[MPICH] bsend behavior differences - any sample pgms ?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Jan  8 14:14:54 CST 2008
  Do you have a sample program showing the behaviour ? Have you tried
installing the 64-bit version of MPICH2 on 64-bit version of WinXP and
running your program ?
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Vlad Branzoi
Sent: Tuesday, January 08, 2008 9:59 AM
To: mpich
Subject: [MPICH] bsend behavior differences
I have a question about the behavior of buffered send on different machines.
On one machine MPI seems to send stuff from the buffer on a consistent basis
while on another machine it only sends messages out when I 'flush' the
buffer via a buffer_detach and buffer_attach.  What could be causing this
different behavior, and is there a way to make it consistent.
Both machines are running MPICH2 1.0.6p1.  The first one is running WinXP
32-bit version and the 2nd machine is running WinXP 64-bit version, however
both are running the 32-bit version of MPICH2.
Vlad
