID_Finalize (in
> ==2031==    by 0x40D8FD4: PMPI_Finalize (in
> ==2031==    by 0x8048920: main (in
> ==2031==  Address 0xbeb6afdc is on thread 1's stack
> ==2030==
> ==2030==    by 0x40AA244: MPIDI_CH3_iStartMsg (in
> ==2030==    by 0x40B0F86: MPIDI_CH3U_VC_SendClose (in
> ==2030==    by 0x4101B7F: MPIDI_PG_Close_VCs (in
> ==2030==    by 0x40F8451: MPID_Finalize (in
> ==2030==  Address 0xbec95084 is on thread 1's stack
> ==2031==
> ==2031==    by 0x40AA244: MPIDI_CH3_iStartMsg (in
> ==2031==    by 0x40B0F86: MPIDI_CH3U_VC_SendClose (in
> ==2031==    by 0x4101B7F: MPIDI_PG_Close_VCs (in
> ==2031==    by 0x40F8451: MPID_Finalize (in
> ==2031==  Address 0xbeb6b084 is on thread 1's stack
> ==2030==
> ==2030==    by 0x40B1181: MPIDI_CH3_PktHandler_Close (in
> ==2030==    by 0x40AB8E0: MPIDI_CH3I_Progress_handle_sock_event (in
> ==2030==    by 0x40ABDE5: MPIDI_CH3I_Progress (in
> ==2030==    by 0x40B0E1C: MPIDI_CH3U_VC_WaitForClose (in
> ==2030==    by 0x40F8456: MPID_Finalize (in
> ==2030==  Address 0xbec94fa4 is on thread 1's stack
> ==2031==
> ==2031==    by 0x40B1181: MPIDI_CH3_PktHandler_Close (in
> ==2031==    by 0x40AB8E0: MPIDI_CH3I_Progress_handle_sock_event (in
> ==2031==    by 0x40ABDE5: MPIDI_CH3I_Progress (in
> ==2031==    by 0x40B0E1C: MPIDI_CH3U_VC_WaitForClose (in
> ==2031==    by 0x40F8456: MPID_Finalize (in
> ==2031==  Address 0xbeb6afa4 is on thread 1's stack
> ==2031==
> ==2031== ERROR SUMMARY: 5 errors from 4 contexts (suppressed: 27 from
> 1)
> ==2031== malloc/free: in use at exit: 0 bytes in 0 blocks.
> ==2031== malloc/free: 55 allocs, 55 frees, 35,225 bytes allocated.
> ==2031== For counts of detected errors, rerun with: -v
> ==2031== All heap blocks were freed -- no leaks are possible.
> ==2030==
> ==2030== ERROR SUMMARY: 5 errors from 4 contexts (suppressed: 27 from
> 1)
> ==2030== malloc/free: in use at exit: 0 bytes in 0 blocks.
> ==2030== malloc/free: 55 allocs, 55 frees, 35,225 bytes allocated.
> ==2030== For counts of detected errors, rerun with: -v
> ==2030== All heap blocks were freed -- no leaks are possible.
> Burlen Loring
> Kitware, Inc.
> R&D Engineer
> 28 Corporate Drive
> Clifton Park, NY 12065-8662
> Phone: 518-371-3971 x137
