[mpich-discuss] core 2 quad and other multiple core processors
    Ariovaldo de Souza Junior
    ariovaldojunior at gmail.com
    Wed Jul  2 15:15:02 CDT 2008
Hello everybody!
I'm really a newbie on clustering, so I have some, let's say, stupid
questions. When I'm starting a job like this "mpiexec -l -n 6 ./cpi" in my
small cluster of (until now) 6 core 2 quad machines, I'm sending 1 process
to each node, right? Assuming that I'm correct, each process will utilize
only 1 core of each node? and how to make 1 process run utilizing the whole
processing capacity of the processor, the 4 cores? is there a way to do
this? or I'll always utilize just one processor for each process? if I
change this submission to "mpiexec -l -n 24 ./cpi" then the same process
will run 24 times, 4 times per node (maybe simultaneously) and one process
per core, right?
I'm asking all this because I think it is a bit strange to see the
processing time increasing each time I put one more process to run, once in
my mind it should be the contrary. I'll give some examples:
mpiexec -n 1 ./cpi
wall clock time = 0.000579
mpiexec -n 2 ./cpi
wall clock time = 0.002442
mpiexec -n 3 ./cpi
wall clock time = 0.004568
mpiexec -n 4 ./cpi
wall clock time = 0.005150
mpiexec -n 5 ./cpi
wall clock time = 0.008923
mpiexec -n 6 ./cpi
wall clock time = 0.009309
mpiexec -n 12 ./cpi
wall clock time = 0.019445
mpiexec -n 18 ./cpi
wall clock time = 0.032204
mpiexec -n 24 ./cpi
wall clock time = 0.045413
mpiexec -n 48 ./cpi
wall clock time = 0.089815
mpiexec -n 96 ./cpi
wall clock time = 0.218894
mpiexec -n 192 ./cpi
wall clock time = 0.492870
So, as you all can see is that as more processes I add, more time it takes,
what makes me think that mpi is performing this test 192 times in the end
and due to this the time increased. Is that correct that mpi performed the
same test 192? Or did it divide the process into 192 pieces, calculated and
then gathered the results and mounted the output again? I really would like
to understand this relationship processor # x process # x .
I have the feeling that my questions are a bit "poor" and really from a
newbie, but the answer will help me on utilizing other programs that will
need mpi to run.
Thanks to all!
Ari - UFAM - Brazil
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080702/69eecc72/attachment.htm>
