[mpich-discuss] Multiple MPI_Comm_spawn to a single multicore host
    Roberto Fichera
    kernel at tekno-soft.it
    Fri Jul 18 03:06:25 CDT 2008
Rajeev Thakur ha scritto:
> It is supposed to work even with multiple processes per node. Are you
> creating the multiple processes with a single MPI_Comm_spawn (and maxprocs
> set appropriately) or with multiple calls to MPI_Comm_spawn. It should work
> either way.
I use only one MPI_Comm_spawn() per slave for spawning *only* one slave
process. If the target node
is the master, I see the problem.
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Roberto Fichera
>> Sent: Tuesday, July 15, 2008 10:29 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] Multiple MPI_Comm_spawn to a single
>> multicore host
>> Hi All on the list,
>> I'm using the MPI_Comm_spawn() to dynamically distribute the
>> jobs in our
>> nodes. Everything
>> works fine until I use one job per node even if the target node is a
>> multicore/smp machine.
>> Whenever I start to spawn multiple jobs, as the number of cpus on the
>> target machine, than I
>> start to see crashes on the MPI application, maybe due to the mpd
>> shutdown caused by the first
>> MPI_Finalize() issued by the slave. So, does anyone know how
>> to handle
>> correctly such distribution.
>> I'm currently using MPICH2 v1.0.7 within a Fedora 8 x86_64 OS.
>> Thanks in advance.
>> Roberto Fichera.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080718/034c53bb/attachment.htm>
