[MPICH] Compiling and using under WinXP/cygwin - use lib*.a in MPICH2\lib
Jayesh Krishna jayesh at mcs.anl.gov
Tue Jan 22 10:15:16 CST 2008
>>>> 1-Can you send me a procedure ?
	Just remove the MPICH2 install directory under cygwin (or modify the
PATH accordingly). Install MPICH2 using the MSI installer.
>>>> 2-I will be able to compile other programs under cygwin if MPICH2 it is
not installed under cygwin?
	As I mentioned in my previous email, "You should make sure that you
use the libraries (lib*.a)provided with the windows installation of MPICH2
(in MPICH2\lib) when compiling your program under cygwin (if you want to run
the program using the windows version of MPICH2)." You are provided a set of
libraries, MPICH2\lib\lib*.a, with the MPICH2 installation (MSI
installation) to be used with cygwin gcc. See the windows developer's guide
for more details
(http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=d
ocs).
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of madfran
Sent: Monday, January 21, 2008 4:50 PM
Subject: RE: RE: [MPICH] Compiling and using under WinXP/cygwin
Hi,..
I am sure I use the mpiexec from MSI, but however with the mpiexec from
cygwin I obtain the same result.
smpd.exe -status, say me,
"smpd running on NOHW8156"
Well. I think will be necessary to remove the installation of MPICH2 from
cygwin and remain only with the installation from msi.
2-I will be able to compile other programs under cygwin if MPICH2 it is not
madfran
>Hi,
>Can you make sure that you are using the mpiexec installed using the
>MSI installer when running your program, compiled under cygwin, on
>windows ? You should make sure that you use the libraries (lib*.a)
>provided with the windows installation of MPICH2 (in MPICH2\lib) when
>compiling your program under cygwin (if you want to run the program
>We recommend windows users to only install MPICH2 using the MSI
>installer (and not recompile under cygwin). The user can then compile
>his/her programs using the cygwin compiler suite and headers/libs
>provided with the MPICH2 installation (using the MSI installer).
>Also make sure that you have the process manager running on your system
>(After making sure that you are running smpd.exe installed using the
>MSI installer, type "smpd.exe -status" to get the status of the process
>manager).
>Regards,
>Jayesh
>From: owner-mpich-discuss at mcs.anl.gov
>Sent: Friday, January 18, 2008 3:10 PM
>Subject: [MPICH] Compiling and using under WinXP/cygwin
>Hi,...
>Situation.
>OS Windows XP
>cygwin
>Over XP I install mpich2 using "mpich2-1.0.6p1-win32-ia32.msi"
>Over cygwin install mpich2 using "mpich2-1.0.6p1.tar.gz"
>Facts
>I can't compile any software under cygwin that work under pmi but its
>work well.
>Example.
>I compile the soft "hellow" found under the
>.../mpich2-1.0.6p1/examples/ and created the "hellow.exe"
>I launch hellow.exe without problems under cygwin
>/tmp/mpi/mpich2-1.0.6p1/examples $ ./hellow.exe Hello world from
>process 0 of 1
>But with mpiexec the result is,
>$ mpiexec -n 2 ./hellow.exe
>[unset]: unable to decode hostport from 1245
>[unset]: aborting job:
>Fatal error in MPI_Init: Other MPI error, error stack:
>MPIR_Init_thread(294): Initialization failed
>MPID_Init(82)........: channel initialization failed
>MPID_Init(333).......: PMI_Init returned -1
>[unset]: unable to decode hostport from 1252
>Same result under cmd WinXP
>C:\cygwin\tmp\mpi\mpich2-1.0.6p1\examples>hellow.exe
>Hello world from process 0 of 1
>C:\cygwin\tmp\mpi\mpich2-1.0.6p1\examples>mpiexec -n 2 -localroot
>hellow.exe
>[unset[unset]: unable to decode hostport from 1318
>[]: unable to decode hostport from 1325
>[unsetunset]: aborting job:
>]: aborting job:
>madfran
