[mpich-discuss] compiling MPICH2 with intel compilers
    Vlad Cojocaru
    Vlad.Cojocaru at eml-r.villa-bosch.de
    Wed Jul 16 03:47:06 CDT 2008
Dear MPICH2 users,
I am trying to build a parallel version of AMBER10 (a molecular dynamics
package) with MPICH2.
I downloaded the mpich2 from your site, I compiled it with the intel
compiler suite 10.1. Apparently everything went smoothly (the tests from
the mpich2 installation guide were correctly executed). However after I
successfully compiled AMBER10 I tried to run the tests and I got the
error below which obviously comes from the mpich2 build. I used the
correct mpiexec script when executing my application, and apparently I
have to interference from a pre-installed mpich.
Looking back at the configuration logfile from the mpich2 compilation
(see attached) I noticed some errors. Could you please take a look at
the config.log attached and tell me if you see anything obviously wrong.
I also attached the compilation flags I set as environmental variables
(maybe there is something wrong there). Also, if you have any idea why I
get the error below, I would be grateful for any advices.
Thanks in advance
Best wishes
vlad
--------------------------------------------error upo testing
export
TESTsander=/scratch/node-06-01/cojocavd/Software/amber10_intel_mpich2/exe/sander.MPI;
make test.sander.BASIC
make[1]: Entering directory
`/exports/scratch/cojocavd/Software/amber10_intel_mpich2/test'
cd cytosine && ./Run.cytosine
Fatal error in MPI_Comm_rank: Invalid communicator, error stack:
MPI_Comm_rank(107): MPI_Comm_rank(comm=0x0, rank=0x14150f0) failed
MPI_Comm_rank(65).: Invalid communicator[cli_0]: aborting job:
MPI_Comm_rank(65).: Invalid communicator[cli_1]: aborting job:
MPI_Comm_rank(65).: Invalid communicator[cli_2]: aborting job:
MPI_Comm_rank(65).: Invalid communicator[cli_3]: aborting job:
rank 3 in job 10  node-06-01_60831   caused collective abort of all ranks
 exit status of rank 3: return code 1
rank 1 in job 10  node-06-01_60831   caused collective abort of all ranks
 exit status of rank 1: return code 1
rank 0 in job 10  node-06-01_60831   caused collective abort of all ranks
 exit status of rank 0: return code 1
 ./Run.cytosine:  Program error
make[1]: *** [test.sander.BASIC] Error 1
make[1]: Leaving directory
make: *** [test.sander.BASIC.MPI] Error 2
Dr. Vlad Cojocaru
EML Research gGmbH
Schloss-Wolfsbrunnenweg 33
69118 Heidelberg
Tel: ++49-6221-533266
Fax: ++49-6221-533298
e-mail:Vlad.Cojocaru[at]eml-r.villa-bosch.de
http://projects.villa-bosch.de/mcm/people/cojocaru/
EML Research gGmbH
Amtgericht Mannheim / HRB 337446
Managing Partner: Dr. h.c. Klaus Tschira
Scientific and Managing Director: Prof. Dr.-Ing. Andreas Reuter
http://www.eml-r.org
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080716/d24690bd/attachment.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080716/d24690bd/attachment.txt>
