[mpich-discuss] Killed by Signal 9!!!!???
    Gholamreza Sobhaninejad
    grsobhani at gmail.com
    Mon Jul 28 09:27:33 CDT 2008
Thanks for your answer.
I solved the problem. And now it is working perfectly.
Best regards,
Reza
On Mon, Jul 28, 2008 at 10:24 PM, Burlen Loring
<burlen.loring at kitware.com>wrote:
> Hi,
> In my experience a number of things could cause this. e.g. I have seen this
> if I run out of memory. The kernel steps in and kills the process. There
> might be some info in dmesg, have you looked? Might be something entirely
> different as well, such as too many open files. There are a bunch of
> settings you can tweak take a look at your environment settings via ulimit
> -a.
> Burlen
> Gholamreza Sobhaninejad wrote:
>> Dear All,
>> Hi,
>> This is a prototype program which I am going to implement it in another
>> program. I want to send objects. The program works very well when 'shapeset'
>> is small. But when I increase number of CPU, and Shapeset size , I get the
>> following error message:
>> "rank 0 in job 12  localhost.localdomain_60694   caused collective abort
>> of all ranks
>>  exit status of rank 0: killed by signal 9 "
>> I have a master process which works on Rank 0 and Slaves which are working
>> on Other ranks.
>> Master serialize (write all the information in a char buffer) a Shape
>> object and send it through MPI::Send. Slaves are reciving the Objects and
>> Deserialize it and call a function pointer to operate on the object.
>> Sorry the code is little bit long.
>> I really appreciate your help. I need some advices. I am working on
>> Linux-Fedora with dual core cpu.
>> Sincerely,
>> Gholamreza Sobhaninejad(Reza)
>> PhD candidate, University of Tokyo
>> Earthquake Research Institute
>> Tel: 090-9807-2477
>> This is a code that I am trying to run it:
>> head.h :
>> #include <mpi.h>
>> #include <stdio.h>
>> #include <cstdlib>
>> #include <iostream>
>> #include <string>
>> #include <sstream>
>> #include <fstream>
>> #include <vector>
>> #include <time.h>
>> using namespace std;
>> const char delim = ' ';
>> #include "Node.h"
>> #include "Shape.h"
>> #include "MPI_Process.h"
>> Node.h
>> #ifndef _NODE_H_
>> #define _NODE_H_
>> static const string Node_head="<\\Node>";
>> static const string Node_tail="<Node\\>";
>> class Node
>> public:
>>    int id;
>>    double x,y,z;
>>    ///---- Constructur, Destructor, Copy Constructor
>>    Node():x(0),y(0),z(0),id(0) {}
>>    ~Node() {}
>>    Node(int ID, double X=0, double Y=0, double Z=0) {id = ID; x=X; y=Y;
>> z=Z;}
>>    Node(const Node& anode) {id=anode.id <http://anode.id>; x=anode.x; y=
>> anode.y; z=anode.z;}
>>    //---- Mutator and Accessors
>>    void SetID(int ID) {id = ID;}
>>    void Set(int ID, double X=0, double Y=0, double Z=0) {id = ID; x=X;
>> y=Y; z=Z;}
>>    Node Get() {return *this;}
>>    //---- Serialization and De serialization
>>    void Serialize(stringstream& out)
>>        out << delim << Node_head << delim << this->id << delim << this->x
>> << delim
>>            << this->y << delim << this->z << delim <<Node_tail << '\n';
>>    void DeSerialize(stringstream& in)
>>        string tmp;
>>        in >> tmp >> this->id >>this->x >> this->y >> this->z >>tmp;
>> #endif
>> MPI_Process.h :
>> #ifndef _MPI_PROCESS_H_
>> #define _MPI_PROCESS_H_
>> ///---- Message Passing Tags
>> #define WORKTAG 1
>> #define LENTAG  3
>> #define DIETAG 2
>> #define SLAVE_GET_LENGTH 4
>> #define SLAVE_WORK_FINISH 5
>> class MPI_Process
>> private:
>>    int* source_ID;
>>    int* current_ID;
>>    int* num_Process ;
>>    int* length ;
>>    MPI::Status status;
>>    void Probe_Message_Length();
>> public:
>>    MPI_Process(void);
>>    ~MPI_Process(void);
>>    void Kill_Process(int rank);
>>    //-- Set & Get
>>    void Set_Num_Proc(int i);
>>    int  Get_Num_Proc();
>>    void Set_SourceID(int i);
>>    int Get_SourceID();
>>    void Set_CurrentID(int i);
>>    int  Get_CurrentID();
>>    int Send_Serializable_Object     ( void* Object ,
>>                                       int  rank    ,
>>                                       void (*pt2function)(void*
>> Object,stringstream& stream)
>>    int Recieve_Serializable_Object  ( void* Object,
>> #endif
>> Shape.h :
>> #ifndef _SHAPE_H_
>> #define _SHAPE_H_
>> static const string Shape_head="<\\Shape>";
>> static const string Shape_tail="<Shape\\>";
>> string    Int2Str(int num);
>> class Shape
>> public :
>>    int id;
>>    vector<Node> nodeset;
>>    Shape() : id(0) {}
>>    ~Shape() {nodeset.clear();}
>>    Shape(const Shape& aShape);
>>    void MakeShape();
>>    void Serialize(stringstream& out);
>>    void DeSerialize(stringstream& in);
>>    void Write2File()
>>        stringstream ss;
>>        ofstream out( ("Shape" + Int2Str(this->id)+".shp").c_str());
>>            this->Serialize(ss);
>>            out.write(ss.str().c_str(), ss.str().size());
>>        out.close();
>>        ss.clear();
>>    static void Wrapper_To_MPI_SEND (void* Object, stringstream& out);
>>    static void Wrapper_To_MPI_RECIVE (void* Object, stringstream& in);
>> #endif
>> MPI_Process.cpp :
>> #include "head.h"
>> #include <string.h>
>> MPI_Process::MPI_Process(void){}
>> MPI_Process::~MPI_Process(void){}
>> void MPI_Process::Set_Num_Proc(int i)
>>    this->num_Process = new int;
>>    *this->num_Process = i;
>> int MPI_Process::Get_Num_Proc()
>>    return *this->num_Process;
>> void MPI_Process::Set_SourceID(int i)
>>     this->source_ID  = new int;
>>     *this->source_ID = i;
>> int MPI_Process::Get_SourceID()
>>    return *this->source_ID;
>> void MPI_Process::Set_CurrentID(int i)
>>    this->current_ID = new int;
>>    *this->current_ID = i;
>> void MPI_Process::Probe_Message_Length()
>>    MPI::COMM_WORLD.Probe(*this->source_ID,WORKTAG,this->status);
>>    this->length = new int(status.Get_count(MPI::CHAR) );
>> int MPI_Process::Send_Serializable_Object(void* Object, int rank, void
>> (*pt2function)(void* Object,stringstream& stream))
>>    stringstream * stream;
>>    char* buffer;
>>          int message_length;
>>      stream = new stringstream();
>>      //-- Serialize      pt2function(Object,*stream);
>>      message_length = stream->str().length();
>>    buffer = new char[message_length];
>>          strcpy(buffer,stream->str().c_str());
>>    MPI::COMM_WORLD.Send(buffer,message_length,MPI::CHAR,rank,WORKTAG);
>>                    delete stream;
>>        delete[] buffer;
>>              return message_length ;
>> int MPI_Process::Recieve_Serializable_Object(void* Object, void
>> {      stringstream * stream;
>>    char* buffer;
>>            this->Probe_Message_Length();
>>      buffer = new char[ *this->length ];
>>              if(*this->length == 1 ) cout << buffer <<endl;
>>    MPI::COMM_WORLD.Recv(buffer,*this->length,MPI::CHAR, 0 ,WORKTAG);
>>      if(buffer[0] =='0')
>>                delete stream;
>>                delete[] buffer;
>>                      return 0;
>>    else
>>        stream->str(buffer);
>>        stream->clear();
>>                delete stream;
>>                delete[] buffer;
>>                                    return *this->length;
>> void MPI_Process::Kill_Process(int rank)
>>    char *buffer;
>>        buffer = new char[1];
>>        buffer[0]='0';
>>        cout << "Process No: " << rank << "is killed" << '\n';
>>        MPI::COMM_WORLD.Send(&buffer,1,MPI::CHAR,rank,WORKTAG);
>>        delete[] buffer;
>>  //MPI::COMM_WORLD.Sendrecv(&buffer,1,MPI::CHAR,rank,WORKTAG,&tmp,1,MPI::INT,rank,WORKTAG);
>> Shape.h :
>> #include "head.h"
>> Shape::Shape(const Shape& aShape)
>>    /*this->id = aShape.id;
>>      for(vector<Node>::iterator i=aShape.nodeset.begin() ;
>> i!=aShape.nodeset.end(); i++)
>>        this->nodeset.push_back(*i);*/
>>    stringstream ss;
>>    ss << num;
>>    return ss.str();
>> void Shape::MakeShape()
>>    Node n;
>>    for(register int i=0;i<10;i++)
>>        //n.Set(i,0.01*i,1.0*i,2.0*i);
>>        n.Set(rand()%100,rand()%100,rand()%100,rand()%100);
>>        this->nodeset.push_back(n);
>> void Shape::Serialize(stringstream& out)
>>    cout << "Start of Serialization Processes NO " <<
>> MPI::COMM_WORLD.Get_rank()    <<endl;
>>    out << Shape_head << '\n' <<delim << this->id << delim << (int)
>> this->nodeset.size() << '\n';
>>    for(vector<Node>::iterator i=this->nodeset.begin(); i!=
>> this->nodeset.end();i++)
>>        i->Serialize(out);
>>    out << Shape_tail  <<'\n' ;
>> void Shape::DeSerialize(stringstream& in)
>>    cout << "Start of DeSerialization Processes NO " <<
>>    string tmp;
>>    int    number_of_nodes;
>>    in >> tmp >> this->id >> number_of_nodes;
>>    this->nodeset.resize(number_of_nodes);
>> i!=this->nodeset.end();i++)
>>        i->DeSerialize(in);
>>    in >> tmp;   }
>> void Shape::Wrapper_To_MPI_SEND(void* Object, stringstream& out)
>>    Shape* myself = (Shape*) Object;
>>    myself->Serialize(out);
>> void Shape::Wrapper_To_MPI_RECIVE(void *Object, std::stringstream& in)
>>    myself->DeSerialize(in);
>>    myself->Write2File();
>> main.cpp :
>> #include "head.h"
>> void Slave()
>>    MPI_Process *slave_process = new MPI_Process();
>>      slave_process->Set_SourceID(0);
>>    slave_process->Set_CurrentID(MPI::COMM_WORLD.Get_rank());
>>      Shape shape;
>>    while(slave_process->Recieve_Serializable_Object( (void*) &shape,
>> Shape::Wrapper_To_MPI_RECIVE)  != 0)
>>        cout << "Slave No: " << MPI::COMM_WORLD.Get_size() << " Finished
>> Work." <<endl;
>>    cout << "Slave No: " << MPI::COMM_WORLD.Get_size() << " Quit." <<endl;
>>  void Master(vector<Shape>& shapeset)
>>    MPI_Process* master_Process = new MPI_Process();
>>      int check(0),rank(1),nproc,counter(0);
>>    master_Process ->Set_Num_Proc(MPI::COMM_WORLD.Get_size());
>>    master_Process->Set_CurrentID(0);
>>    master_Process->Set_SourceID(0);
>>    nproc = master_Process->Get_Num_Proc();
>>                          vector<Shape>::iterator i(shapeset.begin());
>>        cout << shapeset.size() << endl;
>>          for(counter; counter < (int) shapeset.size();counter++,rank++)
>>            if(i!=shapeset.end())
>>        if(rank > nproc-1) rank =1;
>>        cout << "Master Send a Message with Lenght of :" <<
>>        master_Process->Send_Serializable_Object((void*) &(*i) ,rank,
>> Shape::Wrapper_To_MPI_SEND)
>>        << " to CPU Rank:" << rank <<endl;
>>                i++;
>>    cout <<" Start of Turning off System!" << endl;
>>    for(rank=1; rank< nproc ;  ++rank)
>>            cout << "sending Kill Message to Proc: " << rank <<endl;
>>        master_Process->Kill_Process(rank);
>> int main(int argc, char ** argv)
>>    srand( (int) time(NULL));
>>    int rank,nproc,nwork;
>>    //--- Start of MPI CALL
>>      MPI::Status status;
>>    MPI::Init(argc,argv);
>>    nproc=MPI::COMM_WORLD.Get_size();
>>    rank = MPI::COMM_WORLD.Get_rank();
>>      if(rank==0)
>>        vector<Shape> shapeset;
>>        shapeset.resize(10000);
>>        int j=0;
>>        for( vector<Shape>::iterator i=shapeset.begin(); i!=shapeset.end();
>> i++, ++j)
>>            i->SetID(j);
>> i++)
>>            i->MakeShape();
>>              cout << "Shape Initialization Finished" << endl;
>>        cout << "Processor NO:  " << rank << " Started" <<endl;
>>        Master(shapeset);
>>    else
>>        Slave();
>>          MPI::Finalize();
>>    return 0;
> Burlen Loring
> Kitware, Inc.
> R&D Engineer
> 28 Corporate Drive
> Clifton Park, NY 12065-8662
> Phone: 518-371-3971 x137
Tel: 090-9807-2477
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080728/91028093/attachment.htm>
