[mpich-discuss] core 2 quad and other multiple core processors
Robert Kubrick
robertkubrick at gmail.com
Fri Jul 4 12:26:40 CDT 2008
I wonder why ch3:nemesis or ch3:ssm is the default in MPICH. Why
ch3:socket?
Robert
On Jul 2, 2008, at 10:59 PM, Rajeev Thakur wrote:
> For best performance, configure with --with-device=ch3:nemesis. It
> will use the Nemesis device within MPICH2 that communicates using
> shared memory within a node and TCP across nodes.
> Rajeev
> From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-
> discuss at mcs.anl.gov] On Behalf Of Ariovaldo de Souza Junior
> Sent: Wednesday, July 02, 2008 3:15 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] core 2 quad and other multiple core
> processors
> Hello everybody!
> I'm really a newbie on clustering, so I have some, let's say,
> stupid questions. When I'm starting a job like this "mpiexec -l -n
> 6 ./cpi" in my small cluster of (until now) 6 core 2 quad machines,
> I'm sending 1 process to each node, right? Assuming that I'm
> correct, each process will utilize only 1 core of each node? and
> how to make 1 process run utilizing the whole processing capacity
> of the processor, the 4 cores? is there a way to do this? or I'll
> always utilize just one processor for each process? if I change
> this submission to "mpiexec -l -n 24 ./cpi" then the same process
> will run 24 times, 4 times per node (maybe simultaneously) and one
> process per core, right?
> I'm asking all this because I think it is a bit strange to see the
> processing time increasing each time I put one more process to run,
> once in my mind it should be the contrary. I'll give some examples:
> mpiexec -n 1 ./cpi
> wall clock time = 0.000579
> mpiexec -n 2 ./cpi
> wall clock time = 0.002442
> mpiexec -n 3 ./cpi
> wall clock time = 0.004568
> mpiexec -n 4 ./cpi
> wall clock time = 0.005150
> mpiexec -n 5 ./cpi
> wall clock time = 0.008923
> mpiexec -n 6 ./cpi
> wall clock time = 0.009309
> mpiexec -n 12 ./cpi
> wall clock time = 0.019445
> mpiexec -n 18 ./cpi
> wall clock time = 0.032204
> mpiexec -n 24 ./cpi
> wall clock time = 0.045413
> mpiexec -n 48 ./cpi
> wall clock time = 0.089815
> mpiexec -n 96 ./cpi
> wall clock time = 0.218894
> mpiexec -n 192 ./cpi
> wall clock time = 0.492870
> So, as you all can see is that as more processes I add, more time
> it takes, what makes me think that mpi is performing this test 192
> times in the end and due to this the time increased. Is that
> correct that mpi performed the same test 192? Or did it divide the
> process into 192 pieces, calculated and then gathered the results
> and mounted the output again? I really would like to understand
> this relationship processor # x process # x .
> I have the feeling that my questions are a bit "poor" and really
> from a newbie, but the answer will help me on utilizing other
> programs that will need mpi to run.
> Thanks to all!
> Ari - UFAM - Brazil
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080704/133634f7/attachment.htm>
