[mpich-discuss] RE: [mpich2-dev] running MPICH as a cluster on Windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Jul 11 10:44:21 CDT 2008
 For setting up MPICH2 on a cluster, install MPICH2 on all the nodes and
use mpiexec (with the "-machinefile" option) to launch your MPI job. You
can find details on the various options available with mpiexec in the
windows developer's guide (available at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
docs).
 Make sure that you have firewall turned off (or see "Runtime environment"
--> "Firewalls" section to configure the windows firewall for MPICH2) on
all the nodes
 Let us know if you need any further assistance.
(PS: The mailing list for discussions is mpich-discuss)
Jayesh
  _____
From: owner-mpich2-dev at mcs.anl.gov [mailto:owner-mpich2-dev at mcs.anl.gov]
On Behalf Of Rebecca
Sent: Friday, July 11, 2008 10:28 AM
To: mpich2-dev at mcs.anl.gov
Subject: [mpich2-dev] running MPICH as a cluster on Windows
Greetings All!
I am taking a class in parallel computing class this summer at UHD.  Does
anyone have instructions for running the Windows version of MPICH as a
cluster?  The install instructions seem to install an emulation of a
cluster.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080711/c74a09d8/attachment.htm>
