[MPICH] Faster version of make and make install
    William Gropp
    gropp at mcs.anl.gov
    Tue Jan 15 10:13:31 CST 2008
It doesn't support a multithreaded make because of problems with ar
(the library archiver doesn't ensure that concurrent updates do not
corrupt the archive).  It can support building only the files that
are required; there is an option for that in configure (--enable-
dependencies); you also need to create the Makefile.in files to
support this (the reason is that not all environments support the
needed features; if you are in a GNU environment, all of this should
work).
Bill
On Jan 15, 2008, at 7:23 AM, Krishna Chaitanya wrote:
> Hi,
>       Does MPICH support a multi-threaded version of make or a
> version that compiles only those files and its dependents instead
> of compiling the entire source tree?
> Thanks,
> Krishna Chaitnaya K
> In the middle of difficulty, lies opportunity
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080115/122dabae/attachment.htm>
