[mpich-discuss] .pg files in mpich2
Gus Correa gus at ldeo.columbia.edu
Thu Jul 10 20:04:51 CDT 2008
Hello
Maybe using the -configfile option of mpiexec?
"man mpiexec" shows the details.
I used to run mpich1 MPMD jobs, with .pg files to assign
different executables to different processors/computers.
It looks like to me  -configfile in mpich2 is the replacement
(or a generalization with a new syntax) of the old .pg files.
I hope it helps.
Gus Correa
Matthew Bettencourt wrote:
> That doesnt work, i want to run valgrind on Rank=0, what i used to do
> is create a .pg file and then run
> valgrind options ./myjob
> and rank0 would run through valgrind.
> The same sort of thing, i could edit the myjob.pg file to run a script
> for one rank in particular
> Thanks
> M
> Rusty Lusk wrote:
>> In MPICH2 you would say
>>    mpiexec -n 4 myjob
>> On Thursday,Jul 10, 2008, at 2:30 PM, matt at mail.bettencourt.info wrote:
>>> what has happened to the ability to have a procgroup file automatically
>>> spawn an MPI job.  example
>>> ls
>>> myjob  myjob.pg
>>> mordred:french% cat myjob.pg
>>> local 0
>>> localhost 1 myjob
>>> localhost 1 myjob
>>> localhost 1 myjob
>>> ./myjob
>>> then just runs on four CPUS
>>> Is this capability available?
>>> When i do this under 1.27 it works, however, in mpich2 107, it no
>>> longer
>>> seems available.  Is there something like this that works. It is very
>>> useful for working with valgrind and gdb and the like
>>> M
