[MPICH] A doubt regarding the manner in the which MPI_init works
    William Gropp
    gropp at mcs.anl.gov
    Tue Jan 15 15:44:24 CST 2008
Most of the operations that are used as macros are defined that way
so that they can be eliminated at compile time.  The MPIU_DBG
routines are a good example.  These are macros that are used to
enable various debugging options and are not core parts of the
communicator structure.  In fact, when MPICH2 is built for use in
production, these macros are defined as empty.
To answer your other question, there are no universally used routines
for list management - instead, different modules make use of the
routines that they need.
Bill
On Jan 15, 2008, at 2:25 PM, Krishna Chaitanya wrote:
> Dear All,
>              I have been trying to understand the types of data
> structures used by MPICH2 and the way in which the various lists
> are maintained and how they are initialized. I happen to observe
> that most of such routines have been implemented as macros which
> has made my job slightly harder as they dont appear while debugging
> with gdb.( Is there a way to trace through them at run time?)
>              For example, I was keen on observing how MPICH2 deals
> with the MPI_COMM_WORLD data structure, which is of type MPID_COMM
> and it is a member of MPICH_PerProcess_t. So, at the time of
> populating  this structure , the library calls  [ from
> MPIR_Init_thread(...)    ]
>          MPIU_Object_set_ref( MPIR_Process.comm_world, 1 );
>          -- >   MPIU_DBG_MSG_FM ( .... )
>                   -- > MPIU_DBG_MSG_FMT ( .. )
>                          -- >  MPIU_DBG_Outevent ( ... )
>                                  --> va_start and other such list
> related macros.
> However, when the MPIU_DBG_Outevent function is invoked, the
> paramater, int kind is hard-coded to be 0. When the kind value is
> zero, the library does not do any list related work.Instead, it
> prints some details into a file.  So, how does the MPICH library
> maintain reference to the  MPIR_Process.comm_world structure,
> without the invocation of macros like va_start, va_arg etc.
> Its quite possible that I have got things wrong as I am jumping
> from one function to another using the ctags and I havent actually
> seen the code behave as above during run-time as we are dealing
> with macros. So, please correct me if I have got something wrong.
> And, I am trying to draw an analogy between the OPEN-MPI and the
> MPICH2 when it comes to the way the internal data structures are
> handled. In Open-MPI, the OPAL library maitains such lists and has
> routines to manipulate them. Does MPICH have any other way of
> working with the lists of objects other than using the va_start and
> other related macros?
> NOTE :  I am using the mpich2-1.0.6 version.
> Thanks,
> Krishna Chaitanya K,
> National Institute of Technology,Karnataka ( NITK)
> India.
> In the middle of difficulty, lies opportunity
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080115/0cd4f7d6/attachment.htm>
