[mpich-discuss] Why is my quad core slower than cluster
Gaetano Bellanca gaetano.bellanca at unife.it
Mon Jul 14 07:01:34 CDT 2008
Hello to everybody,
we have more or less the same problems. We are developing a FDTD code
for electromagnetic simulation in FORTRAN. The code is mainly based
on a 3 loops used to compute the electric field components, and 3
identical loops to compute the magnetic field components.
We are using a small PC cluster made with 10 PIV 3GHz connected with
a 1Gbit/s ethernet LAN built some years ago, and a Intel Vernonia 2
procesors / 4 core each (total 8 core). The processors are Intel Xeon
E5345  @ 2.33GHz.
We are using the Intel 10.1 fortran compiler (compiler options as
indicated in the manual for machine optimization, with -O3), ubuntu
7.10 (kernel 2.6.22-14 generic on the cluster, kernel 2.6.22-14
server on the multiprocessor machine).
mpich2 is compiled with nemesis, and we are still with the 2.1.06p1
(still no time to upgrade to  the last version)
Testing the code for a (not too big, to keep the overall time
limited) simulation (85184 variables 44x44x44 cells, 51000 temporal
iterations) we had  a good scaling on the cluster. On the total
simulation time (with parallel and sequential operations mixed) we
have a speed-up of 8.5 using 10PEs ( 6.2 with 9, 8.2 with 8, 5 with
7, 5.8 with 6 etc ...).
The same simulation has been run on the 2PEs/quad core machine but we
didn't have good performances.
The speed up is 2 if we run mpiexec -n 2 .... as the domain is
divided between the two processors which seems to work independently.
But, by increasing the number of processors (core) used, running the
simulation with .n 3, -n 4 etc ... we have a speed-up of 2.48 with 4
cores (2 on each PE), but only 2.6 with 8 PEs.
We also tried to use -parallel or -openmp (limiting the openmp
directives only in the loops of field computations), without
obtaining significant changes in the performances, both running with
mpiexec -n 1 or mpiexec -n 2 (trying to mix mpi and openmp).
Our idea is that we have serious problems in managing the shared
resources for memory access, but we have not expertise on that, and
we could be totally wrong.
Regards.
Gaetano
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080714/61cbde9d/attachment.htm>
