[MPICH] Compiling a program (john-mpi MPICH2) under cygwin / WinXP - use libmpicxx.a
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Feb 19 16:39:52 CST 2008
  If you want to compile MPI programs written in C++ from cygwin use the
libmpicxx.a library (not cxx.lib) in MPICH2\lib.
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of madfran
Sent: Tuesday, February 19, 2008 4:09 PM
Subject: [MPICH] Compiling a program (john-mpi MPICH2) under cygwin / WinXP
Hi,...
Trying to build a program under cygwin / WinXP I had received these
messages.
MPICH2 is installed only under WinXP.
Any idea?
gcc -c -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include
- L/c
ygdrive/c/Progra~1/MPICH2/lib -lcxx.lib -lmpi -lfmpich2 -funroll-loops
NTmmx_f
mt.c
NTmmx_fmt.c:63: warning: alignment of 'saved_plain' is greater than maximum
obje ct file alignment.  Using 16
NTmmx_fmt.c:65: warning: alignment of 'output' is greater than maximum
object fi le alignment.  Using 16
gcc: -lcxx.lib: linker input file unused because linking not done
gcc: -lmpi: linker input file unused because linking not done
gcc: -lfmpich2: linker input file unused because linking not done gcc -c
-DUNDERSCORES md5-mmx.S gcc -c  -DUNDERSCORES sha1-mmx.S gcc DES_fmt.o
DES_std.o DES_bs.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.
o AFS_fmt.o LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o
NSLDA P_fmt.o NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o NT_fmt.o md4.o
smbencrypt.o ra wMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o hmacMD5_fmt.o
WPAPSK_fmt.o mscash_fmt.o ora cle_fmt.o batch.o bench.o charset.o common.o
compiler.o config.o cracker.o
crc32
.o external.o formats.o getopt.o idle.o inc.o john.o list.o loader.o
logger.o ma th.o memory.o misc.o options.o params.o path.o recovery.o rpp.o
rules.o signals.
o single.o status.o tty.o wordlist.o unshadow.o ryan.o unafs.o undrop.o
unique.o  DES_bs_b.o x86.o x86-mmx.o  md4-sse2.o NTmmx_fmt.o md5-mmx.o
sha1-mmx.o - lkerne
l32 -o ../run/john.exe
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6c3): undefined reference to
`_mdfivemmx_no sizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6db): undefined reference to
`_mdfivemmx_no init_uniformsizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6ef): undefined reference to
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x703): undefined reference to
bench.o:bench.c:(.text+0x849): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x91f): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x9f2): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0xab0): undefined reference to `_MPI_Reduce'
john.o:john.c:(.text+0x33): undefined reference to `_MPI_Init'
john.o:john.c:(.text+0x43): undefined reference to `_MPI_Comm_rank'
john.o:john.c:(.text+0x53): undefined reference to `_MPI_Comm_size'
john.o:john.c:(.text+0x6e3): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x721): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x741): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x8f1): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0xa92): undefined reference to `_MPI_Finalize'
misc.o:misc.c:(.text+0x38): more undefined references to `_MPI_Finalize'
follow
collect2: ld returned 1 exit status
make[1]: *** [../run/john.exe] Error 1
make[1]: Leaving directory `/tmp/john-mpi/john-1.7.2-bp17-mpi6/src'
make: *** [win32-cygwin-x86-sse2] Error 2
