[mpich-discuss] lock/unlock regions and process synchronization
Rajeev Thakur
thakur at mcs.anl.gov
Thu Jul 10 15:53:00 CDT 2008
You could use some out-of-band synchronization like that to achieve
atomicity.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert Kubrick
> Sent: Thursday, July 10, 2008 3:46 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] lock/unlock regions and process
> synchronization
> Thanks Rajeev, I already have the book in the mail. On a related
> note, is there any potential issue using SYSV semaphores with one-
> sided communications? While the active task is completing the set of
> instructions, all the other slave processes could wait on a semaphore.
> On Jul 10, 2008, at 4:11 PM, Rajeev Thakur wrote:
> > What you are trying to do is an atomic read-modify-write,
> which is not
> > trivial to do with the MPI-2 one-sided operations. There
> are two ways
> > described in the book, Using MPI-2. One is easier to understand
> > than the
> > other one, but is less scalable. The source code for both is
> > available in
> > the MPICH2 distribution. See fetchandadd.c and fetchandadd_tree.c in
> > test/mpi/rma.
> > Rajeev
> Robert Kubrick
> >> Sent: Thursday, July 10, 2008 3:04 PM
> >> Subject: [mpich-discuss] lock/unlock regions and process
> >> synchronization
> >> I need to access a one-sided window region in a master
> from multiple
> >> slave processes. Each slave needs to read the window contents, then
> >> update the same window area:
> >> MPI_Win_lock(...);
> >> MPI_Get(&idx, ...);
> >> MPI_Win_unlock(...);
> >> // Got idx, check value
> >> if( idx > 10 ) {
> >> idx += 5;
> >> MPI_Win_lock(...);
> >> MPI_Put(&idx);
> >> How can I make sure another process does not access 'idx'
> >> between the
> >> two lock/unlock regions in the example?
