[mpich-discuss] Killed by Signal 9!!!!???
Gholamreza Sobhaninejad
grsobhani at gmail.com
Sun Jul 27 20:23:31 CDT 2008
Dear All,
This is a prototype program which I am going to implement it in another
program. I want to send objects. The program works very well when 'shapeset'
is small. But when I increase number of CPU, and Shapeset size , I get the
following error message:
"rank 0 in job 12 localhost.localdomain_60694 caused collective abort of
all ranks
exit status of rank 0: killed by signal 9 "
I have a master process which works on Rank 0 and Slaves which are working
on Other ranks.
Master serialize (write all the information in a char buffer) a Shape object
and send it through MPI::Send. Slaves are reciving the Objects and
Deserialize it and call a function pointer to operate on the object.
Sorry the code is little bit long.
I really appreciate your help. I need some advices. I am working on
Linux-Fedora with dual core cpu.
Sincerely,
Gholamreza Sobhaninejad(Reza)
PhD candidate, University of Tokyo
Earthquake Research Institute
Tel: 090-9807-2477
This is a code that I am trying to run it:
head.h :
#include <mpi.h>
#include <stdio.h>
#include <cstdlib>
#include <iostream>
#include <string>
#include <sstream>
#include <fstream>
#include <vector>
#include <time.h>
using namespace std;
const char delim = ' ';
#include "Node.h"
#include "Shape.h"
#include "MPI_Process.h"
Node.h
#ifndef _NODE_H_
#define _NODE_H_
static const string Node_head="<\\Node>";
static const string Node_tail="<Node\\>";
class Node
public:
int id;
double x,y,z;
///---- Constructur, Destructor, Copy Constructor
Node():x(0),y(0),z(0),id(0) {}
~Node() {}
Node(int ID, double X=0, double Y=0, double Z=0) {id = ID; x=X; y=Y;
z=Z;}
Node(const Node& anode) {id=anode.id; x=anode.x; y= anode.y; z=anode.z;}
//---- Mutator and Accessors
void SetID(int ID) {id = ID;}
void Set(int ID, double X=0, double Y=0, double Z=0) {id = ID; x=X; y=Y;
z=Z;}
Node Get() {return *this;}
//---- Serialization and De serialization
void Serialize(stringstream& out)
out << delim << Node_head << delim << this->id << delim << this->x
<< delim
<< this->y << delim << this->z << delim <<Node_tail << '\n';
void DeSerialize(stringstream& in)
string tmp;
in >> tmp >> this->id >>this->x >> this->y >> this->z >>tmp;
#endif
MPI_Process.h :
#ifndef _MPI_PROCESS_H_
#define _MPI_PROCESS_H_
///---- Message Passing Tags
#define WORKTAG 1
#define LENTAG 3
#define DIETAG 2
#define SLAVE_GET_LENGTH 4
#define SLAVE_WORK_FINISH 5
class MPI_Process
private:
int* source_ID;
int* current_ID;
int* num_Process ;
int* length ;
MPI::Status status;
void Probe_Message_Length();
public:
MPI_Process(void);
~MPI_Process(void);
void Kill_Process(int rank);
//-- Set & Get
void Set_Num_Proc(int i);
int Get_Num_Proc();
void Set_SourceID(int i);
int Get_SourceID();
void Set_CurrentID(int i);
int Get_CurrentID();
int Send_Serializable_Object ( void* Object ,
int rank ,
void (*pt2function)(void*
Object,stringstream& stream)
int Recieve_Serializable_Object ( void* Object,
#endif
Shape.h :
#ifndef _SHAPE_H_
#define _SHAPE_H_
static const string Shape_head="<\\Shape>";
static const string Shape_tail="<Shape\\>";
string Int2Str(int num);
class Shape
public :
int id;
vector<Node> nodeset;
Shape() : id(0) {}
~Shape() {nodeset.clear();}
Shape(const Shape& aShape);
void MakeShape();
void Serialize(stringstream& out);
void DeSerialize(stringstream& in);
void Write2File()
stringstream ss;
ofstream out( ("Shape" + Int2Str(this->id)+".shp").c_str());
this->Serialize(ss);
out.write(ss.str().c_str(), ss.str().size());
out.close();
ss.clear();
static void Wrapper_To_MPI_SEND (void* Object, stringstream& out);
static void Wrapper_To_MPI_RECIVE (void* Object, stringstream& in);
#endif
MPI_Process.cpp :
#include "head.h"
#include <string.h>
MPI_Process::MPI_Process(void){}
MPI_Process::~MPI_Process(void){}
void MPI_Process::Set_Num_Proc(int i)
this->num_Process = new int;
*this->num_Process = i;
int MPI_Process::Get_Num_Proc()
return *this->num_Process;
void MPI_Process::Set_SourceID(int i)
this->source_ID = new int;
*this->source_ID = i;
int MPI_Process::Get_SourceID()
return *this->source_ID;
void MPI_Process::Set_CurrentID(int i)
this->current_ID = new int;
*this->current_ID = i;
void MPI_Process::Probe_Message_Length()
MPI::COMM_WORLD.Probe(*this->source_ID,WORKTAG,this->status);
this->length = new int(status.Get_count(MPI::CHAR) );
int MPI_Process::Send_Serializable_Object(void* Object, int rank, void
(*pt2function)(void* Object,stringstream& stream))
stringstream * stream;
char* buffer;
int message_length;
stream = new stringstream();
//-- Serialize
pt2function(Object,*stream);
message_length = stream->str().length();
buffer = new char[message_length];
strcpy(buffer,stream->str().c_str());
MPI::COMM_WORLD.Send(buffer,message_length,MPI::CHAR,rank,WORKTAG);
delete stream;
delete[] buffer;
return message_length ;
int MPI_Process::Recieve_Serializable_Object(void* Object, void
char* buffer;
this->Probe_Message_Length();
buffer = new char[ *this->length ];
if(*this->length == 1 ) cout << buffer <<endl;
MPI::COMM_WORLD.Recv(buffer,*this->length,MPI::CHAR, 0 ,WORKTAG);
if(buffer[0] =='0')
delete stream;
delete[] buffer;
return 0;
else
stream->str(buffer);
stream->clear();
delete stream;
delete[] buffer;
return *this->length;
void MPI_Process::Kill_Process(int rank)
char *buffer;
buffer = new char[1];
buffer[0]='0';
cout << "Process No: " << rank << "is killed" << '\n';
MPI::COMM_WORLD.Send(&buffer,1,MPI::CHAR,rank,WORKTAG);
delete[] buffer;
//MPI::COMM_WORLD.Sendrecv(&buffer,1,MPI::CHAR,rank,WORKTAG,&tmp,1,MPI::INT,rank,WORKTAG);
Shape.h :
#include "head.h"
Shape::Shape(const Shape& aShape)
/*this->id = aShape.id;
for(vector<Node>::iterator i=aShape.nodeset.begin() ;
i!=aShape.nodeset.end(); i++)
this->nodeset.push_back(*i);*/
stringstream ss;
ss << num;
return ss.str();
void Shape::MakeShape()
Node n;
for(register int i=0;i<10;i++)
//n.Set(i,0.01*i,1.0*i,2.0*i);
n.Set(rand()%100,rand()%100,rand()%100,rand()%100);
this->nodeset.push_back(n);
void Shape::Serialize(stringstream& out)
cout << "Start of Serialization Processes NO " <<
MPI::COMM_WORLD.Get_rank() <<endl;
out << Shape_head << '\n' <<delim << this->id << delim << (int)
this->nodeset.size() << '\n';
for(vector<Node>::iterator i=this->nodeset.begin(); i!=
this->nodeset.end();i++)
i->Serialize(out);
out << Shape_tail <<'\n' ;
void Shape::DeSerialize(stringstream& in)
cout << "Start of DeSerialization Processes NO " <<
string tmp;
int number_of_nodes;
in >> tmp >> this->id >> number_of_nodes;
this->nodeset.resize(number_of_nodes);
i!=this->nodeset.end();i++)
i->DeSerialize(in);
in >> tmp;
void Shape::Wrapper_To_MPI_SEND(void* Object, stringstream& out)
Shape* myself = (Shape*) Object;
myself->Serialize(out);
void Shape::Wrapper_To_MPI_RECIVE(void *Object, std::stringstream& in)
myself->DeSerialize(in);
myself->Write2File();
main.cpp :
#include "head.h"
void Slave()
MPI_Process *slave_process = new MPI_Process();
slave_process->Set_SourceID(0);
slave_process->Set_CurrentID(MPI::COMM_WORLD.Get_rank());
Shape shape;
while(slave_process->Recieve_Serializable_Object( (void*) &shape,
Shape::Wrapper_To_MPI_RECIVE) != 0)
cout << "Slave No: " << MPI::COMM_WORLD.Get_size() << " Finished
Work." <<endl;
cout << "Slave No: " << MPI::COMM_WORLD.Get_size() << " Quit." <<endl;
void Master(vector<Shape>& shapeset)
MPI_Process* master_Process = new MPI_Process();
int check(0),rank(1),nproc,counter(0);
master_Process ->Set_Num_Proc(MPI::COMM_WORLD.Get_size());
master_Process->Set_CurrentID(0);
master_Process->Set_SourceID(0);
nproc = master_Process->Get_Num_Proc();
vector<Shape>::iterator i(shapeset.begin());
cout << shapeset.size() << endl;
for(counter; counter < (int) shapeset.size();counter++,rank++)
if(i!=shapeset.end())
if(rank > nproc-1) rank =1;
cout << "Master Send a Message with Lenght of :" <<
master_Process->Send_Serializable_Object((void*) &(*i) ,rank,
Shape::Wrapper_To_MPI_SEND)
<< " to CPU Rank:" << rank <<endl;
i++;
cout <<" Start of Turning off System!" << endl;
for(rank=1; rank< nproc ; ++rank)
cout << "sending Kill Message to Proc: " << rank <<endl;
master_Process->Kill_Process(rank);
int main(int argc, char ** argv)
srand( (int) time(NULL));
int rank,nproc,nwork;
//--- Start of MPI CALL
MPI::Status status;
MPI::Init(argc,argv);
nproc=MPI::COMM_WORLD.Get_size();
rank = MPI::COMM_WORLD.Get_rank();
if(rank==0)
vector<Shape> shapeset;
shapeset.resize(10000);
int j=0;
for( vector<Shape>::iterator i=shapeset.begin(); i!=shapeset.end();
i++, ++j)
i->SetID(j);
i++)
i->MakeShape();
cout << "Shape Initialization Finished" << endl;
cout << "Processor NO: " << rank << " Started" <<endl;
Master(shapeset);
else
Slave();
MPI::Finalize();
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080728/2db8c0d7/attachment.htm>
