[MPICH] setup and testing of smpd and mpiexec for MPICH2 under WinXP - Is Reg enties ok ?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Jan 14 12:42:57 CST 2008
 Can you see the registry entries for MPICH2 and check if they are *normal*
1. Run "regedit.exe"
2. Check the values in HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD  -- This
should contain binary (executable), phrase (passphrase) & version (version
number)
3. Check the values in HKEY_CURRENT_USER\Software\MPICH\SMPD\CACHE --- This
should contain the cached username(smpda)/password(smpdp) for smpd/mpiexec.
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Kim Parnell
Sent: Friday, January 11, 2008 5:12 PM
Subject: RE: [MPICH] setup and testing of smpd and mpiexec for MPICH2 under
WinXP
All of the results that I have reported thus far have been with MPICH2
uninstalled.  Just using smpd.exe and wmpiexec.exe
It seems like the issue on this system is in the communication since
  smpd -status
still does not return any info and has to be killed.
(I tested on a different but similar system with MPICH2 uninstalled and
returns a status)
On this system with the problem, the last lines returned by
  smpd -status -d
[-1:5056]../smpd_get_opt
[-1:5056]..\smpd_do_console
(no message about the smpd process running, it just hangs here;  my other
system returns a status here and a few additional lines)
  _____
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, January 11, 2008 1:22 PM
To: Kim Parnell
Cc: mpich-discuss at mcs.anl.gov
WinXP
 Can you try a fresh installation (uninstall any existing version of MPICH2
on the machine and install MPICH2 again) of MPICH2
(mpich2-1.0.3-1-win32-ia32.msi) and let us know if it works ?
Jayesh
  _____
Sent: Friday, January 11, 2008 2:54 PM
WinXP
I can kill the smpd process.  Then I can start it with:
  smpd -start
and stop it with
  smpd -stop
  smpd -status
  _____
Sent: Friday, January 11, 2008 12:45 PM
To: Kim Parnell
WinXP
 To restart smpd you should use "smpd -start" (not "smpd -install").
Jayesh
  _____
Sent: Friday, January 11, 2008 1:20 PM
WinXP
Let me provide the last items first:
  Can you provide us the output of "smpd -status -d" ? Can you try "mpiexec
-n 1 dir" ?
mpiexec -n 1 dir
    hangs at the command prompt and does not do a directory listing;   if I
include  -timeout 10  then it will timeout
smpd -status -d
[-1:5056]..\smpd_get_opt_int
[-1:5056]../smpd_get_opt_int
[-1:5056]..\smpd_get_opt_string
[-1:5056]../smpd_get_opt_string
[-1:5056]..\smpd_get_hostname
[-1:5056]../smpd_get_hostname
^C  to kill it    (does not return to command prompt)
I just  used  "smpd -install"   to restart the process after I had killed it
from the TaskManager.
I am not using the latest versions just to avoid possibly introducing
another variable with the MPICH2 applications that I ultimately want to run.
The version used is:
There are not multiple versions and I running smpd and mpiexec from the
local directory.
Thanks!
  _____
Sent: Friday, January 11, 2008 11:01 AM
To: Kim Parnell
WinXP
  Are you using the latest version of MPICH2 (1.0.6p1)? I would recommend
that you try installing the latest version of MPICH2 on your machine. (Are
there multiple versions of smpd/mpiexec on your machine ? Check the PATH and
make sure that you are running the right smpd/mpiexec.)
  Is there a reason you chose to run "smpd -install" (Instead of letting the
MPICH2 installer install SMPD as a service, which gets started when you
logon the next time)?
-n 1 dir" ?
Jayesh
  _____
Sent: Friday, January 11, 2008 12:25 PM
Subject: [MPICH] setup and testing of smpd and mpiexec for MPICH2 under
WinXP
Windows XP SP2 machine with Dual Core CPU
I have an MPICH2 application that was working correctly and now does not get
submitted.
I am trying to go back and test the smpd and mpiexec installations and
hitting some problems that I do not understand.
smpd -install
  starts an smpd process under user SYSTEM that seems to be running
smpd -status
   starts another smpd process under my username but never returns a status;
basically just hangs at the command prompt
smpd -stop
   Stopping MPICH2 Process Manager, Argonne National
Lab...................................
   MPICH2 Process Manager, Argonne National Lab failed to stop.
I can kill the smpd  process from the Windows Task Manager
I will put the Debug output from "smpd -d"  below
mpiexec -validate -user USERNAME
   hangs at the command prompt without any further output
mpiexec -register
prompts for username and password which I can register and is confirmed as
"Password encrypted into the Registry."
a simple test like:
mpiexec  -timeout 20   -verbose   -n 1 ping
will just terminate due to the timeout
I will put the verbose output below  under the smpd debug
What am I missing?   Thanks for any assistance.
Kim
smpd -install -d
[-1:5076]..\smpd_get_opt_int
[-1:5076]../smpd_get_opt_int
MPICH2 Process Manager, Argonne National Lab removed.
[-1:5076]..\smpd_get_opt_string
[-1:5076]../smpd_get_opt_string
[-1:5076]..\smpd_get_win_opt_string
[-1:5076]../smpd_get_win_opt_string
MPICH2 Process Manager, Argonne National Lab installed.
[-1:5076]..\smpd_set_smpd_data
[-1:5076]../smpd_set_smpd_data
C:\MSC.Software\Marc\2007r1\marc2007r1\mpich2\bin>mpiexec  -timeout 20
-verbose   -n 1 ping
..\smpd_get_full_path_name
...fixing up exe name: 'ping' -> '(null)'
../smpd_get_full_path_name
..handling executable:
ping.exe
..\smpd_get_next_host
...\smpd_get_next_hostname
.../smpd_get_next_hostname
...\smpd_get_host_id
.../smpd_get_host_id
..\smpd_create_cliques
...\next_launch_node
.../next_launch_node
../smpd_create_cliques
..\smpd_fix_up_host_tree
../smpd_fix_up_host_tree
./mp_parse_command_args
.host tree:
. host: l30544.na.mscsoftware.com, parent: 0, id: 1
.launch nodes:
. iproc: 0, id: 1, exe: ping.exe
.\smpd_create_context
..\smpd_init_context
...\smpd_init_command
.../smpd_init_command
../smpd_init_context
./smpd_create_context
.\smpd_make_socket_loop
./smpd_make_socket_loop
.\smpd_enter_at_state
..sock_waiting for the next event.
..SOCK_OP_CONNECT
..\smpd_handle_op_connect
...connect succeeded, posting read of the challenge string
../smpd_handle_op_connect
mpiexec terminated job due to 20 second timeout.
mpiexec  -timeout 100   -verbose   -n 1 ping
ping.exe
.host tree:
. host: l30544.na.xxx.com, parent: 0, id: 1
.launch nodes:
..SOCK_OP_CONNECT
mpiexec terminated job due to 100 second timeout.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080114/e087f661/attachment.htm>
