[mpich-discuss] Why is my quad core slower than cluster
    David LeBard
    david.lebard at asu.edu
    Thu Jul 17 12:56:15 CDT 2008
If you people are going to fight like children and clog up my email with
garbage like this, at least learn how to spell.
On Thu, Jul 17, 2008 at 10:20 AM, chong tan <chong_guan_tan at yahoo.com>
wrote:
> grow up Gib.  there is no NDA between empoer and employee in the USA.
> maybe there is in New Zealand, but I certainly don't know anything about New
> Zealand.  I only know taht when a person buy a computer in NZ, the computer
> user count in NZ just doubled.
> tan
> --- On *Wed, 7/16/08, Gib Bogle <g.bogle at auckland.ac.nz>* wrote:
> From: Gib Bogle <g.bogle at auckland.ac.nz>
> Subject: Re: [mpich-discuss] Why is my quad core slower than cluster
> To: mpich-discuss at mcs.anl.gov
> Date: Wednesday, July 16, 2008, 6:31 PM
> And are we to believe that your employer's NDA doesn't permit you to say
> WHICH answer is wrong?  Whew!
> Gib
> chong tan wrote:
> > Just FYI,
> > from my knowledge, at least 1 answer to the question in that thread is
> > absolutely wrong, according to HW information on hand.  Some of the info
> > in that thread are not applicable across the board, and the original
> > question : threaded application, is not answered.
> > whether to use numactl on NUMA system is situation dependent.  In
> > general, numactl is bad if you over subscribe the system.
> > tan
> > --- On *Tue, 7/15/08, Robert Kubrick /<robertkubrick at gmail.com>/*
> wrote:
> >     From: Robert Kubrick <robertkubrick at gmail.com>
> >     Date: Tuesday, July 15, 2008, 4:06 PM
> >     A recent (long) discussion about numactl and taskset on the beowulf
> >     mailing list:
> >     http://www.beowulf.org/archive/2008-June/021810.html
> >     On Jul 15, 2008, at 1:35 PM, chong tan wrote:
> >>     Eric,
> >>     I know you are referring me as the one not sharing.  I am no
> >>     expert on MP, but someone who have done his homeworks.  I like to
> >>     share, but the NDAs and company policy say no.
> >>     You have good points and did some good experiements.  That is what
> >>     I expect most MP designers and users to have done at the first
> place.
> >>     There answers to the original question are simple :
> >>     - on 2Xquad, you have one memory system, while on cluster, you
> >>     have 8 memory systems, the total bandwidth favor the cluster
> >>     considerably.
> >>     - on cluster, there is not way for the process to be context
> >>     switched, while that can happen on 2XQuad.  When this happens,
> >>     live is bad.
> >>     - The only thing that favor the SMP is the cost of communication
> >>     and shared memory.
> >>     There are more factors, Thea rt is balancing them to your favor.
> >>     In a way, the X86 Quad are not designed to let us load it up with
> >>     fat adnd heavy processes.  That is what I have been saying all
> >>     along: know your HW first.  Your MP solution should come second.
> >>     Whatever utilities you can find will help put the solution
> together.
> >>     So, the problem is not MPI in this case.
> >>     tan
> >>     --- On *Mon, 7/14/08, Eric A. Borisch /<eborisch at ieee.org
> >>     <mailto:eborisch at ieee.org>>/* wrote:
> >>         From: Eric A. Borisch <eborisch at ieee.org
> >>         cluster
> <mailto:mpich-discuss at mcs.anl.gov>
> >>         Date: Monday, July 14, 2008, 9:36 PM
> >>         Gus,
> >>         Information sharing is truly the point of the mailing list.
> >>         Useful messages should ask questions or provide answers! :)
> >>         Someone mentioned STREAM benchmarks (memory BW benchmarks) a
> >>         little while back. I did these when our new system came in a
> >>         while ago, so I dug them back out.
> >>         This (STREAM) can be compiled to use MPI, but it is only a
> >>         synchronization tool, the benchmark is still a memory bus test
> >>         (each task is trying to run through memory, but this is not an
> >>         MPI communication test.)
> >>         My results on a dual E5472 machine (Two Quad-core 3Ghz
> >>         packages; 1600MHz bus; 8 total cores)
> >>         Results (each set are [1..8] processes in order),
> >>         double-precision array size = 20,000,000, run through 10
> times.
> >>         Function     Rate (MB/s)  Avg time   Min time  Max time
> >>         Copy:       2962.6937      0.1081      0.1080      0.1081
> >>         Copy:       5685.3008      0.1126      0.1126      0.1128
> >>         Copy:       5484.6846      0.1751      0.1750      0.1751
> >>         Copy:       7085.7959      0.1809      0.1806      0.1817
> >>         Copy:       5981.6033      0.2676      0.2675      0.2676
> >>         Copy:       7071.2490      0.2718      0.2715      0.2722
> >>         Copy:       6537.4934      0.3427      0.3426      0.3428
> >>         Copy:       7423.4545      0.3451      0.3449      0.3455
> >>         Scale:      3011.8445      0.1063      0.1062      0.1063
> >>         Scale:      5675.8162      0.1128      0.1128      0.1129
> >>         Scale:      5474.8854      0.1754      0.1753      0.1754
> >>         Scale:      7068.6204      0.1814      0.1811      0.1819
> >>         Scale:      5974.6112      0.2679      0.2678      0.2680
> >>         Scale:      7063.8307      0.2721      0.2718      0.2725
> >>         Scale:      6533.4473      0.3430      0.3429      0.3431
> >>         Scale:      7418.6128      0.3453      0.3451      0.3456
> >>         Add:        3184.3129      0.1508      0.1507      0.1508
> >>         Add:        5892.1781      0.1631      0.1629      0.1633
> >>         Add:        5588.0229      0.2577      0.2577      0.2578
> >>         Add:        7275.0745      0.2642      0.2639      0.2646
> >>         Add:        6175.7646      0.3887      0.3886      0.3889
> >>         Add:        7262.7112      0.3970      0.3965      0.3976
> >>         Add:        6687.7658      0.5025      0.5024      0.5026
> >>         Add:        7599.2516      0.5057      0.5053      0.5062
> >>         Triad:      3224.7856      0.1489      0.1488      0.1489
> >>         Triad:      6021.2613      0.1596      0.1594      0.1598
> >>         Triad:      5609.9260      0.2567      0.2567      0.2568
> >>         Triad:      7293.2790      0.2637      0.2633      0.2641
> >>         Triad:      6185.4376      0.3881      0.3880      0.3881
> >>         Triad:      7279.1231      0.3958      0.3957      0.3961
> >>         Triad:      6691.8560      0.5022      0.5021      0.5022
> >>         Triad:      7604.1238      0.5052      0.5050      0.5057
> >>         These work out to (~):
> >>         1x
> >>         1.9x
> >>         1.8x
> >>         2.3x
> >>         1.9x
> >>         2.2x
> >>         2.1x
> >>         2.4x
> >>         for [1..8] cores.
> >>         As you can see, it doesn't take eight cores to saturate
> the
> >>         bus, even with a 1600MHz bus. Four of the eight cores running
> >>         does this trick.
> >>         With all that said, there are still advantages to be had with
> >>         the multicore chipsets, but only if you're not blowing
> full
> >>         tilt through memory. If it can fit the problem, do more inside
> >>         a loop rather than running multiple loops over the same
> memory.
> >>         For reference, here's what using the osu_mbw_mr test (from
> >>         MVAPICH2 1.0.2; I also have a cluster running nearby :)
> >>         compiled on MPICH2 (1.0.7rc1 with nemesis provides this
> >>         performance from one/two/four pairs (2/4/8 processes) of
> >>         producer/consumers:
> >>         # OSU MPI Multi BW / Message Rate Test (Version 1.0)
> >>         # [ pairs: 1 ] [ window size: 64 ]
> >>         #  Size    MB/sec    Messages/sec
> >>               1      1.08   1076540.83
> >>               2      2.14   1068102.24
> >>               4      3.99    997382.24
> >>               8      7.97    996419.66
> >>              16     15.95    996567.63
> >>              32     31.67    989660.29
> >>              64     62.73    980084.91
> >>             128    124.12    969676.18
> >>             256    243.59    951527.62
> >>             512    445.52    870159.34
> >>            1024    810.28    791284.80
> >>            2048   1357.25    662721.78
> >>            4096   1935.08    472431.28
> >>            8192   2454.29    299596.49
> >>           16384   2717.61    165869.84
> >>           32768   2900.23     88507.85
> >>           65536   2279.71     34785.63
> >>          131072   2540.51     19382.53
> >>          262144   1335.16      5093.21
> >>          524288   1364.05      2601.72
> >>         1048576   1378.39      1314.53
> >>         2097152   1380.78       658.41
> >>         4194304   1343.48       320.31
> >>         # [ pairs: 2 ] [ window size: 64 ]
> >>               1      2.15   2150580.48
> >>               2      4.22   2109761.12
> >>               4      7.84   1960742.53
> >>               8     15.80   1974733.92
> >>              16     31.38   1961100.64
> >>              32     62.32   1947654.32
> >>              64    123.39   1928000.11
> >>             128    243.19   1899957.22
> >>             256    475.32   1856721.12
> >>             512    856.90   1673642.10
> >>            1024   1513.19   1477721.26
> >>            2048   2312.91   1129351.07
> >>            4096   2891.21    705861.12
> >>            8192   3267.49    398863.98
> >>           16384   3400.64    207558.54
> >>           32768   3519.74    107413.93
> >>           65536   3141.80     47940.04
> >>          131072   3368.65     25700.76
> >>          262144   2211.53      8436.31
> >>          524288   2264.90      4319.95
> >>         1048576   2282.69      2176.94
> >>         2097152   2250.72      1073.23
> >>         4194304   2087.00       497.58
> >>         # [ pairs: 4 ] [ window size: 64 ]
> >>               1      3.65   3651934.64
> >>               2      8.16   4080341.34
> >>               4     15.66   3914908.02
> >>               8     31.32   3915621.85
> >>              16     62.67   3916764.51
> >>              32    124.37   3886426.18
> >>              64    246.38   3849640.84
> >>             128    486.39   3799914.44
> >>             256    942.40   3681232.25
> >>             512   1664.21   3250414.19
> >>            1024   2756.50   2691891.86
> >>            2048   3829.45   1869848.54
> >>            4096   4465.25   1090148.56
> >>            8192   4777.45    583184.51
> >>           16384   4822.75    294357.30
> >>           32768   4829.77    147392.80
> >>           65536   4556.93     69533.18
> >>          131072   4789.32     36539.60
> >>          262144   3631.68     13853.75
> >>          524288   3679.31      7017.72
> >>         1048576   3553.61      3388.99
> >>         2097152   3113.12      1484.45
> >>         4194304   2452.69       584.77
> >>         So from a messaging standpoint, you can see that you squeeze
> >>         more data through with more processes; I'd guess that this
> is
> >>         because there's processing to be done within MPI to move
> the
> >>         data, and a lot of the bookkeeping steps probably cache well
> >>         (updating the same status structure on a communication
> >>         multiple times; perhaps reusing the structure for subsequent
> >>         transfers and finding it still in cache) so the performance
> >>         scaling is not completely FSB bound.
> >>         I'm sure there's plenty of additional things that
> could be
> >>         done here to test different CPU to process layouts, etc, but
> >>         in testing my own real-world code, I've found that,
> >>         unfortunately, "it depends." I have some code that
> nearly
> >>         scales linearly (multiple computationally expensive operations
> >>         inside the innermost loop) and some that scales like the
> >>         STREAM results above ("add one to the next 20 million
> points") ...
> >>         As always, your mileage may vary. If your speedup looks like
> >>         the STREAM numbers above, you're likely memory bound. Try
> to
> >>         reformulate your problem to go through memory slower but with
> >>         more done each pass, or invest in a cluster. At some point --
> >>         for some problems -- you can't beat more memory busses!
> >>         Cheers,
> >>          Eric Borisch
> >>          borisch.eric at mayo.edu <mailto:borisch.eric at mayo.edu>
> >>          MRI Research
> >>          Mayo Clinic
> >>         On Mon, Jul 14, 2008 at 9:48 PM, Gus Correa
> >>         <gus at ldeo.columbia.edu
> <mailto:gus at ldeo.columbia.edu>> wrote:
> >>             Hello Sami and list
> >>             Oh, well, as you see, an expert who claims to know the
> >>             answers to these problems
> >>             seems not to be willing to share these answers with less
> >>             knowledgeable MPI users like us.
> >>             So, maybe we can find the answers ourselves, not by
> >>             individual "homework" brainstorming,
> >>             but through community collaboration and generous
> >>             information sharing,
> >>             which is the hallmark of this mailing list.
> >>             I Googled around today to find out how to assign MPI
> >>             processes to specific processors,
> >>             and I found some interesting information on how to do it.
> >>             Below is a link to a posting from the computational fluid
> >>             dynamics (CFD) community that may be of interest.
> >>             Not surprisingly, they are struggling with the same type
> >>             of problems all of us have,
> >>             including how to tie MPI processes to specific processors:
> >>            http://openfoam.cfd-online.com/cgi-bin/forum/board-auth.cgi?file=/1/5949.html#POST18006
> <http://openfoam.cfd-online.com/cgi-bin/forum/board-auth.cgi?file=/1/5949.html#POST18006>
> >>             I would summarize these problems as related to three types
> >>             of bottleneck:
> >>             1) Multicore processor bottlenecks (standalone machines
> >>             and clusters)
> >>             2) Network fabric bottlenecks (clusters)
> >>             3) File system bottlenecks (clusters)
> >>             All three types of problems are due to contention for some
> >>             type of system resource
> >>             by the MPI processes that take part in a
> computation/program.
> >>             Our focus on this thread, started by Zach, has been on
> >>             problem 1),
> >>             although most of us may need to look into problems 2) and
> >>             3) sooner or later.
> >>             (I have all the three of them already!)
> >>             The CFD folks use MPI as we do.
> >>             They seem to use another MPI flavor, but the same problems
> >>             are there.
> >>             The problems are not caused by MPI itself, but they become
> >>             apparent when you run MPI programs.
> >>             That has been my experience too.
> >>             As for how to map the MPI processes to specific processors
> >>             (or cores),
> >>             the key command seems to be "taskset", as my
> googling
> >>             afternoon showed.
> >>             Try "man taskset" for more info.
> >>             For a standalone machine like yours, something like the
> >>             command line below should work to
> >>             force execution on "processors" 0 and 2 (which
> in my case
> >>             are two different physical CPUs):
> >>             mpiexec -n 2 taskset -c 0,2  my_mpi_program
> >>             You need to check on your computer ("more
> /proc/cpuinfo")
> >>             what are the exact "processor" numbers that
> correspond to
> >>             separate physical CPUs. Most likely they are the even
> >>             numbered processors only, or the odd numbered only,
> >>             since you have dual-core CPUs (integers module 2), with
> >>             "processors" 0,1 being the four
> >>             cores of the first physical CPU, "processors"
> 2,3 the
> >>             cores of the second physical CPU, and so on.
> >>             At least, this is what I see on my dual-core
> >>             dual-processor machine.
> >>             I would say for quad-cores the separate physical CPUs
> >>             would be processors 0,4,8, etc,
> >>             or 1,5,7, etc, and so on (integers module 4), with
> >>             "processors" 0,1,2,3 being the four cores
> >>             in the first physical CPU, and so on.
> >>             In /proc/cpuinfo look for the keyword
> "processor".
> >>             These are the numbers you need to use in "taskset
> -c".
> >>             However, other helpful information comes in the keywords
> >>             "physical id",
> >>             "core id", "siblings", and "cpu
> cores".
> >>             They will allow you to map cores and physical CPUs to
> >>             the "processor" number.
> >>             The "taskset"  command line above worked in one
> of my
> >>             standalone multicore machines,
> >>             and I hope a variant of it will work on your machine also.
> >>             It works with the "mpiexec" that comes with the
> MPICH
> >>             distribution, and also with
> >>             the "mpiexec" associated to the Torque/PBS batch
> system,
> >>             which is nice for clusters as well.
> >>             "Taskset" can change the default behavior of the
> Linux
> >>             scheduler, which is to allow processes to
> >>             be moved from one core/CPU to another during execution.
> >>             The scheduler does this to ensure optimal CPU use (i.e.
> >>             load balance).
> >>             With taskset you can force execution to happen on the
> >>             cores you specify on the command line,
> >>             i.e. you can force the so called "CPU affinity"
> you wish.
> >>             Note that the "taskset" man page uses both the
> terms "CPU"
> >>             and "processor", and doesn't use the term
> "core",
> >>             which may be  a bit confusing. Make no mistake,
> >>             "processor" and "CPU" there stand for
> what we've been
> >>             calling "core" here.
> >>             Other postings that you may find useful on closely related
> >>             topics are:
> >>            http://www.ibm.com/developerworks/linux/library/l-scheduler/
> <http://www.ibm.com/developerworks/linux/library/l-scheduler/>
> >>            http://www.cyberciti.biz/tips/setting-processor-affinity-certain-task-or-process.html
> <http://www.cyberciti.biz/tips/setting-processor-affinity-certain-task-or-process.html>
> >>             I hope this helps,
> >>             Still, we have a long way to go to sort out how much of
> >>             the multicore bottleneck can
> >>             be ascribed to lack of memory bandwidth, and how much may
> >>             be  perhaps associated to how
> >>             memcpy is compiled by different compilers,
> >>             or if there are other components of this problem that we
> >>             don't see now.
> >>             Maybe our community won't find a solution to
> Zach's
> >>             problem: "Why is my quad core slower than
> cluster?"
> >>             However, I hope that through collaboration, and by sharing
> >>             information,
> >>             we may be able to nail down the root of the problem,
> >>             and perhaps to find ways to improve the alarmingly bad
> >>             performance
> >>             some of us have reported on multicore machines.
> >>             Gus Correa
> >>             Gustavo J. Ponce Correa, PhD - Email:
> >>             gus at ldeo.columbia.edu <mailto:gus at ldeo.columbia.edu>
> >>             Lamont-Doherty Earth Observatory - Columbia University
> >>             P.O. Box 1000 [61 Route 9W] - Palisades, NY, 10964-8000 -
> USA
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080717/298e5d61/attachment.htm>
