[MPICH] build mpich2 with Myrinet GM
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Tue Feb 26 15:22:23 CST 2008
I tried intel-c-9.1.046 and it failed with the same error.
The only 2 Intel v9 available on the machine are:
 +intel-c-9.0.032-f-9.0.033-r1  Intel C/Fortran Build 20060223
 +intel-c-9.1.046-f-9.1.041-r1  Intel C/Fortran Build 20070111
There is no v10 and above available there.
I need fortran compiler, but gfortran is not available there, either.
Wei-keng
On Tue, 26 Feb 2008, Darius Buntinas wrote:
> It looks like the icc compiler you're using doesn't like the gcc-style inline
> assembly code.
> What version of icc do you have?
> Can you try compiling with gcc instead of icc?
> -d
> On 02/26/2008 12:32 PM, Wei-keng Liao wrote:
> > Attached are 3 files:
> > out.configure  -  stdout from configure
> > out.make       -  stdout from make
> > config.log
> > Wei-keng
> > > Can you send us the output of configure as well as config.log?
> > > Thanks,
> > > -d
> > > On 02/26/2008 11:35 AM, Wei-keng Liao wrote:
> > > > I got an error during make:
> > > > ../include/mpid_nem_atomics.h(31): catastrophic error: #error directive:
> > > > No
> > > > swap function defined for this architecture
> > > >   #error No swap function defined for this architecture
> > > > compilation aborted for mpid_nem_alloc.c (code 4)
> > > > I am using configure options:
> > > >           --with-device=ch3:nemesis:gm  \
> > > >           --with-gm=/opt/gm \
> > > >           --enable-f77 --enable-f90 --enable-cxx \
> > > >           --enable-fast \
> > > >           --enable-romio \
> > > >           --without-mpe \
> > > >           --with-file-system=ufs
> > > > and the command "uname -a" on the machine is
> > > > Linux tg-login4 2.4.21-309.tg1 #1 SMP Thu Jun 1 17:07:28 CDT 2006 ia64
> > > > unknown
> > > > I am using Intel compiler v 9.1.043
> > > > Wei-keng
> > > > > On 02/26/2008 10:08 AM, Wei-keng Liao wrote:
> > > > > > I have a few questions on build mpich2-1.0.6p1 with Myrinet GM
> > > > > > library.
> > > > > > On my target machine, the GM library (include, lib, bin, etc.) is in
> > > > > > /opt/gm. According to MPICH README, I used the 2 options below when
> > > > > > configuring:
> > > > > >     --with-device=ch3:nemesis:gm  and --with-gm=/opt/gm
> > > > > > I can see both libgm.a and libgm.so are in /opt/gm/lib.
> > > > > > Q1: Do I need other configure options or setting environment
> > > > > > variables
> > > > > >     (in addition to CC, FC, CXX, F90)? Should I set LDFLAGS to
> > > > > >     "-L/opt/gm/lib -lgm" ?
> > > > > Nope, the --with-gm=/opt/gm should take care of all of that for you.
> > > > > > Q2: Since nemesis does not support MPI dynamic process routines yet
> > > > > > and
> > > > > > I
> > > > > >     need those routines, can I use --with-device=ch3:sock:gm
> > > > > >     instead?
> > > > > No, only nemesis supports gm.
> > > > > > Q3: Do I need anything else (source codes, library) from Myrinet to
> > > > > > build
> > > > > >     mpich? Or the /opt/gm is good enough?
> > > > > All you need is libgm.a and gm.h.
> > > > > > Q4: Once the mpich is built, is there a way to verify that GM is
> > > > > > actually
> > > > > >     used?
> > > > > Well, you should see a performance improvement over using sockets.
> > > > > Run a
> > > > > ping-pong test; you should see latencies around 10us or less.
> > > > > -d
