[MPICH] build mpich2 with Myrinet GM
Wei-keng Liao
wkliao at ece.northwestern.edu
Tue Feb 26 12:32:12 CST 2008
Attached are 3 files:
out.configure - stdout from configure
out.make - stdout from make
config.log
Wei-keng
On Tue, 26 Feb 2008, Darius Buntinas wrote:
> Can you send us the output of configure as well as config.log?
> Thanks,
> -d
> On 02/26/2008 11:35 AM, Wei-keng Liao wrote:
> > I got an error during make:
> > ../include/mpid_nem_atomics.h(31): catastrophic error: #error directive: No
> > swap function defined for this architecture
> > #error No swap function defined for this architecture
> > compilation aborted for mpid_nem_alloc.c (code 4)
> > I am using configure options:
> > --with-device=ch3:nemesis:gm \
> > --with-gm=/opt/gm \
> > --enable-f77 --enable-f90 --enable-cxx \
> > --enable-fast \
> > --enable-romio \
> > --without-mpe \
> > --with-file-system=ufs
> > and the command "uname -a" on the machine is
> > Linux tg-login4 2.4.21-309.tg1 #1 SMP Thu Jun 1 17:07:28 CDT 2006 ia64
> > unknown
> > I am using Intel compiler v 9.1.043
> > Wei-keng
> > > On 02/26/2008 10:08 AM, Wei-keng Liao wrote:
> > > > I have a few questions on build mpich2-1.0.6p1 with Myrinet GM library.
> > > > On my target machine, the GM library (include, lib, bin, etc.) is in
> > > > /opt/gm. According to MPICH README, I used the 2 options below when
> > > > configuring:
> > > > --with-device=ch3:nemesis:gm and --with-gm=/opt/gm
> > > > I can see both libgm.a and libgm.so are in /opt/gm/lib.
> > > > Q1: Do I need other configure options or setting environment variables
> > > > (in addition to CC, FC, CXX, F90)? Should I set LDFLAGS to
> > > > "-L/opt/gm/lib -lgm" ?
> > > Nope, the --with-gm=/opt/gm should take care of all of that for you.
> > > > Q2: Since nemesis does not support MPI dynamic process routines yet and
> > > > I
> > > > need those routines, can I use --with-device=ch3:sock:gm instead?
> > > No, only nemesis supports gm.
> > > > Q3: Do I need anything else (source codes, library) from Myrinet to
> > > > build
> > > > mpich? Or the /opt/gm is good enough?
> > > All you need is libgm.a and gm.h.
> > > > Q4: Once the mpich is built, is there a way to verify that GM is
> > > > actually
> > > > used?
> > > Well, you should see a performance improvement over using sockets. Run a
> > > ping-pong test; you should see latencies around 10us or less.
> > > -d
Configuring MPICH2 version 1.0.6 with '--prefix=/home/ac/wkliao/MPICH/WKLIAO' '--with-device=ch3:nemesis:gm' '--with-gm=/opt/gm' '--enable-f77' '--enable-f90' '--enable-cxx' '--enable-fast' '--enable-romio' '--without-mpe' '--with-file-system=ufs' 'CC=icc' 'CXX=icc' 'F77=ifort' 'F90=ifort'
Running on system: Linux tg-login4 2.4.21-309.tg1 #1 SMP Thu Jun 1 17:07:28 CDT 2006 ia64 unknown
Executing mpich2prereq in /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3 with nemesis:gm
Executing mpich2prereq in /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3/channels/nemesis
configure: WARNING: The device ch3:nemesis:gm does not support MPI dynamic process routines
sourcing /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/pm/mpd/mpich2prereq
sourcing /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/pm/mpd/setup_pm
checking for gcc... icc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether icc accepts -g... yes
checking for icc option to accept ANSI C... none needed
checking whether icc accepts default optimizations... yes
checking for type of weak symbol support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking for multiple weak symbol support... yes
checking whether we are using the GNU Fortran 77 compiler... no
checking whether ifort accepts -g... yes
checking whether ifort accepts default optimizations... yes
checking how to get verbose linking output from ifort... -v
checking for Fortran libraries of ifort... -L/usr/projects/compilers/intel/9.1.043/lib -L/usr/lib/gcc-lib/ia64-suse-linux/3.2.2/ -L/usr/lib/gcc-lib/ia64-suse-linux/3.2.2/../../../ -lifport -lifcore -limf -lm -lipgo -lirc -lunwind -lgcc_s -lirc_s -ldl
checking whether ifort accepts the FLIBS found by autoconf... yes
checking whether C can link with -L/usr/projects/compilers/intel/9.1.043/lib -L/usr/lib/gcc-lib/ia64-suse-linux/3.2.2/ -L/usr/lib/gcc-lib/ia64-suse-linux/3.2.2/../../../ -lifport -lifcore -limf -lm -lipgo -lirc -lunwind -lgcc_s -lirc_s -ldl... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower underscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
checking whether Fortran accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking for which Fortran libraries are needed to link C with Fortran... none
checking whether Fortran compiler processes .F files with C preprocessor... yes
checking that f works as the extension for Fortran 90 program... yes
checking whether we are using the GNU Fortran 90 compiler... no
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (ifort -g ) works... yes
checking whether the Fortran 90 compiler (ifort -g ) is a cross-compiler... no
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 accepts f90 suffix... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for f90 compiler vendor... intel
checking whether we are using the GNU C++ compiler... yes
checking whether the C++ compiler icc can build an executable... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 3 . 2
checking for perl... /usr/bin/perl
checking for ar... ar
checking for ranlib... ranlib
checking for etags... etags
checking for etags argument to specify language... --language=c
checking for killall... killall
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... no
checking for bash... /bin/sh
checking whether /bin/sh supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for an ANSI C-conforming const... yes
checking for volatile... yes
checking for restrict... __restrict
checking for inline... inline
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether icc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... sixteen
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... sixteen
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs. MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking for egrep... grep -E
checking for ANSI C header files... no
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for char... yes
checking size of char... 1
checking for short... yes
checking size of short... 2
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 8
checking for long long... yes
checking size of long long... 8
checking for float... yes
checking size of float... 4
checking for double... yes
checking size of double... 8
checking for long double... yes
checking size of long double... 16
checking for wchar_t... yes
checking size of wchar_t... 4
checking for void *... yes
checking size of void *... 8
checking for size of float int... 8
checking for size of double int... 12
checking for size of long int... 12
checking for size of short int... 6
checking for size of 2 int... 8
checking for size of long double int... 20
checking for sys/bitypes.h... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is -1 and False is 0
checking how to run the C preprocessor... icc -E
checking for Fortran 90 integer kind for 8-byte integers... 8
checking for bool... yes
checking size of bool... 1
checking how to run the C++ preprocessor... icc -E
checking for complex... yes
checking for Complex... yes
checking size of Complex... 8
checking for DoubleComplex... yes
checking size of DoubleComplex... 16
checking for LongDoubleComplex... yes
checking size of LongDoubleComplex... 32
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on int64_t... no
checking for alignment restrictions on int32_t... no
checking for size of MPI_BSEND_OVERHEAD... 95
checking for gcc __asm__ and pentium cmpxchgl instruction... no
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking for ANSI C header files... (cached) no
checking for stdlib.h... (cached) yes
checking for stdarg.h... yes
checking for sys/types.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for limits.h... yes
checking for stddef.h... yes
checking for errno.h... yes
checking for sys/socket.h... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking for endian.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for gettimeofday... yes
sourcing /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread.h... yes
checking for pthread_yield... no
checking for library containing pthread_key_create... -lpthread
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
RUNNING CONFIGURE FOR CH3 DEVICE
checking for assert.h... yes
checking for uuid/uuid.h... no
checking for time.h... yes
checking for ctype.h... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for ANSI C header files... yes
checking for string.h... (cached) yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking for library containing uuid_generate... no
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating util/Makefile
config.status: creating util/shm/Makefile
config.status: creating util/shmbase/Makefile
config.status: creating channels/Makefile
config.status: creating localdefs
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: executing default-1 commands
copying /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3/../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: configuring in channels/nemesis
configure: running /bin/sh '/home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3/channels/nemesis/configure' --prefix=/home/ac/wkliao/MPICH/WKLIAO '--prefix=/home/ac/wkliao/MPICH/WKLIAO' '--with-device=ch3:nemesis:gm' '--with-gm=/opt/gm' '--enable-f77' '--enable-f90' '--enable-cxx' '--enable-fast' '--enable-romio' '--without-mpe' '--with-file-system=ufs' 'CC=icc' 'CXX=icc' 'F77=ifort' 'F90=ifort' '--disable-checkerrors' 'CFLAGS=' --cache-file=/dev/null --srcdir=/home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpid/ch3/channels/nemesis
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking for netdb.h... yes
checking for sys/ioctl.h... yes
checking for sys/sockio.h... no
checking for sys/ipc.h... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking for gm.h... yes
checking for gm_init in -lgm... yes
checking for mkstemp... yes
checking for rand... yes
checking for srand... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking for x86 mfence instruction using __asm__... no
checking for x86 sfence instruction using __asm__... no
checking for x86 lfence instruction using __asm__... no
checking for x86 mfence instruction using __asm... no
checking for x86 sfence instruction using __asm... no
checking for x86 lfence instruction using __asm... no
checking for x86 mfence instruction using asm()... no
checking for x86 sfence instruction using asm()... no
checking for x86 lfence instruction using asm()... no
checking for _InterlockedExchange intrinsic... yes
checking for SPARC membar instruction with gcc... no
checking for SPARC membar instruction with Solaris C... no
checking for SPARC stbar instruction with gcc... no
checking for SPARC stbar instruction with Solaris C... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/net_mod/Makefile
config.status: creating nemesis/net_mod/elan_module/Makefile
config.status: creating nemesis/net_mod/gm_module/Makefile
config.status: creating nemesis/net_mod/mx_module/Makefile
config.status: creating nemesis/net_mod/tcp_module/Makefile
config.status: creating nemesis/net_mod/newtcp_module/Makefile
config.status: creating nemesis/net_mod/sctp_module/Makefile
config.status: creating nemesis/net_mod/ib_module/Makefile
config.status: creating nemesis/net_mod/psm_module/Makefile
config.status: creating nemesis/net_mod/none_module/Makefile
config.status: creating include/mpidi_ch3i_nemesis_conf.h
Configuring with args --prefix=/home/ac/wkliao/MPICH/WKLIAO --with-device=ch3:nemesis:gm --with-gm=/opt/gm --enable-f77 --enable-f90 --enable-cxx --enable-fast --enable-romio --without-mpe --with-file-system=ufs CC=icc CXX=icc F77=ifort F90=ifort --disable-checkerrors
checking for architecture... LINUX
ROMIO home directory is /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for int large enough for pointers... no
checking for Fortran 90 KIND parameter for 8-byte integers... 8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
setting CC to icc
setting F77 to ifort
setting TEST_CC to /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/bin/mpicc
setting TEST_F77 to /home/ac/wkliao/MPICH/WKLIAO/mpich2-1.0.6p1/bin/mpif77
setting CFLAGS to -O -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for sys/socket.h... (cached) yes
checking for netinet/tcp.h... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
checking whether make sets $(MAKE)... yes
checking whether ln -s works... yes
checking whether install /usr/bin/install -c works... yes
Using INSTALL=/usr/bin/install -c
checking for totalview... no
checking for python2.5... no
checking for python2.4... no
checking for python2.3... no
checking for python2.2... python2.2
checking for python2... no
checking for python... python
checking that python2.2 is a valid python version... yes
checking that the cPickle module is available for python2.2... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for strings.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for putenv... yes
config.status: creating mpdconf.h
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran77... yes
checking whether the Fortran Offset type works with Fortran90... yes
Running Configure for F90 Type routines
checking for cc... icc
checking whether the C compiler sets its return status correctly... yes
checking for an ANSI C-conforming const... no
checking for Fortran 90 compiler default output file name... a.out
checking whether the Fortran 90 compiler works... yes
checking for precision and range of reals... 6 , 37
checking for precision and range of double precision... 15 , 307
checking for range of integers... 9
checking for available integer kinds and ranges... 2 , 1, 4 , 2, 9 , 4, 18 , 8,
{ 2 , 1 , 1 }, { 4 , 2 , 2 }, { 9 , 4 , 4 }, { 18 , 8 , 8 },
config.status: creating mpif90model.h
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/pkgconfig/mpich2-ch3.pc
config.status: creating src/pkgconfig/Makefile
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/parkill
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/mpid/common/locks/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/thread/mpe_thread.h
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
copying ./src/util/thread/mpe_thread_posix.c to src/util/thread/mpe_thread.c
moving mpe_thread.h to src/include
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
config.status: executing default-13 commands
config.status: executing default-14 commands
configure: configuring in test/mpi
configure: running /bin/sh './configure' --prefix=/home/ac/wkliao/MPICH/WKLIAO '--prefix=/home/ac/wkliao/MPICH/WKLIAO' '--with-device=ch3:nemesis:gm' '--with-gm=/opt/gm' '--enable-f77' '--enable-f90' '--enable-cxx' '--enable-fast' '--enable-romio' '--without-mpe' '--with-file-system=ufs' 'CC=icc' 'CXX=icc' 'F77=ifort' 'F90=ifort' --disable-checkerrors --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking whether make sets CFLAGS... yes
Configuring tests for MPICH2
checking whether struct hostent contains h_addr_list... no
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran has pointer declaration... yes
checking whether the Fortran 90 compiler (ifort -O2 -L/opt/gm/lib64 -L/opt/gm/lib) works... yes
checking whether the Fortran 90 compiler (ifort -O2 -L/opt/gm/lib64 -L/opt/gm/lib) is a cross-compiler... no
checking whether Fortran 90 has Cray-style pointer declaration... yes
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating errors/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
Configuration completed.
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080226/5301de48/attachment.obj>
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080226/5301de48/attachment-0001.obj>
