[MPICH] Compiling mpich with a new component
Rajeev Thakur
thakur at mcs.anl.gov
Fri Jan 25 11:19:46 CST 2008
Your component probably includes some .h file that in turn includes other .h
files. If the include paths are not specified correctly during the build, it
will complain. You can try including your component in say the ch3/sock/src
directory and use the Makefile in there to build your code as well and see
if it works.
Rajeev
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Krishna Chaitanya
Sent: Thursday, January 24, 2008 11:34 PM
To: Dave Goodell
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] Compiling mpich with a new component
There are still references to such non-existent .h files even after
configure has returned successfully. I find it had to understand how such
errors are not reported when I detach my component. Does it mean that they
are not actually necessary?
On Jan 24, 2008 2:00 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
Make sure that you run configure first. There are a number of files
of the form "FOO.BAR.in" that are used by configure to create
"FOO.BAR". "mpid_thread.h" is an example of one of these files.
For what it's worth, the mpich2 build system is somewhat complicated,
so you should be prepared to spend quite a bit of time poking around
with it in order to be able to add your own files.
-Dave
On Jan 24, 2008, at 12:13 PM, Krishna Chaitanya wrote:
> Hi,
> I have been working on a small profiling module and I wish to
> test it out by integrating it while building mpich. I am yet to
> modify the makefiles, I tried to compile the new files directly, by
> making sure that I have specified all the paths. I am faced with
> many errors relating to the files in the include directory. For
> example, in the file mpiimplthread.h,
> 20 /*#if (MPICH_THREAD_LEVEL >= MPI_THREAD_SERIALIZED)
> 21 #include "mpid_thread.h"
> 22 #endif
> The if test succeeds and the compiler complains that there is
> no file of that name.
> or
> in the file mpiimpl.h,
> 99 #include "mpidpre.h"
> Again, there is no file with that name.
> And there are also many errors of the type : error: expected
> specifier-qualifier-list before " ... " . Could someone shed some
> light on these?
> Thanks,
> Krishna Chaitanya K,
> National Institute of Technology,Karnataka (NITK),
> India
> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080125/135f9de0/attachment.htm>
