[mpich-discuss] lock/unlock regions and process synchronization
Rajeev Thakur thakur at mcs.anl.gov
Thu Jul 10 15:11:30 CDT 2008
What you are trying to do is an atomic read-modify-write, which is not
trivial to do with the MPI-2 one-sided operations. There are two ways
described in the book, Using MPI-2. One is easier to understand than the
other one, but is less scalable. The source code for both is available in
the MPICH2 distribution. See fetchandadd.c and fetchandadd_tree.c in
test/mpi/rma.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert Kubrick
> Sent: Thursday, July 10, 2008 3:04 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] lock/unlock regions and process
> synchronization
> I need to access a one-sided window region in a master from multiple
> slave processes. Each slave needs to read the window contents, then
> update the same window area:
> MPI_Win_lock(...);
> MPI_Get(&idx, ...);
> MPI_Win_unlock(...);
> // Got idx, check value
> if( idx > 10 ) {
>    idx += 5;
>    MPI_Win_lock(...);
>    MPI_Put(&idx);
> How can I make sure another process does not access 'idx'
> between the
> two lock/unlock regions in the example?
